PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
Intermittent TPMS Pressure Monitor Malfunction
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
02-18-2023, 02:34 PM | #1 |
IN54NE
324
Rep 483
Drives: e90 335i LCI M-Sport
Hello everyone,
Trying to diagnose my TPMS Inactive issue. It comes and goes, self-clears then reappears a few days/week later and I've had it. On most drives it would clear before getting home so I wouldn't even be able to get a scanner on to see what part of the system is failing so that I had a starting place to diagnose it. However, today I managed to get home with the malfunction still going on and got a scanner on there. I didn't want to miss my chance so I just threw on my Carly (no bully) and this is what I got: Running it through a code decoder, I got this: I took it to my local tire shop and they scanned each TPMS and did confirm that all sensors were producing a signal except for the driver's front. Now, interestingly enough, I HAVE had issues with my reverse gear sticking/activating while driving (causing my PDC and rear lights to activate) so it's funny that this code includes both those faults. I have a new reverse switch on order (car is a manual) but have not yet ordered a new TPMS. Could the faulty TPMS cause the whole system to malfunction? I thought if one TPMS goes bad it only displays a fault with that specific unit in the CIC? Ergo, would it stand to reason that if I replace my presumed faulty TPMS, my inactive code should disappear? This is probably my next course of action but I just wanted to see if anyone else had this issue and how they resolved it (WITHOUT coding out the TPMS function and switching to FTM). Car is 10/2009 build 2010 e90 335i
03-23-2023, 05:13 PM | #2 | |
IN54NE
324
Rep 483
For anyone who may stumble upon this thread years from now with the same issue and tries to search 005E2E or 5E2E I think my issue was a dead/dying/damaged TPMS sensor
I posted about my fix here: Quote:
I have also only driven the 335i maybe not even 100 miles since swapping sensors however so it may be too early to tell. If I end up receiving a new error I will update the thread but If I don't, that should be all the information you need to conclude what has happened from here on out
06-26-2023, 10:28 AM | #3 |
Rep 1
Hi all. Having a similar problem, tho mine is TPMS Malfunction and is no longer intermittent. Had TPMS sensors scanned at a tire shop today and they all read good; surprising since they're original from 2011.
Planning on new tires soon, so should I just replace wheel sensors anyway due to their age? |
06-27-2023, 01:07 PM | #4 |
94
Rep 298
Drives: 2011 BMW 335xi
I would replace both. Mine were giving me intermittent codes for a while. I chased a few rabbits, but eventually just bought new ones and had them installed when I got new tires. They did not charge for relearn. These sensors learn on their own.
2011 BMW 335i xDrive E92 N55 Alpine White\M-Sport /BMS CAF/HPS CAI/VRSF 5" FMIC/VRSF CP/VRSF Inlet and Outlet/VRSF Catless DP/NGK 1-Step Colder Plugs/xHP Stage 1//MHD Stage 2+
06-27-2023, 06:35 PM | #5 |
202
Rep 165
The other option I wish I had known about earlier is coding it out: https://www.e90post.com/forums/showt...highlight=tpms
06-27-2023, 08:49 PM | #6 | |
94
Rep 298
