I'm going to preventatively replace my 72K N55 rod bearings
01-21-2019, 09:10 AM | #89 |
Clean is the new cool, keep it that way.
808
Rep 1,685
I mean, that is not ideal for sure, but I doubt these would have been a real problem for a long while.
But man, thanks for sharing your work, I appreciate it. I am curious about your driving habits and OIC's as well.
2011 335i, FBO, N55+ Turbo, full E85, S55 intercooler, etc.
2015 X5 35i Xdrive |
01-21-2019, 11:22 AM | #91 |
Rep 9,209
You are being ridiculous now. They won't be a problem for a long time as long as car isn't driven lol . Everyone with a little knowledge will disagree with you. As someone who has rebuild dozen of these engines and is dumb to attach mileage or time time frame I will tell you probably 12k or 1y max left on those bearings.
Pladi719.00 |
01-21-2019, 12:52 PM | #92 | |
808
Rep 1,685
2015 X5 35i Xdrive Last edited by 9krpmrx8; 01-21-2019 at 01:40 PM.. |
01-21-2019, 02:23 PM | #94 |
Rep 9,209
fatty335 sorry to pollute your thread. I wish there was less keyboard warriors. Anyhow, I'm doing one now with 100k. 2nd owner for the last 70k. Take a look.
01-21-2019, 03:48 PM | #95 |
123
Rep 109
Ouch, those are certainly worse than mine. Are you changing due to a problem or just as a "preventative measure" like me? N54 or N55?
01-21-2019, 04:57 PM | #96 |
Rep 9,209
Due to a problem. No noise. Good oil report. However, silent code for oil pressure (Castrol 0w-40) when Engine gets hot which is often caused by worn out bearings.
01-21-2019, 05:05 PM | #97 |
Rep 1,753
Hey feuer thank you for your input. Do you think that engine was neglected ? In terms of oil intervals or anything like that ?
01-21-2019, 05:08 PM | #98 |
115
Rep 127
What was the code and how did you diagnose it or came to find out it was the bearings? Interested to know.
01-21-2019, 06:14 PM | #101 |
Rep 9,209
2F7B. Didn't cause CEL nor showed on CIC. Only when you scan DME. Engine is put together now and isn't getting that code so the worn bearings were causing drop in oil pressure.
01-21-2019, 06:57 PM | #102 |
141
Rep 227
I'm happy this thread exists. This is all excellent information and definitely has convinced me to go ahead and plan to do this soon. I bought it at 50k, at 108k now and plan on keeping the car for much more than that. I've kept up with maintenance quite well and also use Castrol 0w40. No problems yet but I don't want to wait until it develops.
01-21-2019, 08:04 PM | #103 |
Rep 1,753
U can monitor this with MHD. Typical oil pressure numbers are easy to fnd through different logs under load or idle. Usualy 40 PSI idle at operating temp and 80 PSI Full throttle. DME will log guessing shadow codes if the pressure is low due to less restriction when there is less clearance.
feuer4277.00 |
01-21-2019, 08:06 PM | #104 |
Rep 1,753
It would be amazing if this engine was logged and u can share those logs but thats probably highly unlikely.
01-21-2019, 08:47 PM | #105 |
Rep 3,190
This is all very interesting and makes me want to consider a built engine sooner rather than later.
My main question is what causes bearing wear like this? I know on the S65 wear on ALL bearing is normal and they are proactively replaced. What could cause more bearing wear on only 1-2 cylinders? I know the stock tune pretty much runs on the knock sensors and pulls timing a lot. Would this knock cause this type damage over time or is this an oil issue due to too tight of clearance? |
01-21-2019, 09:01 PM | #106 | |
123
Rep 109
Design (tight tolerances, bearing composition, etc.) Factory recommended OCIs that almost all followed due to lease/free maintenance Driving style (i.e. driving hard on cold oil) Improper or delayed maintenance Poor quality fuel Tuning Obviously these are weighted differently in each instance but I suspect they all come into play in some measure. I doubt anyone will ever be able to narrow it down to one thing. |
Pladi719.00 |
01-21-2019, 09:13 PM | #107 | |
Rep 3,190
01-21-2019, 09:18 PM | #108 |
123
Rep 109
01-22-2019, 07:24 AM | #110 |
Rep 6,304
