04-25-2019, 11:28 PM | #45 |
429
Rep 268
11-01-2019, 07:57 AM | #46 |
92
Rep 125
headlight code
Hey Almaretto.. Would like to have the headlights coded to activate the adaptive option. Are you still doing this?
Have a 2020 X5, and believe I have all the options needed:
11-01-2019, 10:58 AM | #47 |
Rep 3,967
I wasn't bothered about the adaptive function. I got them because they're a lot brighter than the standard LEDs, which in turn are nowhere near as bright as the old xenons were
Owned: 440i GC LCI with MPPSK, F31 330D M Sport with MPPK, F11 530D SE, F11 520D SE, E61 530D M Sport, E36 325i plus many MB's, Audi's & Volvo's
11-20-2019, 04:44 PM | #48 |
16
Rep 47
Can you please get back to me brother I PM’d you.
11-20-2019, 10:50 PM | #50 |
37
Rep 56
Can you enable Lane Change Assist on 530i 2017 with the hardware already specced? My car has all the hardware and Active Lane Assist, but missed out on the mentioned function because it was disabled in the first year of production due to regulations. Later models can now do it but I'm still missing out and the dealer won't enable it for obvious reasons.
11-20-2019, 11:00 PM | #51 | |
Rep 8,364
11-20-2019, 11:23 PM | #52 | |
37
Rep 56
I'll send you a PM to coordinate this. |
11-21-2019, 02:39 AM | #53 |
Newbie to G30
Rep 37
Actually you are Right Hand Drive (RHD) like us in the UK as the steering wheel of the vehicle is positioned on the right hand side of the vehicle and drive on the Left hand side. Can be confusing.
11-21-2019, 10:05 AM | #54 | |
Rep 1,145
03-12-2020, 03:34 PM | #55 |
Rep 4
I am in need of help with Coding new headlights. I upgraded to the Adaptive - I had someone helping me and they were able to get the High / low beams to work, but not able to get the turnsignal or running lights to work.
The turnsignal modules i bought new from bmw, The module under the light assembly came with the lights The larger module on the inside of the light i transferred over from the the old lights. |
06-19-2020, 04:10 PM | #57 |
31
Rep 74
06-19-2020, 06:14 PM | #58 |
Rep 4,210
06-20-2020, 02:17 AM | #59 |
18
Rep 15
I'm in Australia and my 540i has the fully functional adaptive LEDs. For those in the US and other places where they are not functional, from my personal experience, I'd suggest it's not worth the effort trying to code them on. I've had my car for almost 3 years, and I've switched the adaptive function on maybe 5 times for only short periods. On those occasions, I've been flashed by some on-coming cars. Also, I find it disconcerting when travelling on a freeway that the high beams seem to dance around hitting signs on the sides of the road one second then moving up and lighting up the big signs on the overhead gantries. I can only imagine what other drivers are thinking!
In theory, the concept is a good one but doesn't appear to work all that well in real world situations. Otherwise, maybe there's something about the way our roads are set up here (someone mentioned that cats' eyes, which we have on many of our roads) that impairs the proper functioning of the adaptive LEDs. |
06-21-2020, 09:53 AM | #60 |
31
Rep 74
06-22-2020, 12:18 PM | #61 | |
M6GCComp, Porsche Cayman S PDK, Peug 208 GT1 BPS
512
Rep 1,280
Acceleration is heavenly
01-19-2022, 06:08 AM | #62 |
Rep 12
Hello everyone, I have retrofitted Icon headlights to 2019 BMW 540. I have removed option 5A2 and put option 552 and 5AC. VO coded BDC and both FLM modules. Everything is working now but I have low beam malfunktion and high beam malfunktion and parking lights malfunktion on Idrive. I still don't have the drl modules and I think the parking lights will disappear when I install them. The low/high beam malfunktion is what troubles me. Also I couldn't find any option to initialise headlights in ista. Only option to initialise turn signals which are working fine.
Any help will be greatly appriciated |
01-22-2022, 05:01 PM | #64 |
Rep 2
I have 2017 G12 I installed ICON headlights instead of regular LED, then added 552 to FA, code the BDC and both FLE's for the new FA, but both lights are blinking and give me an fault "Voltage out of tolerance range" Can you give me any advice please?
01-23-2022, 02:34 AM | #65 |
Rep 8,364
What does ISTA+ say when you run scan?
01-23-2022, 08:09 AM | #66 |
Rep 560
Define correctly? I VO coded this by removing the two lock VO codes, but I'm wondering if there's more to be had. It works fine now, but just curious.
