M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Engine, Exhaust, Drivetrain Modifications
      07-04-2014, 10:49 AM   #133
Northern X5M
Northern X5M's Avatar
105
Drives: 2014 Tanzanite Blue M5
Originally Posted by M-bitious View Post
It needs some modifications but it will replace the oem one. I ran the car with a Bosch Motorsport fuel pump and instantly I had more power, but the pump could not be controlled as we wanted (two instead of four wires). We are now going to Walbro and this will work I am sure.
So you are saying that you could not increase the voltage of the Bosch Pump? Is it possible to run a Boost-a-Pump with the stock pump or is it even compatible with the fuel system?
2014 ///M5 CP Tanzanite Blue/Cohiba - 11.15 @ 128.8 & 1.84 60' (2150' DA) - BPM Tune - MSR Intake - SSP DCT - SS DPs & HFC Mid Pipes/X-Over - E Race Muffs - 19" MT DRs... On to a new home.
      07-04-2014, 01:05 PM   #134
M-bitious
M-bitious's Avatar
Netherlands
85
Drives: BMW M2
We had the oem pump running at 120% but it is not enough. Quick study learned that the fuel pump has three stages, low - mid - high, each controlled by its own wire. Perhaps we will hook up an extra pump to the wire for high level, so only when lots of extra fuel is needed (WOT) it activates the extra pump. But the guys are thinking it over carefully before executing it.
      07-05-2014, 03:13 AM   #135
Andym3100k
Singapore
110
Drives: 2014 M6 GC FULL HAMMAN WIDE BO
Can I know how do u get the pump to run at 120%?
What is the max boost that u r running at when u noticed u r running out of fuel?
Is yr system running stock or upgrade turbo? If is stock what boost r u running at?
Thanks.
      07-05-2014, 01:03 PM   #136
M-bitious
M-bitious's Avatar
Netherlands
85
Drives: BMW M2
They did that through software for the fuel pump.I am running stock turbos but I don't know what the boost is.
      07-05-2014, 05:41 PM   #137
Andym3100k
Singapore
110
Really like to know what boost yr system is running at, shouldn't be difficult to get a digital gauge that plug into the obd2 port n immediately u can tell what's the max boost u r running after a 4th or 5 gear pull. Can tell that most of us wanted to push the power to the next level so we need to explore into different boost level with different gas n of course methods like changing fuel pump n etc for the present moment unless someone break the DME code. Thks.
      07-21-2014, 04:44 AM   #138
M-bitious
M-bitious's Avatar
Netherlands
85
Drives: BMW M2
If I can get my hands on such tools I will let you know.
In the meantime we found out that the fuel pump is running on ac, while the rest of the world is on direct current. There are no alternating current fuel pumps other than BMW use. We need to think how we can change to direct current, but this involves hardware and software changes. Not easy, but once done it will be a solid foundation for more power in the near future.
      07-21-2014, 06:34 AM   #139
Andym3100k
Singapore
110
Sounds good can't wait to see the results.
      07-31-2014, 03:13 PM   #140
Rickstah
Rickstah's Avatar
Netherlands
Drives: F31
Spotted this M5 tonight at the local tuning shop, while picking up my E46 M3 CSL to go for a ride
Looks stunning! I noticed some new wheels??
      07-31-2014, 05:59 PM   #141
Andym3100k
Singapore
110
Hi M-bitious, any new progress on the fuel pump?
      08-02-2014, 05:08 AM   #142
M-bitious
M-bitious's Avatar
Netherlands
85
Drives: BMW M2
More data logging shows the fuel pump produces consistent with enough pressure. We are seeing a drop in fuel pressure at the high pressure system in higher gears under WOT. Not sure yet what causes the drop. Since the gearbox torque limiter was removed this happens.
Will keep you posted.
      08-08-2014, 01:18 AM   #143
M-bitious
M-bitious's Avatar
Netherlands
85
Drives: BMW M2
It seems the software cannot keep up with the fuel request. I need someone to actually program the car through the obd port, and I found someone. Need to make an appointment soon and get it sorted. The cause was removing the gear box torque limiter. Fuel demand is now too great. I will give detailed info once this is sorted and I will tell you how it was done, so we will know if we have an actual proper remap.
      08-08-2014, 02:48 AM   #144
Andym3100k
Singapore
110
Great sound good, pls keep us posted.
      08-11-2014, 03:31 AM   #145
M-bitious
M-bitious's Avatar
Netherlands
85
Drives: BMW M2
The fuel pump in the tank runs at 5 bar (72.5 psi) continuous. The high pressure fuel pumps run at a maximum of 200 bar (2,900 psi). They cannot produce a higher pressure without software modifications. As soon as my engine requests over 200 bar, it drops the fuel pressure to under 100 bar, and goes into limp mode. This cannot be solved with piggy bags, it requires a proper dme tune I mentioned above. This problem started when we removed the torque limiter from the gearbox. Once sorted I am sure it will be awesome and it opens up the doors to upgraded turbos.
      08-11-2014, 09:24 AM   #146
M5Rlz
249
Drives: R8, f10m59(Rip), m4, GTR
Probably why my car threw limp mode at 155+mph with amounted to 6lbs of boost on 93
      08-12-2014, 10:55 AM   #147
igorsm
Drives: M5F10
I'm having about the same issues with PP-Peformance Stage 3 kit in my M5F10.
After 3rd gear car is starting to shoot into the exhaust and jerking @ about 6200rpm.
Usually it happens in 4th.
After all it falls in the limp mode. It shows drivetrain malfunction on the dash.
When you read it with scanner it shows multiple cylinder misfires P0300 as well as other cylinder misfire codes P0301, P0302, P0305, P0308, etc.
Changed the plugs and coils - same thing.
Once it has thrown P0087 fuel system pressure low.
Maybe a pump as well? Or the fuel pressure sensor?
      08-20-2014, 03:17 PM   #148
AstonMartian777
Drives: 2014 M6 F06
How do you get 800 hp ? What mods ? Thanks !
m5post
