How often do you change your oil?
View Poll Results: How often do you change your oil? | |||
3 months/ 3k miles | 8 | 9.30% | |
6 months/ 5k miles | 44 | 51.16% | |
1 year/ 10k miles | 29 | 33.72% | |
Never, engine oil last a lifetime | 5 | 5.81% | |
Voters: 86. You may not vote on this poll |
03-28-2021, 02:01 AM | #67 |
No one sleep in Tokyo
945
Rep 1,507
Drives: 2011 E90 328i//1995 E34 530i
Pretty easy to do both, and cheap in general. Especially if your go-to retailer has an awesome ship back old part, get refund policy. I do both at the same time about every 15-20 thousand miles, every four oil changes generally. I could go longer but net cost is very cheap for me and no reason not to, so might as well!
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
Piano_Black4.50 |
03-28-2021, 11:19 AM | #69 | |
3981
Rep 2,660
Drives: 2019 BMW 540
Some say it can mess with the gaskets and oil seals. Some say it does absolutely nothing. I used Ceratech like 1 year ago. Haven't noticed a difference. But, I have gotten a UOA either. I use LM 5w-40 the purple bottle which from my knowledge doesn't have a lot of Ceratech or MO2 as the Molygen does. |
03-28-2021, 09:07 PM | #70 |
Rep 1,531
I have follow the my cars CBS oil change intervals since brand new. Typically every 15,000 miles. That’s what BMW recommended so it was good enough for me! My car has well over 187,000 miles and still doesn’t use any oil between changes. Honestly I thought the car would blow up following this, but the engine valve train looks very clean. The dealer has done everyone of my oil changes as well. I can’t kill this thing!
2021 M40i Phytonic Blue / Black Vernasca
2020 X5 xDrive 40i Tanzanite Blue / Coffee Vernasca 2011 328xi. Space Grey - Sold 188,925 great miles |
Mosaud19983980.50 POBEP374.50 |
03-28-2021, 11:11 PM | #71 | |
Rep 1,772
Drives: Bmw 330i and Bmw 328i
03-29-2021, 05:30 AM | #72 |
Rep 1,531
Yes. The only time it didn’t was when I had the usual oil leaks, valve cover, oil filter housing, and oil pan gaskets. All were fixed during the last 10 years as they occurred. I got lucky when my Vanos went because the oil pan gasket was fixed for free under the 10 year Vanos warranty BMW put out. The bolts sheared off and part or the procedure is to check the oil pan to find them, meaning free gasket replacement!
I changed my plugs twice and changed all the coils once for preventative maintenance, no misfire, but figured they had to go sometime! The plugs were perfectly grey with no oil fouling each time. Engine still runs like new.
03-29-2021, 12:10 PM | #73 | ||
Robot
1694
Rep 2,193
This oil consumption has been exactly the same as long as I've owned the car for the past 3 years, so it hasn't gotten worse. I did a few things to try and stop the consumption including a piston soak (possibly try to free a stuck oil control ring) and replaced the CCV system which included a new external oil separator, and the oil consumption was unchanged. Oil consumption isn't as uncommon as you'd think. A friend had a brand new Q5 which burned a quart every 2000 miles. He later owned a new Q7 which also needed a quart added between oil changes. Quote:
The oil is being burned. But as I said, there's ZERO smoke. There's a bit of excess black soot on the inside of the exhaust pipes and the spark plugs have deposits indicative of oil burning, but again no smoke and no SES light so I'll just keep topping off with oil as needed and not stress over it. Besides, the 325 isn't really special. If something did happen, it could easily be replaced. My 330i on the other hand... with 6MT sport package, that definitely gets more attention and care. |
3PedalJake2613.50 Fritzer944.50 |
03-29-2021, 04:30 PM | #74 |
Rep 1,183
I have an N54, so every 7500 miles / 1 year. Oil changes are cheaper than new turbos!
I went with the CBS for my previous E46 (so around 15K miles) and it never used a drop of oil until it was totaled @ 225K. I’d do the same if I had an N52/N51. |
ky0u1068.50 |
03-29-2021, 05:14 PM | #75 |
Rep 1,599
Depends of the engine and reliability of the car.
- Changing oil on a hyundai accent every 3000 miles is fcking waste. First the engine will last longer than the car even with poor maintenance since its not a desirable car, and when too much stuff to do on it, people will scrap it. (go see scrap yards....) - Having a 'rare' car, that keeps value, with a over-engineering engine, yeah, could be a nice idea to keep oil change interval as per specs. My manual Audi Avant with the infamous 2.0t, call every 15k km interval. I do 8000km My E91, 10k km. Both car are on 1+ year oil (covid). But as per test, its not 1950 anymore, syn oil are lasting way longer on the shelve |
Fritzer944.50 |
03-29-2021, 08:50 PM | #76 | |
945
Rep 1,507
It won't hurt your engine, seals, or your gaskets. That's like an urban myth more than anything. Even if it did slightly, it does FAR more good than anything bad it could do.
Mosaud19983980.50 |
03-29-2021, 08:52 PM | #77 | |
3981
Rep 2,660
The engine flush could be a waste of money in my case |
03-30-2021, 12:59 AM | #78 |
945
Rep 1,507
Eh, I would highly recommend yout to do it a least few times, irregardless. It's very cheap.
Dave92N54528.00 |
03-31-2021, 02:17 AM | #79 |
Rep 8
I tend to change mine after about 5-7k , I'm running castrol 0w40 on my n54 and have had zero issues, but it honestly depends on your driving habits and what you use the car for.
03-31-2021, 04:45 AM | #80 |
144
Rep 350
10k but after opening up the valve cover it's slightly dirtier than I'd like. I'm dropping to 7500 miles. Also, the filter looks horrendous and collapsed by 10k.
08 E93 N52 170k
04-01-2021, 04:37 PM | #81 |
323
Rep 230
Every 10K miles.
6K if the car sounds like it's got a flu or after doing some rather long journeys @ motorway speeds. Last change was @ 7K miles. |
12-21-2023, 06:11 PM | #83 |
31
Rep 77
I'm new to the n54 scene. Tryna figure out which oil is best to use, Castrol gtx or liqui moly molygen?
Here in the UK both are about the same price. 5L is around £40-42. |
12-21-2023, 09:31 PM | #84 |
Rep 3,053
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
If the same price, LM is a go-to item for these cars. But I think with the turbo engines, don't obsess on the brand, but focus on doing the changes more often. As long as the oil is LL-01, you're good.
tcphoto3555.00 |
12-27-2023, 07:51 PM | #85 |
DIYer
274
Rep 312
BMW says their transmission fluid is lifetime. LIFETIME.
BMW says you don't need to change your oil but every 10k miles. Most don't trust the lifetime transmission fluid recommendation claim. But will run their car on a 10k mile oil change and trust that recommendation. When it costs less to just change your oil to keep your engine running new. Oil in a combustion engine is crucial. Clean oil is critical to preserving the engine as a whole. With costly and complex engine like in these BMW, just change your oil frequently. It is the cheaper alternative. |
12-31-2023, 05:07 PM | #86 | |
31
Rep 77
Its unusual for a German company to give such a vague measurement. Same nonsense for the ZF box, but the ZF site says to service before 70k miles. I think when BMW say lifetime*, they mean *lifetime under warranty period. Word on the street is the DCT oil service should be done between 80-100k miles. The oil spec is given, so its tempting to use off the shelf brands to save money, but turns out this Getrag DCT can be very picky, so its best to use bmw oil or the oe brand oil. oem - BMW DTF 1+ (£25/L) oe - Fuchs (formally Pentosin) titan FFL-4 (£15-18/L) Both oils are made by the same company and specifically developed for this DCT box. Different packaging, identical oil. Link below to for more info https://www.opieoils.co.uk/p-87386-f...ion-fluid.aspx Last edited by mittu; 01-01-2024 at 11:03 AM.. |
StradaRedlands4998.50 |
12-31-2023, 10:54 PM | #87 | |
General
17428
Rep 18,801
01-01-2024, 09:00 AM | #88 |
Rep 3,060
As a freelancer, I don't drive a lot of miles so I change the oil once a year. I drive mainly city miles and it's been about 3500 miles this past year. I just ordered a kit from FCPEuro.
