05-04-2022, 12:07 PM | #1 |
128
Rep 172
Drives: 2020 Z4 M40i
How to remove marker from leather?
I found what looks like black permanent marker on my arm rest. I tried common Google search suggestions - distilled vinegar, makeup remover wipes, Mr. Clean magic eraser, and baking soda and toothpaste mixture. The mark is much lighter but it's still there.
I thought I would see if anyone here has any suggestions. I don't know if the arm rest is actually leather. I don't think it is. Thoughts, suggestions?
2020 Z4 M40i - Black Sapphire Metallic with Magma Red Vernasca Leather
05-04-2022, 12:24 PM | #2 |
Rep 1,798
Disclaimer: I'm not responsible for further damage.
High alcohol content (80-90%) isopropyl alcohol and a cloth. It likely will remove the dye on the leather if you over do it. |
05-04-2022, 01:06 PM | #3 |
Rep 11,136
Careful. It's easy to start damaging the material. Trust me, I know from trying to clean my steering wheel. Once you go too far, it'll look worse than the marker you're trying to remove.
05-04-2022, 01:13 PM | #4 |
Rep 3,548
If you're talking permanent marker I want to say they have toluene in them, maybe xylene. Either way it's quite the solvent, it's one reason they work. You might need a solvent on a similar level to basically dissolve it again and remove it. Brake cleaner, some goof-off's (the little metal can). I have a feeling they'll murder the leather though.
Agreed that you will probably make it worse. If you want it perfect you probably have to replace it. Or get the cleaner on every part of the arm rest you can see, and then plan to "fix" the leather afterwards. And again, being prepareed to replace it if it just doesn't work. |
Karnidge127.50 |
05-04-2022, 04:35 PM | #5 |
128
Rep 172
Ya, I made the mistake in the past of being too aggressive on my steering wheel and ended up having to have it professionally redone. So I don't want to repeat that here. Although, that armrest part on the door feels more like rubber than leather. Maybe I will have to live with it like it is.
05-04-2022, 05:28 PM | #8 |
Rep 3,548
Any shops in your area that do interiors, i.e. for classic cars? They may have something?
You might also consider a test spot, where you absolutely can't see or care about. Try a cleaner there. I think the leather itself might be OK but I think anything that lifts off marker will probably bring a lot of that red with it. |
Karnidge127.50 |
05-04-2022, 08:18 PM | #9 |
Not a good Canadian sheep!
1273
Rep 1,109
I personally feel if it's a spot you rest your arm on that might be just the ticket. Let it wear off naturally from your skin or clothing slowly doing that work.
That after all is the natural course for the leather really. What about a oil of some sort. Leather can absorb oil so it shouldn't hurt it too much if you use a tiny bit on micro fiber. I agree with the guys above...careful as that surface is delicate somewhat as you seem to already understand. 99% alcohol removes marker very well. But it may loosen the top layer of color. something will work...or let it wear off. Doesn't look to deep to me. |
05-04-2022, 08:20 PM | #10 | |
2030
Rep 2,672
05-04-2022, 08:22 PM | #11 |
6553
Rep 2,310
Drives: 9Y0 Cayenne S
Either Goo Gone or Goof Off. Read the labels, they are not both compatible with the same materials.
Do you with certainty have leather door trims? The armrest is generally vinyl. Confirm your option content, and dealers usually have a sales guide that indicates which specific surfaces are leather. |
05-04-2022, 08:36 PM | #12 | |
Rep 11,136
///M Power-Belgium63358.00 |
05-04-2022, 08:56 PM | #13 |
1195
Rep 2,907
That is for sure not leather. I can tell just by looking at it. Try some Blue Magic leather and vinyl cleaner. Can be had at many auto part stores. Might take while to work, but it wont' harm the surface.
05-05-2022, 06:38 AM | #15 |
Petrolhead
440
Rep 808
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
Give Colourlock strong leather cleaner a go - I had great results removing blue ink streak from our leather couch. I usually use their mild cleaner to clean my BMW seats and steering wheels - but it may not be enough for that marker. Amazon usually stocks them.
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) |
Karnidge127.50 |
05-06-2022, 08:17 AM | #16 |
Rep 4,404
Drives: 2022 Z4 M40i, 2021 228i GC
Try smooth peanut butter and apply it gently with a damp cloth. It worked in my wife's old Mini on the material on the roof and the driver's door when she smeared them with red lipstick. I realize that lipstick isn't the same as a marker but you might get lucky.
My local mechanic told me about the peanut butter trick several years ago and it works for certain stains. |
Karnidge127.50 |
05-07-2022, 10:15 PM | #17 |
6553
Rep 2,310
Karnidge any progress?
05-08-2022, 02:07 AM | #19 |
148
Rep 164
Hear me out on this.....red marker.
Westside Guy5720.50 |
05-08-2022, 03:20 AM | #20 | |
Rep 944
Consider obtaining some of the correct colour leather paint to cover over anything that remains. |
05-08-2022, 05:47 PM | #21 |
128
Rep 172
I picked up some Colourlock strong leather cleaner and applied it over the weekend. The mark is much lighter now and has no damage to the surrounding area. I am going to try applying it again to see if I can get it to completely disappear.
*fingers crossed*
M8Bimmer1272.50 spielnicht439.50 tracer bullet2411.50 StradaRedlands4940.50 mzwerner393.50 chassis6552.50 Westside Guy5720.50 ny2nj189.50 |
