Mobil 1 0w-40 euro no longer LL-01 approved since 11/2015
02-27-2016, 04:59 PM | #67 |
Rep 5,102
So it looks like if the bottle label has LL-01 approval then the oil (the previous Group III one)will be OK on cars that require LL-01.
An interesting topic is if LL-04 can be used instead of LL-01(e.g. Walmart Castrol Edge is LL-04 approved). In CA the gasoline sulfur level is already similar to Euro's standard, so even though CA gasoline is E10 as long as OCI is 6k-8k(or maybe even 10k) the low SAPS LL-04 should work just fine in CA(and the Fed will mandate 10ppm sulfur starting Jan 2017 in all states). In fact a few German indies around here use Liqui Moly LL-04, and their customers(like myself) don't see any issue with LL-04 with 10k OCI. |
03-08-2016, 06:07 PM | #68 |
Rep 891
So it was 71 out and I did an oil change.
Put in some 0 40 to use up my other bottle.. Went to my mom's and when I left I blew some smoke on a jeep at a stop sign lmao. Honestly though I think 0 40 is too thin. Not saying it's not a worn seal but it happens more when outside Temps are up and I drive somewhere then leave an hour or so later.
Formerly Ian_N54 - @b1mmr
03-09-2016, 03:28 PM | #70 | |
Rep 891
03-09-2016, 04:01 PM | #71 |
Rep 712
Sorry if I missed it but will they discontinue this and when?
I've been always a Mobil 1 fan and plan to use this on my new to me 325i. But I may go with Castrol is this is the case. |
03-09-2016, 04:07 PM | #72 | |
Rep 1,163
03-09-2016, 04:15 PM | #73 |
Rep 3,696
03-09-2016, 04:20 PM | #74 | ||
Rep 891
03-10-2016, 07:40 PM | #75 |
bOrN To DiE
413
Rep 1,738
Just changed my oil with new non LL01 approved M1 0W40 (4K miles between oil changes) Car felt smoother probably because of new oil. Lets see whats gonna happen
03-11-2016, 08:44 PM | #76 | |
Rep 1,286
2012 Jet Black 328i Coupe / ESS Tuning Gen. 2 Supercharger / Evolution Racewerks Oil Cooler / BMS Oil Catch Can / BMW Performance Exhaust with Dinan Y Pipe / Eibach Pro Kit Springs / Koni FSD Shocks / MFactory LSD & Differential Bushings / Performance Rear Trailing Arms / BMW Performance Strut Brace / Stop Tech Slotted Rotors / Hawk HPS 5.0 / SS Brake Lines / Brass Guide Pins / M3 Front Control Arms, 28 MM FSB, Engine Cowl, and DCT Paddle Shifters / Michelin PSS / APEX ARC-8
03-11-2016, 11:29 PM | #78 | |
Rep 1,818
Grabbed some ll-01 castrol 0-40 at walmart. Mobil 1 on the next shelf was the new non-bmw formulation |
03-13-2016, 11:38 AM | #81 | |
Rep 1,163
This goes on sale for $25.xx a jug about once a week on Anazon, but you can also find them at certain Walmarts for the same sale price. |
03-13-2016, 02:12 PM | #83 |
34
Rep 313
Drives: Like a hooligan
Good to hear. I bought two 5qt jugs of the new formulation yesterday, changing it this afternoon.
2016 F30 340i M Sport | 2009 E92 328i 6MT |
03-14-2016, 10:19 AM | #85 |
Rep 3,696
Considering that a lot of folks use Rotella T6 diesel 5w-40 motor oil in a variety of cars (including n54's and other e9x's)... I think you should be safe in using the non LL-01. However, I have not attempted this myself personally... it's only what I have "heard".
03-14-2016, 11:35 AM | #86 | |
34
Rep 313
03-23-2016, 04:52 PM | #87 |
Rep 5,102
The Castro Edge 5w40/0w30/0w40 at walmart is only LL-01 recommended not approved. Is there any Castro oil that has BMW LL-01 approval? Local NAPA stocks LiquiMolly LL-04 approved oil but those go for $8-9 per quart/liter.
03-23-2016, 09:34 PM | #88 | |
Where'd my VTEC go?
481
Rep 6,067
What do you mean recommended and not approved? If it says LL-01 on the bottle then it's approved.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
