04-08-2024, 08:17 AM | #2 |
30
Rep 58
Hi, just measured mine for you, using digital callipers, the outside diameter of the exhaust pipe is 65.3mm (2017 640d GC). Measured from behind the tailpipes.
This obviously differs from either of the diameters you mention - maybe you’re working on inside diameter(?) in which case I’d assume 63mm |
04-08-2024, 06:17 PM | #4 |
Rep 7,491
Did you pull up the exhaust for your model using one of the online part database sites like realoem.com? They list the diameter of the coupler/bushing used to connect the exhaust and mufflers etc.
See #2 when you go to realoem.com and input your VIN and pull up the rear exhaust:
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
