TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > X6 Engine / Exhaust / Drivetrain Modification
      04-11-2019, 12:28 PM   #1
mike140389
Drives: BMW X5
BMW X5 Mass Air Flow
Hi All
Hoping you can he,p me with my 2011 X5. The engine warning light is on and as per image engine is running rich.
I plan on trying to clean the MAF to see if that sorts the problem but don't know where it is.
I have attached an image of the engine and would love any help you could provide in locating it
Thanks in advance
      10-27-2019, 12:22 PM   #2
Thecastle
Drives: F10 550i
2020 BMW M340i  [0.00]
2019 RAM 3500  [0.00]
2020 BMW X3  [0.00]
2016 BMW 550i  [0.00]
2000 Ford F450 7.3l ...  [0.00]
You’ll need to get an actual bmw code scanner not a generic obd scanner to pull the bmw specific codes.
With that you’ll be able to tell if it’s bank 1 or 2. Then narrow it down to if it’s misfires, bad 02 sensor, bad injector, and etc. without that Info you’ll just be guessing. If it’s the maf, cleaning generally doesn’t work, you’ll have to replace it.
If it’s a 50i which it looks to be, here is the location part#3 https://www.realoem.com/bmw/enUS/sho...diagId=13_1272
It’s a module on your intake air filter housing. I see it in your picture It’s on the air filter housing.
xbimmers
