04-18-2020, 04:10 AM | #1 |
M Enthusiast
438
Rep 626
Drives: 2018 F80 M3 ZCP
18" wheel fitment question
Hoping someone out there knows the answer to this.
Found a set of new 18" TE37's meant for the Honda Civic Type R but the bolt pattern is the same at 5x120 18x9.5 +38 all around Will that fit on a F30 with a 255/40 square set up? I know the rears will fit but concerned about the front. My car is currently lowered on ST coilovers.
2018 F80 M3 ZCP - CCB - MPE - BBS RI-D - Pure Turbos Stage 2+ - 3D Design Bumper - KW Clubsport 3 Way - Cary Jordan E85 Tuned
2021 F97 X3MC 2017 F30 340i (SOLD) 2015 F82 M4 (SOLD) |
04-18-2020, 05:37 AM | #2 |
M Enthusiast
438
Rep 626
Another thought just popped in my head. Bore size. Civic Type R has a 64.1mm bore size and F30's from what I've found have 72.56
Seems that I cannot run a hubcentric ring since the F30's bore size is larger than the Type R's instead of smaller. So does that mean I will have to get it machined to the proper size?
04-18-2020, 10:56 AM | #3 |
Rep 4,380
9.5" +35 fits. I believe 9.5" +38 will fit(by a hair) but I could be wrong and you'd need a 3mm spacer up front
Yes, you'd have to rebore the centerbore. Better to get wheels with 72.56mm cb and width and offset that fit without issue. |
04-18-2020, 11:18 AM | #4 |
Rep 467
From what I've seen the "FK8 spec" TE37s are BMW 72.6 hub bore, the CTR guys all run hubcentric rings.
alohasurftoad3132.00 |
04-18-2020, 11:42 AM | #5 | |
Rep 3,748
04-18-2020, 02:46 PM | #6 | |
M Enthusiast
438
Rep 626
01-08-2024, 12:59 PM | #7 |
Rep 65
Hello, was wondering if anyone would have any information on this. I have a 2018
Bmw 330i xdrive and currently run 20” staggered set up 405m mags. With our road conditions I keep blowing tires with pot holes and need a higher profile. I’m looking to downsize to 18” and was wondering if 245/45/18 will fit. I found replica mags that are 18” 8.5 width and offset of 25. Not too familiar with these things so any help would be greatly appreciated! |
