09-27-2020, 07:56 PM | #1 |
24482
Rep 191,469
Active Autowerke MAD MAX M3 M4 Exhaust - 3 Can Valved
The Ultimate F8X BMW M3 & M4 Rear Exhaust System - now with valves At Active Autowerke, it’s not ONLY about making as much power as possible. For over 30 years, power has been the end result of improved performance due to our relentless desire to develop a refined, quality product. This philosophy behind our performance parts is best represented by one of the newest additions to our F80 BMW M3 and F82 BMW M4 collection. The Active Autowerke F8X rear exhaust was carefully engineered to eliminate the unflattering sound of the factory M3 and M4 exhaust, while also allowing for optimum flow and resonance. Every effort was made in addressing the not so appeasing sound of the stock OEM exhaust, but in designing an exhaust worthy for an "M" car. We believe our rear exhaust combined with our mid-pipe offers the deepest sound and best performance of any other system on the market today. Available for both models, this axle-back exhaust gives your BMW the deep, throaty, growl a car of its caliber should have had from the factory! And NOW, after many requests from our dedicated customers, we are introducing a valved version of the ultimate exhaust which has been dubbed "Max Max" by our team. We will update dyno charts later but this exhaust flows even better with its valved system. Key features Made in the USA 18+ WHP gain over stock* 30+ LB-FT gain over stock* Quicker turbo spool Low, Deep Rumble Flex joints to reduce vibration Double-canned muffler to reduce resonance Each exhaust test-fit on our F8X Exhaust Fixture Guaranteed to fit all F80 BMW M3/F82 BMW M4 Includes all necessary installation hardware Note: Active Autowerke Full Exhaust System is recommended for, BUT NOT LIMITED TO, off-road or racing applications. Refinement Meets Performance: The OEM F8X exhaust utilizes the services of middle and rear silencer as well a pair of exhaust valves. It is supposed to be a freely-flowing exhaust that produces an external sound that meets the demands of a M3 or M4. The middle silencer has a small crossover that allows for noise dampening while the rear silencer (muffler) has a reflection chamber on either end that re-directs exhaust gases to the opposite side they entered from (driver’s side exhaust exits on passenger side). When the exhaust valves are closed, this helps eliminate the back pressure buildup that occurs during noise dampening. After analyzing the factory exhaust, we realized less would be more in regards to our F8X exhaust. We began with a complete redesign of the mid-pipes. This involved drastically increasing exhaust flow as well as reducing the uneven, out-of-sync turbocharger's sound that many F8X owners have complained about on the forums. We were able to achieve this on our F8X Mid-Pipe (sold separately) by using a single pipe that not only cancels out the offensive sound, but allows unrestricted exhaust flow. The most noticeable difference between the Active Autowerke F8X Rear Exhaust Section and the BMW factory exhaust is how we utilized the muffler. Our design incorporates two mufflers that create a huge resonance chamber to further cancel out the “weed eater” noise. This design also allows exhaust gases to crossover freely without being forced in a certain direction - eliminating back pressure without sacrificing that deep, aggressive rumble that some turbocharged cars are known for. Note: Active Autowerke GUARANTEES that each and every F8X Rear Exhaust Section will be a precise fit. Every Active Autowerke F8X Rear Exhaust Section is test-fitted on our in-house F8X Exhaust Fixture as part of our quality control measures.
09-28-2020, 05:13 AM | #3 |
Rep 4,203
09-28-2020, 08:24 AM | #4 |
Rep 5,204
Just spoke to AA. Mad Max is only the valved 3 can rear section. Midpipe is not included. You pick if you want to reuse your factory midpipe or buy an AA mid (single or equal).
Currently 6-week wait on all EL mids (res/non-res) , and Single mids are in stock. I want to hear Max on an EL mid with Hi-Flow Cats. Prolly extra mean sounding when opened up!
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
mike@x-ph.com24481.50 |
09-28-2020, 11:00 AM | #5 |
Rep 511
Hmm... it looks like repurposed NOS of their previous model, [Edit:] "3 can" exhaust.
Nevertheless, If it lives up to the hype (Dyno. & sound), it's an excellent idea! The claimed "+18WHp" is based upon a purely "stock" (Non - ZCP or DP'd. stock Mid.) configuration, correct? What's the weight in comparison to the OEM Axle back/muffler set up? Also, can that back plate, to the rear (facing out) of the valved downturned pipes, be (waterjet?) [Edit: Similar to the exhaust cross brace] etched with a logo? Personally, I'd like to see and hear it on a stock "ZCP" with an EL resonated Mid Pipe. Cheers!
///M Joy
09-28-2020, 11:05 AM | #6 |
Rep 1,164
Well this looks interesting, and the fact you can pair it with an AA mid is a huge plus. Awaiting some sound clips, especially with stock DPs and original AA midpipe. Sorry if I missed it, but what's the price range for this rear section?
09-28-2020, 11:28 AM | #8 | ||
24482
Rep 191,469
09-28-2020, 11:31 AM | #9 |
Rep 606
Really looking forward to Non Res EL MP with Stock DP soundclips! Getting reaaally close to pulling the trigger on this setup.
09-28-2020, 05:56 PM | #11 |
24482
Rep 191,469
Done
09-28-2020, 07:05 PM | #12 | |
Rep 511
Since your the OP here, could you please respond to the above post. Thanks!
///M Joy
09-28-2020, 07:09 PM | #13 | |
Rep 606
Non res EL Pipe for me please.
09-28-2020, 08:27 PM | #14 |
24482
Rep 191,469
Done
Mintsopoulos668.50 |
09-29-2020, 12:37 PM | #16 |
Rep 606
So excited for soundclips.
09-30-2020, 09:06 AM | #18 |
24482
Rep 191,469
I believe Active Autowerke posted a video of this setup a couple of weeks ago on their social media
10-11-2020, 10:49 AM | #21 | |
24482
Rep 191,469
