BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > Regional Forums > Canada
Mporium BMW
      07-05-2021, 05:51 PM   #1
Prince_of_Persia
Prince_of_Persia's Avatar
248
Drives: 6MT E92 M3
Rod Bearing change in Vancouver
Hey everyone,
My 08 M3 has been extremely reliable, and just hit 93K KM. I thought to get a quote to replace its rod bearing as an upcoming maintenance. Leah’s Automotive in North Van gave me a quote for ~$5K. Is that the amount people usually pay to change their rod bearings? If so, how does that make sense where I have seen you can buy a second hand engine for around 8-9K? Am I missing something?
AW|FR 6MT E92 ///M3
      07-06-2021, 11:51 AM   #2
MisterClutch888
MisterClutch888's Avatar
552
Drives: 2011 E90 M3 6MT ZCP
i just DIY my 08 last year as well. i think shop usually charges around 1500-2000 for labor?
Parts you can simply source them yourself for cheaper. I think with my BE bearings, ARP bolts, engine mounts, 10w60 oil, filter, oil pick up o-rings, oil pan gasket....etc. Parts were under $2000 for sure.
Current - 2011 E90 M3, Jet Black, 6MT ZCP. Recaro/Bilstein/BBS/StopTech/Haimus/Turner/Pinnacle/BE/Auto Solutions/Macht Schnell/GC/Whiteline/Slon/Alpine
Sold - 2008 E92 M3, AW x FR, 6MT. CF roof is oh-so-Sexy!
IG @misterclutch888
Slow Build
      07-06-2021, 12:28 PM   #3
Prince_of_Persia
248
Drives: 6MT E92 M3
Thanks for the reply. So people pay around 40% of a second hand engine (assuming doing the job in a shop) for changing rod bearing? If that is the case, it seems a bit expensive and I prefer to take the risk, and in case of an engine failure, try to find a second hand engine.
AW|FR 6MT E92 ///M3
      07-08-2021, 08:04 PM   #4
Brody_Goble
Drives: E46 M3 Coupe 6-speed, LS7 240
I just had mine changed 2 days ago by Performance One in Richmond. They have done a lot of e9x there and did a great job and also really quick, was happy. I know they have one set of BE bearings and ARP bolts on hand as they are a little hard to come by currently. The job was in the 3-4k range with new engine mounts, new oil pan gaskets and bolts, oil change of course etc etc. They can knock it out same day you drop the car off usually!
      07-09-2021, 01:46 AM   #5
MaximusB
Drives: 13 Frozen White E92
About $3k-$4k range for parts and labour, pending on what else you change while at it.
Sure it is 40% cost of an used engine but you’re not factoring in labour to swap the motor, plus unknown of an used motor. How will you know an used motor won’t spin the bearing as well?
      07-11-2021, 03:54 PM   #6
Scharbag
Scharbag's Avatar
2621
Drives: 2011 E92 M3
2011 BMW E92 M3  [0.00]
I did mine myself.
That said, 10 hours of labor is $1500 max and a good shop should be able to knock it out in under 10 hours. Parts are $1500 max using BE bearings and bolts, new gaskets, oil, PS fluid and motor mounts. No way a shop should be more than $3k for a bearing swap.
It is not a hard job, just takes time.
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies...
      07-15-2021, 11:35 PM   #7
tsk94
tsk94's Avatar
1522
Drives: E92 M3, E82 128i, F82 M4, E36
Where the hell are you finding a used S65 for $5k CAD? Let me know so I can pick one up if they are that cheap..
Expect to spend ~2k for a well done job by a shop that knows what they're doing. Anything in the realm of 3k is ridiculous. It's not a 2k labour job. Parts alone are 1k so the remaining is labour. If you're decent at wrenching you can do it yourself and save some money. Takes a long time to do but it's not overly difficult.
      07-27-2021, 03:25 AM   #8
diaosiM3
Drives: m3
I had bearings replaced for S65 and S85 in late 2020. Cost was $4-5k for 18 cylinders (parts and labour).
Here's the S85:
      08-26-2021, 02:46 AM   #9
bornyesterday
18
Drives: F82, E92
got mine done at dynamic performance in Richmond, racing greed is also a popular place
      09-09-2021, 10:33 AM   #10
iamtrashman
iamtrashman's Avatar
185
Drives: 09 E92 AW Stripper M3
Just had mine done at Mike Automobile in Richmond yesterday. Great guy and would highly recommend him. He has done a bunch of them, and the fact he prefers to use BE bearings is reassuring, as other shops recommending ACL and VAC etc don't have as much of my confidence, given the amount of data BE has been willing to provide over the competition.
I supplied my own parts minus oil and a filter, and the cost was just a hair over 2000$ with tax.
The peace of mind after getting the service is worth it. My car has 142xxxkm and the bearings were not the worst I had seen but they still did NOT look good.
Will be taking pictures soon for the RB thread.
      11-04-2021, 09:57 PM   #11
BCBMWF30
BCBMWF30's Avatar
52
Drives: m3
I had mine done at Racing Greed. My other friend also went there.. Tommy the owner stocks BE bearings or you can supply your own parts. He said they have done a lot of rod bearings on these cars over the last few years. I paid $2k and brought my own parts.
      07-29-2023, 02:43 AM   #12
Prince_of_Persia
248
Drives: 6MT E92 M3
Anyone recently has changed the rod bearings in Vancouver? What parts did you use, where did you do it, and how much did you pay? I think i decided that I want to keep this car for ever so need to change the rod bearing this year.
Thanks
m3post
