06-24-2019, 09:26 AM | #1 |
10
Rep 22
My 328i F30 is making a weird rattle noise when accelerating at slow speeds up to around 25mph.
It's usually heard when the car passes by parked cars the sounds seems to echo off of the other cars. It's sounds like loose pieces of flimsy metal hitting each other when I press the acceleration. Anyone know what this is? Could this be something with the timing chain? Or is this a non serious issue? Thank! |
06-24-2019, 02:22 PM | #2 |
Rep 943
Drives: F30 328i Msport
does it go away when warm?
06-24-2019, 02:38 PM | #4 |
Rep 3,680
My first thought is an exhaust clamp or something along the exhaust somewhere.
Instagram: rjd_f30 | Current: EBII 2013 335i 6MT RWD & Sprint Blue 2008 Audi RS4 | Retired: 2013 328i, 2000 XTerra, 2022 Civic Si |
06-24-2019, 02:54 PM | #5 |
10
Rep 22
I don't have a custom exhaust but I'm thinking about something for it actually because the engine in the n20 sounds horrible like a tractor.
My mods are Bilstein shocks and struts and H&R Sport springs. (Don't by previous owner) I actually want a more comfortable ride lol was thinking about tasing it. |
06-24-2019, 02:55 PM | #6 | |
10
Rep 22
I made an appointment to come in when he has time next Monday. |
06-24-2019, 04:47 PM | #8 |
¯\_(ツ)_/¯
947
Rep 1,762
Exhaust pipe flap/valve in the back (search it's been discussed many many times and most likely that's it) if not the turbo wastegate.
Tensioner/belt DIY | Side skirt extension DIY
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC |
06-24-2019, 07:11 PM | #9 |
Rep 3,680
Sounds about right. Nothing to worry about, just an annoyance.
06-24-2019, 07:45 PM | #10 |
154
Rep 387
06-25-2019, 12:33 AM | #11 | |
10
Rep 22
06-27-2019, 08:37 AM | #13 |
Rep 495
I've got a funny noise like this too, it's super noticeable when driving by parked cars or a wall, it sounds sorta like an exhaust leak to me. I have a catless DP, stock MP, and Dinan axleback. So I can rule out the exhaust valve since I don't have one
07-14-2019, 07:15 PM | #14 |
Rep 2
I've got a similar problem but I have a 320i instead, so no exhaust flap in the back. Sound is coming from the engine bay.
https://www.youtube.com/watch?v=V-9t...ature=youtu.be |
07-16-2019, 01:53 PM | #15 |
Rep 4
I had a similar noise from my 428 when accelerating in gears 1-3 and it was a broken plastic guide for the emergency brake cable. $8 part but $260 to drop the driveshaft, heatshields etc to replace it. I'm glad it wasn't more serious.
07-16-2019, 05:00 PM | #16 | |
24
Rep 199
08-11-2020, 07:46 PM | #17 |
Rep 943
This is my wastegate, dont think it sounds normal, does it sound like this?
09-15-2020, 04:20 PM | #18 |
Rep 8
Hi,
Anyone have solution for this rattling ? I have f30 320i wiht n20, after replacing timing chain and both vanos units. There is strange rattling noise only when pressing throttle and it seems to come from engine bay. It happens even when only gently touching throtlle, rpms are not even increasing much, but there is rattling. And when throttle is released, it suddenly dissapear everytime. There is no any errors, car is driving completely normal, only this rattling.... |
10-15-2022, 02:25 PM | #20 |
-1
Rep 13
My 2013 f30 335i (pneumatic waste-gate) has started to make this "ticking" or "rattling" noise upon startup. It also has started making a "metallic rattling" or "metallic vibrating" noise when accelerating from a stop.
I've attached videos where you can hear the rattling upon startup and another one where you can CLEARLY hear the metallic vibration at 2k-3k rpm's when accelerating. PLEASE ADVISE if you have any ideas of what this might be. 1. Vibration/Rattling at 2k-3k RPMS when accelerating from stop: https://youtube.com/shorts/MeKYDv978a8?feature=share 2. Rattling/Clicking/Chugging noise when idling after startup: https://youtube.com/shorts/FxnBuPyQwrY?feature=share |
02-02-2024, 12:21 PM | #21 | |
Rep 1
04-11-2024, 01:52 AM | #22 |
Rep 3
Hi, hope you are well, sorry to bring up a old thread, I was wondering if you figured out the issue? I am having the exact same problem you described on my 428i and would really appreciate it if you could let me know if you solved the issue, I’ll attach a video of what mine sounds like for reference, thank you so much.
rattle sound video |
