Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Cosmetic and Lighting Modifications
      07-20-2021, 01:38 PM   #1
Kurt206
Kurt206's Avatar
Drives: 20 F82, 03 E46 M3, 89 E30 M3
F82 Door Panel Interior Trim Removal/Replacement "plugs"?
I had a few minor scratches on my door panel interior trim so I ordered the new part, removed the old piece, and went to install the new one but there was nothing for the new part to "plug into" in my door panel, just the holes.
I searched the forum but didn't see anyone discussing this and there doesn't seem to be any videos online either.
I did find a picture on another thread (attached below) which looks to show black plugs (circled in blue) that the new trim piece would push into but I can't find a part # in the diagram that matches and BMW parts department has no clue.
Has anyone replaced this part in the past? Know IND-Distribution made replacement painted parts so perhaps someone has installed those and knows what they are.
      07-20-2021, 08:51 PM   #2
Strmtrpr_F80
Strmtrpr_F80's Avatar
494
Drives: 2015 BMW F80
The piece is held in by sealant. I used sealant like e6000. You have to push it in, add sealant then hold until it hardens. I removed mine and painted them. Mine an f80
Kurt206147.50
      07-21-2021, 02:25 AM   #3
Dang3r
Schmollbraten
Dang3r's Avatar
Germany
12512
Drives: M4CPC // HP4 Comp.
Correct, its rest is realized with sealant and sometimes with heat melted ends. For some of the pins you have to order the clips from number 19, but to be honest I dont know the amount of the necessary clips, also necessary is number 17, but also here no idea how many to order.
Hope that helps.
Citizen of ///M - Town, where too much is just right
Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox
Kurt206147.50
psyki285.00
      07-21-2021, 12:11 PM   #4
Kurt206
Kurt206's Avatar
Well they certainly don't make it easy do they... Thank you both for the help.
Dang3r12512.00
      07-21-2021, 08:41 PM   #5
Strmtrpr_F80
494
Here you go https://www.realoem.com/bmw/enUS/sho...diagId=51_9239.
Kurt206147.50
      07-22-2021, 12:48 PM   #6
Kurt206
Kurt206's Avatar
In case anyone is interested, I ended up getting a bunch of Part 17 from BMW and they were a bit small, very difficult to put on.
I ended up buying larger clamps in the same style from a hardware store and was able to secure the piece on well.
I played around with the idea of melting/sealing but the clips work great and if needed can remove the piece later on.
Dang3r12512.00
psyki285.00
      08-06-2021, 01:25 PM   #7
Imperial328i
Imperial328i's Avatar
Drives: 2015 MGM 328i, 2017 LBB M2
I had good luck using washers and screws on my F30
2017 F80 ZCP - Mineral Grey Metallic
Kurt206147.50
      04-08-2024, 07:03 PM   #8
CKP42027
Cayman Islands
Drives: BMW M4
What size screws and washer?
Thanks!
f80post
