BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
European Auto Source (EAS)
      10-31-2020, 02:03 PM   #67
unrulyteach
unrulyteach's Avatar
Drives: 2011 335i
2011 BMW 335i  [0.00]
Originally Posted by Dubstar View Post
Originally Posted by unrulyteach View Post
Still getting the same results as i did with f series trsvc module
Tried to change the CAN bus cable on TRSVC? Maybe it's wrong..
I think it's wiring oem wire should be here Wednesday
      10-31-2020, 10:09 PM   #68
SaNGRia
SaNGRia's Avatar
997
Drives: LCI E93 M3 + F85 X5M
Did you try without the TRSVC to see are you getting any error on PDC?
I assume you already had rear PDC fitted in. And you are splitting the Canbus from there to the TRSVC. Make sure you are doing a connection while the PDC wires intertwined tightly. Cat5 cables same with canbus cables. If yours intertwined that shouldnt be an issue. Report back!
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post!
DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue,
, F85 ACC Retrofit
Dubstar15.00
      11-01-2020, 07:04 AM   #69
unrulyteach
Drives: 2011 335i
Yea when pdc isn't Sharing wires with trsvc module Pdc works fine with no errors at all, only when sharing wiring, so that's why I'm thinking it's the wiring. Will report back on Wednesday when i install wiring
SaNGRia996.50
      11-01-2020, 06:55 PM   #70
SaNGRia
SaNGRia's Avatar
997
What is this? Did you made your own socket? If so, is the other end has intertwined cable all the way to the PDC for canbus?
, F85 ACC Retrofit
      11-01-2020, 07:16 PM   #71
unrulyteach
Drives: 2011 335i
Attachment 2451339
Yes they do
      11-01-2020, 07:52 PM   #72
SaNGRia
SaNGRia's Avatar
997
Yes they do
If i was you, i would connect the canbus directly to PDC harness not like additional socket or anything
, F85 ACC Retrofit
      11-02-2020, 12:09 AM   #73
unrulyteach
Drives: 2011 335i
Yes they do
U mean tapping it?
      11-02-2020, 07:42 PM   #74
SaNGRia
SaNGRia's Avatar
997
U mean tapping it?
correct. Canbus is a very sensetive data cable you dont want any interruption!
, F85 ACC Retrofit
      11-02-2020, 10:13 PM   #75
emanmor345
Drives: 2011 335d
Wonder if I can get this in on a K line e90. I have a JBBF81 so my car is wired for kline, havent anything about jumping to jbbf3 there is a KL high version jbbf that seems to be the equivalent to a M version, but its awesome to the the OEM camera, it looks great with the pdc obstacles!
07' E90 N51 Retrofitted : $3AG, $313, $319, $322, $415, $430, $459, $464, $465, $494, $5AC, $524, $541, $609, $6VC
NBT EVO ID4 + ATM W/ carsystems adapter
LCD3, M3 DCT wheel, OSRAM CBB, LUX V8.1
      11-03-2020, 12:46 AM   #76
unrulyteach
Drives: 2011 335i
U mean tapping it?
That's what i did when i retrofitted ACC i solder it? I'm not quite sure but it's that what u did
      11-03-2020, 12:10 PM   #77
unrulyteach
Drives: 2011 335i
U mean tapping it?
So i got oem cable but it doesn't hav pins on it or ground connect, hoe did u connect power to jbe and how did u connect canbus again
      11-03-2020, 08:46 PM   #78
unrulyteach
Drives: 2011 335i
Had something to do with wiring harness. I tapped each wire just for testing purposes and it worked. Ps cam is in trunk so that's why it's dark. So just need to figure out how to draw power and were to put ground at.
      11-03-2020, 09:45 PM   #79
unrulyteach
Drives: 2011 335i
Is it just my module that sounds like a jet engine when it turns on?
      11-03-2020, 10:58 PM   #80
SaNGRia
SaNGRia's Avatar
997
It is overheating somehow. As i thought it is the Canbus cable issue. You re good now. You can connect the negative cable on the chassis somewhere such as the 2 nuts that keeps the Combox bracket in place is one of them and positive to PDC wiring harness. Then you are all set!
, F85 ACC Retrofit
      11-03-2020, 11:02 PM   #81
SaNGRia
SaNGRia's Avatar
997
i used the Pin 10 (KL15) on the fusebox with 5amp fuse and negative to chassis.
, F85 ACC Retrofit
Luxury85.50
      11-03-2020, 11:10 PM   #82
SaNGRia
SaNGRia's Avatar
997
E90s don't have kline, not even early ones. The pin for Kline is x60002 #2 (on all MSV & MSD DMEs) and you will find on the E9x they all say "not used". (hassmaschine)
What year and model your car is and what is your DME?
But if you re 100% it is Kline then you will need DCAN cuz none of the modules like PDC or TRSVC will communicare over KLine! Too slow
, F85 ACC Retrofit
      11-03-2020, 11:22 PM   #83
unrulyteach
Drives: 2011 335i
That's not a good thing any idea why it would be over heating
      11-04-2020, 12:21 AM   #84
emanmor345
Drives: 2011 335d
well yea my car does kline or dcan, but my odb port isnt wired for it
      11-04-2020, 03:46 PM   #85
unrulyteach
Drives: 2011 335i
Did u use pin 10 on the blue or black connector
      11-04-2020, 05:28 PM   #86
unrulyteach
Drives: 2011 335i
Does camera auto adjust it self? No matter what i do I'm still swing the silicone
      11-04-2020, 08:31 PM   #87
unrulyteach
Drives: 2011 335i
How did u fit handle with cam? Did u install cam afterwards
      11-04-2020, 09:28 PM   #88
SaNGRia
SaNGRia's Avatar
997
I wrote the details on the description!!!
, F85 ACC Retrofit
Dubstar15.00
m3post
