06-15-2012, 03:24 PM | #1 |
20
Rep 86
DIY Radiator Flush
I can't find a DIY for flushing the radiator. Can someone tell me if this is the right procedure?
1. Let the engine cool down. 2. Put the car in ramps/jacks. * Make sure the car height is balanced. The Radiator reservoir has to be the highest. 3. Remove one of the Under body cover 4. Remove the radiator bleeder screw (underneath the car) and let it radiator bleed. 5. Reinstall the bleed screw 6. Fill the radiator with only water. Let the radiator cap off (Pressurized cap) and turn the engine and car heater on. *Keep an eye in the fluid level!! 7. Let the car run for 5-10 min then repeat steps 4-6 like 2 times. 8. After bleeding water, Install a new bleader screw and fill the radiator with 50% Antifreeze-50% water. 9. Turn the engine and car heater on and let the coolant flow with the radiator cap off (to release the air in the system) 10. Turn the engine off, check level and install the radiator cap. If above steps are ok, I will do it today/tomorrow and post some pictures.. Thanks Jose |
06-15-2012, 05:54 PM | #3 |
Rep 1,286
If you do this, please post plenty of photos. I want to do this too, but haven't seen a DYI yet.
I checked the owner's manual and the only capacities it lists are for the fuel tank and the window washer fluid. |
06-15-2012, 06:07 PM | #4 |
Rep 980
I found a post for an E46 M3 and the DIY said 2.5 gallons. Ours could be more though...
http://www.m3forum.net/m3forum/showthread.php?t=327613
Mods: too many the list wont fit in the sig page. PM me
Tesla Referral code: http://ts.la/juliana77782 |
07-17-2012, 07:59 AM | #5 |
Rep 869
Bump. Any updates? I would like to do this too.
2008 M3 Coupe / DCT // StopTech BBK 380/355 / Pagid RS29 / Motul / Apex Arc-8 / BFG R1S / Ground Control / MS filter / Performance spoiler / BPM tune // Road Atlanta 1:39.70 / VIR Full 2:10.87 / Barber 1:42.20 |
07-29-2012, 12:41 PM | #6 |
Rep 10,668
I'll be doing it this week. Have not researched it yet. Typically, I find block drain(s) and open those and also the radiator drain. Apparently the system holds 12 quarts so buy 3 gallons if using a pre-mix or 2 gallons if you are mixing with distilled water.
08-14-2012, 06:19 PM | #7 | |
Rep 746
i'm looking to do this soon. |
08-14-2012, 06:32 PM | #8 |
Rep 1,470
Make sure to use distilled water. It is okay to not know the capacity. Just keep mixing up your own 50/50 blend a little at a time and only add that mix. Keep in mind that there will be residual fluid left in the block after you do these water flushes unless BMW has a plug on the side of the block to remove to get that out. Toyota gives you a block plug to remove. So if you cannot do that, err on the strong side when blend up your coolant and water to end up at 50/50. If you truly knew the capacity, that would help. I would fill and drain 3x with distilled water if I was doing it.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
08-15-2012, 09:13 AM | #9 |
Rep 12,315
I've done this job on my other BMW's. Really simple that you probably don't need pictures on this one.
If you were going to flush the radiator, might as well flush what's left in the block too (there's another plug as other members mentioned). Quite a lot of coolant came out of that too. Be prepared to get soaked though. It's always such a messy job. I recommend wearing safety glasses and have plenty of towels/rags on hand.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
08-15-2012, 09:33 AM | #10 |
Rep 10,668
So where is the block drain on the S65? No one has answered that question yet.
I have flushed coolant on E34, E36, and E39 so I understand the normal process. We are trying to figure out in this thread if there are any E9x M3 specific issues. I still have not gotten to this project so I have nothing to contribute yet. |
08-15-2012, 09:52 AM | #11 | |
Rep 12,315
There's nothing else down there. You're either draining oil or coolant from the block
Current:
10-15-2012, 07:37 PM | #14 | |
Rep 486
the manual says the coolant is lifetime fill.i plan to change it every 3-4 years.does anyone who is more mechanically savvy than me think it can really be left unchanged for the life of the car? Last edited by bimdo; 10-15-2012 at 08:26 PM.. |
10-18-2012, 10:35 AM | #15 | |
Rep 12,315
I don't track my car, but I still do a full fluid flush every 2 years. Easy job (although messy), but well worth it I think.
Current:
10-22-2012, 02:52 PM | #17 |
22
Rep 344
Has anyone done this yet? I'm due, but can't seem to find the information I need. Some posts say there is no block drain, others say there is. What's the consensus?
I've never done a coolant flush on a BMW and it would be awesome if somebody could post pics of the block drain (if it exists) and radiator bleeder screw. |
10-24-2012, 07:13 PM | #18 |
Rep 5,482
When they say "lifetime" they mean "it'll last long enough to make it until something else fails catastrophically to the point of needing a rebuild". For those who want 200k+ out of an engine, I'd change it more frequently than "never", or at least drain the rad and refill to get some of the more corrosive, higher dielectric stuff out and dilute it with fresh
03-14-2013, 09:00 AM | #19 |
Rep 12,315
Still no updates on potential drain plug in the block? I'm about to do this tonight or tomorrow, guess I might as well check for myself if no one has looked yet.
Current:
03-14-2013, 10:14 AM | #20 | |
Rep 409
It's a bummer they didn't put one in... on other BMWs it makes it really easy to get ALL the fluid out, albeit messy.
Jon Maddux
coupenut.blogspot.com x5nut.blogspot.com 16 X5d | 08 M3 Sedan | 06 M Coupe | 01 M coupe | 99 M coupe |
Fr0gman19.50 |
03-19-2013, 06:18 PM | #21 |
54
Rep 381
So... I gave this coolant flush a try and to my disappointment, I was unsuccessful in accomplishing a full flush.
Two problems: 1. I cannot locate the engine block drain. 2. I do not know the volume of the whole coolant system. What I bought: Two gallons of BMW antifreeze/coolant (one shown), 2 gallons of distilled water (one extra), new radiator drain plug - part#17117530902 What I did: 1. Jack up the car and level. Remove the felt panels underneath the bumper (Left, Center and Right). They are mounted with 8mm screws and 3x 10mm screws on the back of the center piece connected to the metal skid plate. (L piece - part# 51757896419, R piece - part# - 51757896420 ) - Unhooked (twist and slide to bigger hole) the hangers holding the center piece on both sides - part# 51757899820 2. Found the radiator drain plug (left side underneath the radiator). 3. Used a large phillips to unscrew it and drain. 4. Replugged the radiator drain hole with the old plug. 5. Filled the reservoir to about halfway with %50 BMW coolant / %50 distilled H20 (made separately in a container). The ball on the floating stick sat above the fill line. 6. Removed the bleed screw and fill cap. Start the engine and turn heater on highest temp without putting the fan on high. 7. I let the engine get to about 140 degrees F (took about 7-8 mins and heat starts coming out of cabin vents) and then shut down. Repeated steps 3.-6. three times using a new drain plug when done. 8. On the final fill, I filled to full and closed the bleed screw, opening and closing to let the air bubbles out while the engine is on. When there are no more bubbles, I used a turkey baster to remove some coolant from the reservoir. The issues: Since I did not know the volume of the coolant system, I did not try to flush the entire system using pure distilled water. The ratio of coolant to water would've been unknown when it came time to fill. I made a premix of 50/50 coolant/H20 and filled with that after each drain. Each drain yielded about 1 gallon of coolant. What my method hopes to accomplish is to dilute old coolant with new coolant. This is why I mentioned this is NOT a flush but a way to get keep the coolant somewhat fresh. My car is just under 2 years old and I have about 28,000 miles. If anyone knows a full flush method please let us know. For the time being, if anyone sees other problems with my method in addition to what I mentioned or has a better method than mine please let me and the rest of us know. Last edited by jjw2331; 03-20-2013 at 01:04 PM.. |
03-19-2013, 06:41 PM | #22 |
Rep 486
in some correspondence about radiator flushes with mike miller of roundel,he said that bmw had made it hard to do a full coolant flush on bmw's built after 2006 without extensive,and therefore expensive,disassembly,and that because of that the best you can do is drain and fill the radiator,which it looks like you have done.
hth |
