BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > dumb fuel pump question
      04-14-2024, 07:47 PM   #1
autoart
347
Drives: 2009 335i e90 M/ 22 X3
I don't know if I'm missing something.
I am on my second fuel pump in the past month.
The fuel psi goes down to 20 psi on hard pulls.
It starts fine within about 4 days. After that, I get a long crank, and stumbles a bit then runs fine.
Could it be anything else like the EKPS or the low-pressure sensor before I change fuel pumps again? 2009 335I. Thanks
      04-14-2024, 08:08 PM   #2
335i54n
Drives: e90 335i, e39 m5
lpfp sensor, ekpm, and fuel reg/filter -check all
      04-16-2024, 11:46 PM   #3
autoart
347
What are signs of a lpfp sensor problem?
      04-17-2024, 06:54 AM   #4
iqraceworks
iqraceworks's Avatar
2002
Drives: 2007 335i
Whats your fuel pressure at idle? If it's around 72psi at idle, and then drops down to 20psi during a pull, something it wrong. Can you post a log showing the LPFP and Rail (HPFP) pressure during a pull?
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
      04-18-2024, 04:26 AM   #5
335i54n
lpfp sensor is one of those things that is easier to replace with new than to actually do any testing. Imo doesn't fail often.
      04-19-2024, 11:12 PM   #6
autoart
347
From what I have read the lp sensor will stay at the same reading and not move, or throw a code. Mine does neither of those.
I think it's the fuel pump, I ordered a new 1. Will see how it goes
