04-11-2024, 12:13 AM | #1 |
91
Rep 138
Unstable rear end while shifting and turning solution
I figured this might be helpful for a few people a few years down the line, so I lights as well put it out there!
I usually drive my car with mdm on and in DCT setting 5. And if I shift around redline while turning, the rear end seamed to wiggle and become unstable. The simple solution is go to DCT setting 4! Shifts are still just as quick, but just less violent, it almost feels like it slips the clutch a bit to make the car become less unsettled. This made a great difference on track and on backroads for me! |
04-11-2024, 12:52 AM | #2 |
Rep 1,707
no. the solution is to get solid rear subframe bushings.
04-11-2024, 07:25 AM | #3 |
Rep 4,169
Yeah you haven't really driven an E9x M3 until you've driven one with solid rear subframe bushings.
04-11-2024, 08:13 AM | #4 | |
Friends don't let friends ESS
3178
Rep 874
Drives: '11 Lemans Blue 6mt Harrop e90
Garage List 2011 E90 M3 [9.00]
2003 Porsche 911 Turbo [9.75] 2019 BMW X5 xDrive40i [0.00] 2013 Mercedes E550 ... [0.00] |
Tell us more! Just did coil overs and a set of GAS monoball front control arms with plans for diff and diff / rear subframe mounts as my next step, probably next spring. What specific benefits and drawbacks do you experience with solid subframe bushings? |
M3MATT91.00 |
04-11-2024, 08:50 AM | #5 |
Rep 4,169
A lot more chassis rigidity. You can actually feel the springs and dampers working. The chassis just feels tighter and newer. Greatly improved rear end stability. The rear end shimmy over bumps, bridge joints is gone. Rear end just feels more stable and predictable and gives you more confidence overall.
Drawbacks - none. No additional NVH. Aside from cost there is no reason not to do this mod. The E9x GTS came with solid rear subframe as did the F10 M5 and F8x M3/4. Imho the E9x M3 should have come from factory with solid rear subframe. |
04-11-2024, 09:07 AM | #6 |
Dont listen to me
796
Rep 562
The benefit of solid subframe bushings and essentially "WOT powershifting" in a turn are two completely different things. If you are in a fast DCT shift setting and you are full throttle around a fast corner and shift mid-corner, the car is going to try to chirp the tires due to the violent shift speed, which makes the car unstable and want to step out. Having solid subframe bushings does not cure this mid-corner shift instability but it does help the heavy braking stability.
Separate example: My F82 DCT with solid rear everything gets crazy loose on a race track when when I shift mid corner in the fastest shift setting. Sometimes it chirps the tires shifting into 4th gear on the street in S3 shift speed. I only ever drive the car on a race track in the middle S2 shift setting because of how rowdy the shifts are in mid-corner.
Instagram: @thatwhitem4
omgzirra_exe1512.00 CamasM3e933177.50 |
04-11-2024, 11:11 AM | #7 | |
Rep 1,707
Although I do not disagree with you, as I do use S3 in the rain religiously, I don't use anything higher. This is more to do with keeping the car stable out of corners when I am in a full WOT upshift. The rear end tends to move around too much with the standard rubber bushings, affecting everything connected to it. Upgrading to solid rear subframe bushings and upgraded diff bushings should minimize drivetrain slop and stabilize the subframe, which would make the rear end more stable in every scenario. So technically it's the combination of the subframe bushings and the diff bushings... since the diff bushing is foam... lol. Even in my S2000, I had to buy rigid collars to basically lock the subframe in place and prevent it from shifting around so much because from the factory, it had a solid 2mm gap around the bolts, which created too much instability on the track.
CamasM3e933177.50 |
04-11-2024, 11:38 AM | #8 | |
Rep 484
Planning to do MCS coilovers next year. Didn't feel like dropping $12k on the car in one year 😬 |
CamasM3e933177.50 |
04-11-2024, 12:21 PM | #9 | |
91
Rep 138
I sell CMP arms/bushings on my site. His raise the subframe up 8mm for roll center and bump steer correction. Pretty kick ass imo! |
04-11-2024, 12:24 PM | #10 |
91
Rep 138
Haha. Cars had them in for a while- the solid bushings irritated the issue slightly. The subframe use to soak up some of that “kick” but with solid it just goes right to the wheels.
My car has solid bushings in every position, along with adjustable arms in ever position. it’s a ring tool but with an interior. |
omgzirra_exe1512.00 |
04-11-2024, 12:34 PM | #11 |
Rep 973
Drives: 2012 E92 M3 DCT ZCP
Just got some installed on mine. Feels so much better...
2012 E92 M3 | ZCP | DCT | Space Grey Metallic | Black Novillo | BE/ARP | MPE V2 | AA green filter |BMW CF Rear Spoiler, RW Carbon Diffuser, CF Front Splitters | DTEC 160W Angel Eyes
M3MATT91.00 CamasM3e933177.50 |
04-11-2024, 12:34 PM | #12 | |
Rep 1,707
im in the same boat as you. everything is done minus interior.
M3MATT91.00 |
04-11-2024, 03:01 PM | #14 | |
YNWA
1048
Rep 814
Doesn't make sense to raise the subframe on e9x/e8x chassis.
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54 |
04-11-2024, 03:52 PM | #15 | |
91
Rep 138
It does the same thing with the diff too. It corrects your axle angle. It all works great! You can take a look on my site for more info on how it works. Schirmer cars use roll center and bump steer correction in subframes too. It’s fast! Heres a link! |
spammysammich1586.50 |
04-11-2024, 04:31 PM | #16 |
YNWA
1048
Rep 814
Ah how could I forget the slammed cars with ruined suspension geometry.
04-11-2024, 04:43 PM | #17 |
91
Rep 138
Not even slammed. Stock cars that go through travel often can still benefit from it. But slightly lowered cars (track spec rideheight) have the best benefit
04-11-2024, 04:50 PM | #18 |
68
Rep 119
04-11-2024, 06:08 PM | #19 |
Rep 1,707
a true Schirmer spec e9x uses a rear diff lift where they raise the diff completely to bring the whole driveline to neutral.
04-11-2024, 08:46 PM | #20 | |
91
Rep 138
I have a buddy with a Schimer car and he said it’s nothing too out of the ordinary- one car has a bladed sway bar. Rest are normal. They just have CRAZY setups and even crazier drivers |
04-11-2024, 08:48 PM | #21 | |
91
Rep 138
It keeps everything in line! While turning/compressing, or when dropped. So his bushings even have benefit on stock cars. Theres a reason I sell his stuff! He’s the only one doing it |
04-12-2024, 05:57 AM | #22 |
mTekMods
2149
Rep 2,906
I considered doing this but for my street car it just seemed like too much, I raised the car as much as my clubsports would go.
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
M3MATT91.00 |
