04-18-2016, 05:15 PM | #1 |
Rep 9
Hood liner or sound insulation
Greetings all,
This is my first post here. However, I've reading your helpful posts for a while and learned a lot of thing. I know this subject has come up in the past and there has been questions with regards to the function of the hood liner and whether is meant for heat or sound insulation. Well, if you don't know it already, here are the picture! It's in fact sound insulation which to my surprise, BMW don't supply any longer on a lot of models. I took the car for a test drive after the install and for those who think it doesn't make any difference, my answer is - YES, IT DOES! The simplest test is to honk the horn and you will see the type of sound feedback that you hear in the room. Also, the engine sounds much warmer and you won't hear the tires in higher speeds as much! |
04-18-2016, 07:49 PM | #2 |
Beachtown Bill Collector
582
Rep 1,062
Drives: 2012 135i
I'm surprised to learn it has such an effect on noise. I believe the primary purpose is for it to act as a fire retardant that can fall onto the engine and supress/retard a fire.
Either way, it looks good! I may have to consider doing this on mine! Last edited by tock172; 04-19-2016 at 01:26 PM.. |
04-18-2016, 08:29 PM | #3 |
Rep 9
The reason I included the picture of the product tag was to show the factory description which says "sound insulation". There is absolutely nothing to do with fire and if there was, there would've been a huge liability for eliminating it. I'm not sure a car maker like BMW would take such a risk to save some production cost!
04-18-2016, 10:58 PM | #4 |
582
Rep 1,062
Drives: 2012 135i
Well, I wouldn't go that far. Any kind of hood insulation is flame retardant and designed to fall onto and smother and engine fire.
04-18-2016, 11:36 PM | #5 |
bimmerphile, technogeek
1000
Rep 3,785
Drives: 2012 E82 6MT Sport
Nice.
Debating whether or not to get it for my car... What did it cost you?
04-19-2016, 10:26 AM | #7 |
Rep 439
It is for both sound insulation and heat retention. Automakers have also been trying to quiet down the noises from engines with plastic covers (they're also to tidy up a cluttered engine bay). On our daughter's Mazda, for example, the plastic cover has insulation material underneath it. On my wife's Lincoln, the engine cover, which looks like black plastic, is actually heavy, dense foam. The hood sound pad helps here as well.
Things like lifters and injectors can be noisy and automakers use many techniques to suppress the various noises. BMW did away with the hood insulation on some models merely as a cost saving feature (like doing away with the hidden trunk key hole on later 1s). Remember at the time the Euro/dollar exchange wasn't helping things on already pricey BMWs. On it's latest and future models BMW wants the engine to stay warm for as long as possible so that on subsequent starts the engine is still up to temperature (cuts down on start-up emissions). Expect the hood pad to be in place on all BMW vehicles. Yes, hood pads have been around forever but they have a more important role than in the past. Last edited by KNS; 04-19-2016 at 10:57 AM.. |
04-19-2016, 10:42 AM | #8 |
Rep 439
While they may be flame retardant, I've never heard of the hood pad being used to help extinguish an engine fire. In fact, if you talk to a firefighter, engine fires are some of the most dangerous and hottest fires to try and put out. A simple hood pad would last a few seconds in a actual fire.
04-19-2016, 11:30 AM | #9 | |
Bergspyder
1484
Rep 1,216
WRT a fire I don't think you will be putting out an engine fire if it gets going. Especially a Magnesium Block!!!!!
04-19-2016, 01:14 PM | #10 |
27
Rep 91
Nice! I want one! Looks like the going rate is about $94, which is not bad for a bmw part.
But I noticed that the underside of your hood is white, but your car is blue. The underside of my hood is LeMans Blue, just like the exterior. What's up with that? Maybe they changed it on later cars (mine's a 2010). Is your trunk lid the same? Cheers! Craig |
04-19-2016, 01:21 PM | #11 | |
582
Rep 1,062
Drives: 2012 135i
The process is beautiful in it's simplicity. In the event of an engine fire, the plastic expanding rivets used to secure the insulation to the hood melt, allowing the insulation to drop onto the engine, in hopes of containing the fire and acting as a retardant. The idea is that it gives the vehicle occupant enough time to exit the vehicle before the fire spreads. Here's a photo of how it functions in a Corvette. Note how similar the material is to the photo posted in this thread. Here's a shot of the hood after the fire raged for 10 minutes. Notice how it is essentially isolated to the engine compartment. |
04-19-2016, 02:09 PM | #12 |
Rep 6,196
Interesting. I thought the 128's had the hood insulation, but BMW removed it on the 135's. Must have been a reason. Maybe the turbo runs too hot?!?
04-19-2016, 04:18 PM | #13 |
Rep 9
04-19-2016, 04:26 PM | #15 | |
Rep 9
04-19-2016, 04:37 PM | #16 |
Rep 9
128s don't come with it either (at least not mine which is 2012) - it's all about cost saving measures and apparently this was an item that could eliminated!
04-19-2016, 05:10 PM | #17 |
27
Rep 91
Well of course it's white, now that I look at it properly. The part I thought looked blue was the dash, which I mistook for part of the bodywork (which our cars don't even have, I mean I've got one right here I could have looked at!).
I'm playing the bad eyesight card! Cheers, Craig |
04-19-2016, 05:18 PM | #18 | |
Rep 6,196
04-19-2016, 05:30 PM | #19 | |
European Editor
10628
Rep 22,992
I remember being at the 'Ring a few years back with the 1er Forum.de Two guys swapped the insulation out - right there in the Brunchen parking lot! lol Dackel
04-19-2016, 09:56 PM | #20 |
Rep 439
Agree, it is possibly a flame retardant material, as I mentioned earlier. However I'd be willing to bet that is flame resistant (there is a difference). BMW wasn't concerned about occupant safety at the start of an engine fire otherwise they wouldn't have eliminated such a (critical) piece of equipment (it's fairly inexpensive yet they still chose to do away with it).
The Corvette engine has aluminum block. The BMW N series engines found in our cars are aluminum and magnesium. On your reasoning you better get out of a 128/135 fast if the engine catches fire because BMW took away the hood pad. Last edited by KNS; 04-19-2016 at 10:08 PM.. |
04-19-2016, 11:24 PM | #21 |
1000
Rep 3,785
Good point... I should get one, though I do prop up the hood all the time when I get home from work, just to let the heat out.
mecheng038.50 |
04-20-2016, 01:32 AM | #22 |
Rep 1,850
The idea that this thing will put out a fire is funny as fuck. No, it won't catch on fire itself, but it sure as hell isn't putting one out.
Yes, it's sound insulation. End of story. |
