BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      01-31-2023, 02:18 PM   #23
///Mobbin
///Mobbin's Avatar
1478
Drives: m3
Pumped for this build, subscribed!
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
okusa853.00
      01-31-2023, 02:30 PM   #24
reidetailing
Alex - IG @screamer
reidetailing's Avatar
613
Drives: 08 SS E90, 11 Moonstone E92
Originally Posted by okusa View Post
Here you go
SPA Kevlar?
Instagram: @screamer
- 2013 Subaru STi Hatch - White - Racecar
- 2011 BMW E92 M3 - Moonstone - Collector Car
- 2008 BMW E90 M3 - Silverstone - Racecar
      01-31-2023, 05:33 PM   #25
okusa
okusa's Avatar
853
Drives: 2011.75 E90 M3 - SSII
Originally Posted by reidetailing View Post
SPA Kevlar?
SPG fiberglass shell.
      01-31-2023, 06:40 PM   #26
redpriest
redpriest's Avatar
2147
Drives: 2011 M3/Porsche 992 GT3RS
Subscribed, dogbone mentioned you were doing this. I too have a similar goal to get below 3k lbs.
'06 BMW M3 ZCP 6MT | JRZ RS Pro + Hyperco 650/750 | Epic Tune | Brembo 355mm BBK | too many to list
'11 BMW M3 ZCP DCT | Akra Evolution | Eventuri intake | MCS 3-way | 4.6L Carbahn S65 | Zebulon Aero | AP Racing Radi-CAL BBK by Essex | 305/645-18 Pirelli DHB
Porsche 992 GT3, 991.2 GT3RS, 718 Spyder
instagram.com/titomanlio
okusa853.00
      01-31-2023, 07:18 PM   #27
okusa
okusa's Avatar
853
Great, we can share notes!
      02-13-2023, 04:16 PM   #28
okusa
okusa's Avatar
853
Some progress pictures.
Once the rear parcel shelf came out, a cool rear cage landing zone concept was incorporated since I am running a true coil over in the rear.
      02-13-2023, 04:17 PM   #29
okusa
okusa's Avatar
853
Today the base plates were welded in and boxes made and tacked in. Tube work starts this afternoon.
Appreciate 4
derbo3610.00
redpriest2147.00
DRLane3991.50
      02-13-2023, 04:28 PM   #30
redpriest
redpriest's Avatar
2147
okusa did you switch over to MCS yet or are you still on JRZ?
      02-13-2023, 05:36 PM   #31
okusa
okusa's Avatar
853
I upgraded from JRZ RS-PRO (2 way) to JRZ Motorsport 3 way with upgraded pistons. Truly magical.
Appreciate 3
tsk941522.00
redpriest2147.00
      02-16-2023, 07:17 PM   #32
okusa
okusa's Avatar
853
Couple of cage progress pictures...
Appreciate 5
///Mobbin1478.00
tsk941522.00
roastbeef11586.00
      02-16-2023, 07:56 PM   #33
StripclubDJ
StripclubDJ's Avatar
4100
Drives: e92 m3
that wiring is calling my name lol
      02-16-2023, 10:20 PM   #34
okusa
okusa's Avatar
853
Will be coming your way…
      03-03-2023, 06:36 PM   #35
okusa
okusa's Avatar
853
Lots of carbon stuff arrived
Appreciate 8
tsk941522.00
DRLane3991.50
b4hand661.00
///Mobbin1478.00
Nish9037.50
derbo3610.00
roastbeef11586.00
      03-05-2023, 06:17 PM   #36
reidetailing
Alex - IG @screamer
613
Doors look absolutely incredible!!
This is my new favourite build, and rightfully so.
It's so cool, because I have an SS too, and it'll hopefully look similarly one day.
A couple questions:
1) I went on the HGK site, and didn't see Carbon E90 Doors?
2) I also got nervous because when you click E90, it shows a non-M3 E90 in WTCC form, but not sure if E90 non M3 doors are the same as E90 M3 doors?
3) How is fitment? Does it line up to the fender and rear quarter panel body-lines?
4) If I have the Plastics4Performance Polycarbonate Glass, will that work with these doors?
Thank-you so much, and I look forward to hearing back from you!
Sincerely,
Alex
      03-05-2023, 09:58 PM   #37
roastbeef
roastbeef's Avatar
Drives: E92 M3
good refresh job for when you come to do my car.
Instagram; @roastbeefmike
      03-05-2023, 10:41 PM   #38
StripclubDJ
4100
Drives: e92 m3
he’s going full send tho, you ain’t ready to be a man like this guy
Appreciate 4
roastbeef11586.00
tsk941522.00
Adrian g.245.50
      03-06-2023, 12:10 PM   #39
tsk94
tsk94's Avatar
1522
Drives: E92 M3, E82 128i, F82 M4, E36
A couple questions:
Doors should be the same non-M vs M3 sedan. It was for the coupe when I had my M3.
      03-06-2023, 12:20 PM   #40
okusa
okusa's Avatar
853
A couple questions:
Sincerely,
Alex
Thanks Alex!
It has been a bit of an adventure dealing with HGK. Though their responsiveness is generally acceptable, the order ending up taking over a month longer than promised. Why? It turns out that though they (previously) advertised carbon doors, they had never actually made a set! So, they must have tried and failed on the first go around and then made a second set. However, they uses their fiberglass mold for my set and could not get the finish right. My guess is that they tried to duplicate their fiberglass wet layup process rather than a dry method and then realized they could not hide the finish imperfections on a carbon product like they could with fiberglass. So, I am looking into options for cleaning up the door finish.
Apart from the finish, the door design and build quality is actually quite nice and the doors are shockingly light. They even used a kevlar inner layer for extra strength which was a nice surprise. The fitment (same for M and non-M) is decent for race parts, but not great. The right side is quite good but the left side requires a lot of tweaking, though I am confident they will fit properly when finished.
I also ordered P4P glass and it will absolutely work with these doors.
Hope that helps.
Owen
      03-06-2023, 12:26 PM   #41
DRLane
DRLane's Avatar
Drives: E92 M3
2008 m3  [6.63]
Owen,
Are you planning on mounting the lexan glass or using a slide method?
Have you see these? They’re on a couple race cars in buddies shop and it’s pretty sweet. Obviously you manually pull the “window panel” up and down. But seals really nicely.
https://quartermax.com/window-latch-kit/
Not a Doctor, those are just my initials.
      03-06-2023, 01:27 PM   #42
okusa
okusa's Avatar
853
Originally Posted by DRLane View Post
Owen,
I can't mount the lexan since most events require that you lower the fronts. My thought was to have them pinned so they are easily removable, but I think I like your suggestion better. Thanks!
DRLane3991.50
      03-06-2023, 06:16 PM   #43
reidetailing
Alex - IG @screamer
613
Thanks Alex!
Hope that helps.
Owen
Thanks for the insight, Owen.
Couple follow-up questions:
1) What do you do about the mirrors and door handles mounting? I don't see those sections cutout.
2) Do you need to run any weather-stripping / rubber door trim?
3) Can you also share some photos of what the inner door cards look like? Are you running the stock interior door cards, or does HGK make a carbon door card for the E90 interior?
Thanks Owen,
Alex
      03-06-2023, 06:20 PM   #44
okusa
okusa's Avatar
853
1. I am going to use my stock pieces.
2. I do not believe so, but haven't gotten that far. Will let you know.
3. There are actually pictures of the HGK carbon cards in the above picture (on the ground).
m3post
