05-13-2022, 12:30 AM | #155 |
Rep 9
I turned ASD off as I personally do not care for the artificial sound the feature offers. With the MPPSK and Eventuri intake I am able to hear the gear shifts and intake sounds much more clearly with the enjoyment knowing the amazing sound I am hearing is not artificial.
JD
Billfitz8296.50 |
05-13-2022, 01:21 AM | #156 | |
Rep 48
06-12-2022, 01:48 AM | #157 | |
Rep 48
my e-sys setup is; E-Sys 3.27.1 E-Sys Launcher PRO 2.8.2 v.4.27.20_PSdZData_Lite |
07-24-2022, 04:50 PM | #158 | |
Rep 3
Does anyone know if there are female headers of the hifi amp, and its part number? I ask this because I'd like to make an extension to retrofit ASD in my f31 that has wifi amp without changing the oem original cables. |
07-26-2022, 10:16 AM | #159 |
86
Rep 174
Drives: 2014 F32 435i xdrive 6 speed
My old 2006 Z4 did this...there was a pipe from the intake that fed past through the driver side firewall to pump in sound. Still some foam in the pipe to reduce the sound but I remember removing that as well.
08-05-2022, 03:38 AM | #160 |
Rep 3
ASD retrofit tutorial and resources
Hello,
Since I am in the process of doing this retrofit (ASD), I compiled all relevant information in one single document with: - tutorial for ASD retrofit - connectors and wiring details including fuse box, etc.. - coding tutorial - reported issues and open questions I share it here for all of you to use, comment and enjoy. I will uptate it if/when required. Important: I have NOT installed this or followed this information yet - I am waiting for parts. All this information was copy-pasted from this thread and other resources. Props to all that contributed in the forums, specially vitchie that created the main thread used as the main tutorial; atzebmw for its replies and clarifications, and many others for their questions and hands-in experience and for sharing their problems in the forum. Of course I am not liable for anything. Its your life, car and decision. Enjoy! |
10-25-2023, 06:27 PM | #161 | |
13
Rep 27
04-16-2024, 01:05 PM | #162 |
Rep 14
Hi, I’m going to attempt this, I don’t know which psdzdata version I should download? From the posts they say an old version is needed or the ASD feature won’t work. I have the part I have a harness. Need to splice some wires and connect up.
