The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Excessive brake pedal travel.
      05-06-2024, 09:18 AM   #1
absconditus
Drives: BMW 320d ED E90 177bhp
Just fitted new discs and pads. Took car out for a test drive and I have excessive
Brakes pedal travel. The brakes work well and stop the car but I have to push further
Down on the pedal than I did before.
Only potentially odd thing I noticed were when I changed the near side front
Discs, and refitting the caliper, but before fitting anti rattle spring, when I had tightened the caliper slide pins.
I could slide the caliper a good 5mm forward and backwards on the slide
Pins......I could not do that on the rest of the calipers, Is something not right ?
Cheers
320d E90 2007
      05-09-2024, 05:20 AM   #2
vester86
97
Drives: BMW 330D '08
try breaking in the pads with a couple good hard stops and report back.
have you flushed any brake fluid?
      05-09-2024, 10:22 AM   #3
Malteser_wfj
52
Drives: BMW 335i 2012 Manual
As above, sounds like they need bleeding
brakes
