04-14-2023, 08:09 PM | #1 |
118
Rep 328
Liquimoly engine flush... Is it needed?
Hello!
I own a 2016 340i coming up on 60k miles. For my next oil change, I purchased motul xcess 5w40 and an OEM filter. Currently in the car I have rotella t6 at about 3k miles. Changing it soon, but I remember I have a bottle of LM engine flush in my garage. Could I do it on my b58, and if so, how? I saw how you may need to change the oil twice or something. I've changed oil brands a few times. I'm finally settling on motul. Just wondering if I should throw this engine flush bottle in the car before I change the oil. Also, has anyone else done it on their b58? Will it harm anything? Thanks !! |
04-14-2023, 08:29 PM | #2 | |
Rep 629
04-14-2023, 09:29 PM | #3 |
118
Rep 328
Gotcha. Yea it's just been sitting on my shelf. I was thinking why not, but I didn't know much about it... like the procedure and if I'll hurt the motor.
04-15-2023, 05:54 AM | #5 |
Rep 629
If you are worried about it harming your engine don't use it. If you do the flush follow the directions exactly and don't worry about it. If you are worried about the residual liquimoly flush after draining, fill with some cheap walmart synthetic (Quaker State Euro is only $22 for the 5 quart bottle), run your engine for 15 minutes, and drain again. Then complete your oil and filter change with the Motul oil you bought.
If all of that sounds wasteful, it probably is. The little bit leftover won't harm your engine after you do the normal oil change. Then again, the whole engine flush thing is not necessary for properly maintained engines. |
04-15-2023, 08:51 AM | #6 |
Rep 503
Engine flush seems useful if you're restoring old E46/E39/E36 cars that have had 'deferred' maintenance.
If you're on top of your oil changes and such, it's totally unnecessary at normal mileage. |
04-15-2023, 11:14 AM | #7 |
118
Rep 328
Ah ok. I didn’t know if it mattered for me, as I’ve switched oils a few different times with different brands/viscosities.
Neue_Klasse4.50 |
04-15-2023, 12:25 PM | #8 | |
Rep 10,394
Might as well save it for a time when you buy a beater bimmer that has been neglected.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
04-15-2023, 12:29 PM | #9 |
118
Rep 328
Dang. So even if I've changed to a few different oils, it won't do anything? I didn't know if it would do anything or not I assumed since all of them have different additives and viscosities it would be a good idea to just flush it.
04-15-2023, 02:48 PM | #10 |
Rep 10,394
There's not an overly large difference between off the shelf brands which are blended to the same approvals. The differences which do exist are found at the end of the extended drain intervals (10k miles and over).
Ivilla035118.00 |
04-15-2023, 04:07 PM | #11 |
Rep 629
I think you have the wrong idea of what liquimoly engine flush does. It’s less of a flush and really it’s a cleaner. Engine flushes consist of a solvents (typically naphtha or kerosene) and detergents. They clean and and disperse hardened sludge and hardened/coked oil. It gets suspended in your oil and gets drained out.
04-15-2023, 09:14 PM | #12 |
Rep 1,703
Drives: 2014 428i and 2018 X5
I been using it once a year for each my cars for almost 10 years now…2 BMWs, 1 Dodge and 3 GMCs and never an issue.
It basically turns your oil into the consistency of water, which allows it to easily and fully drain out of the engine…brining with it all the dirt, sludge, etc.
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
01-30-2024, 09:19 PM | #13 |
126
Rep 222
Drives: '20 M340iX
Just did a flush with the liquimoly pro line stuff on my M340i (2020). I couldn’t believe all the shit that came out of the motor. Absolutely insane. And it flowed freely and completely. Drain pan was coated in brown sludge. Filled with Liquimoly 6600 and cranked it. Quiet as hell, smooth as hell, and just feels like it’s almost new again. Not trying to be dramatic with that statement but that’s exactly how it's operating. Stage 1 tune since 4,700 miles or so with occasional E30 mix. Sitting at 56k now. Very pleased. Not sure how anyone would say this shit doesn’t work. All motors collect junk on the internals. Doesn’t matter how often you change the oil.
01-31-2024, 03:24 AM | #14 |
225
Rep 378
This is what's in it...if anyone is interested.
https://sichdatonline.chemical-check...09-2022_EN.pdf |
03-31-2024, 09:20 PM | #15 |
Mike FURY
Rep 11
Hi Everyone,
New to bummerpost. Would a engine flush using liquid molly or something else help clear this? I did genuinely have it serviced 7 months ago can’t seem to understand what’s gone wrong. Hoping it’s a new timing chain and a good old engine flush ? Any help or advice would be greatly appreciated Thanks |
04-01-2024, 06:49 AM | #17 |
Mike FURY
Rep 11
04-01-2024, 03:25 PM | #19 | |
118
Rep 328
MyBimma0.00 |
04-01-2024, 03:29 PM | #20 | |
118
Rep 328
If that was my motor, I'd go grab the flush from autozone (liquimoly) and throw it in. But at that point, I'd even grab 2 bottles and do it a second time with the cheapest synthetic you can find (kirkland or supertech) depending on how it looks/sounds. The flush would likely be your best bet, but do it at your own risk. That's just what I'd do in an attempt to save it. Update us if you do! |
MyBimma0.00 |
04-01-2024, 03:34 PM | #21 | |
Mike FURY
Rep 11
Initially the only thing I could hear was the timing chain making that dreaded sound on a cold start up… after 15 minutes of the car warming up, the sound would fade away substantially. I do have the car booked in for a timing chain at an independent garage, hopefully they can do the flush as well. Retailer diagnosed the following ; Visible float/movement on the cam shaft Crank shaft has float/movement which is outside of tolerance Also play in the time chain There is a significant difference in the oil condition from the top of the engine to the bottom …. My confusion is that I’ve genuinely had it services accordingly to the manufacturer recommendation with proof of servicing. Doesn’t make any sense to me whatsoever |
04-01-2024, 03:37 PM | #22 | |
Mike FURY
Rep 11
