$10 paypal if you can tell me where this plug goes!
12-07-2010, 08:08 AM | #1 |
44
Rep 210
Still need help guys. Did an Intake manifold swap. When reassembling could not for the life of me figure out where this plug goes. There is just no place to plug it in, that I can see?! My DSC light is on after the intake manifold swap, so I am assuming it is DSC related. $10 paypal to the first person that can get this plug identified, (it is directly under the throttle body) and my DSC functional again!
M Performance Suspension
12-07-2010, 08:24 AM | #3 |
Rep 12,567
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
^^ WHS
This person did the same conversion and in the 3rd pic from the top, you see what appears to be the same plug going into the back of the intake box http://www.zpost.com/forums/showthread.php?t=455180 |
12-07-2010, 08:54 AM | #4 |
Rep 1,522
I doubt it, could he even start the engine without the MAF plugged in? He only got the DSC code.
On a side note, can the same thing be done to a 328i? Where does the extra 45hp come from, I thought the N52 is maxxed out pretty much? |
12-07-2010, 09:07 AM | #6 |
General
290
Rep 28,154
most cars will run with the mass air sensor unplugged,the computer goes into a default setting when the sensor is not detected, not that they will always run perfect, it depends on the temp's and all and what the factory set the car to run with at default without the sensor
12-07-2010, 09:13 AM | #7 | |
Rep 12,567
not sure where you're getting the 45hp. if it's from the link i posted, that guy is also getting an AA tune on top of this so it'll be effectively comparing a stock 328 to a tuned 330i so he must be comparing difference in crank #s. |
12-07-2010, 09:19 AM | #8 |
Rep 560
i am almost sure that is the plug for the DISA valves motors, on 328 with stock manifold there one thats just hanging next to the manifold and when you put a 330i manifold you need to plug that in. hope this helped
ps did you get your computer reprogramed? it mihght also be a plug for the throtle but this is less posible
2016 bmw M4 YMB/SO Stock
12-07-2010, 09:20 AM | #9 | |
Rep 1,522
BTW part of the reason I doubt that was the MAF connector was because it is very very hard to miss the MAF plug |
12-07-2010, 09:50 AM | #10 |
44
Rep 210
Here is what it is not
It is not one of the plugs to the DISA motors. There are two of those type plugs and they are smaller. Both plugged in.
It is not the plug to the MAF. That one is larger, and also plugged in. It is not the plug to the Throttle body, that one is larger and plugged in. The only error on the dash is DSC disabled. So thats what I was thinking it went to...
12-07-2010, 10:03 AM | #11 | |
Rep 1,522
Do you plan to get it tuned? If so what is the estimated power gain from stock? |
12-07-2010, 10:18 AM | #12 |
Rep 12,567
06-08 z4 non-m only came in 3.0i/3.0si which would be the equiv of 328i/330i.
12-07-2010, 10:53 AM | #13 | |
44
Rep 210
The plug is plastic and not oxidized
12-07-2010, 12:23 PM | #14 |
44
Rep 210
Maybe this is it
Looks like DubbeDown, has gotten me closer. It might go here See the RED CIRCLE! I will try this spot tonight, and if DubbedDown is correct. $10.00
12-07-2010, 12:53 PM | #15 | |
Rep 1,522
12-07-2010, 01:37 PM | #16 |
44
Rep 210
Think its more like 35 HP
The price to do this is about $900 for parts
The software tune you need is at least $400.00 depending on vender. The labor to do this is a two person job, and if I had to do it again, I would let a mechanic do the work. Its a one person pain in the a$$ So if your time is free, then $1300 gives you about 35 HP
12-14-2010, 07:40 PM | #18 |
44
Rep 210
This plug goes to the Crankshaft Sensor
The E90 can run without the Crankshaft Sensor, but poorly. The car goes into default limp mode. You get a Service Engine Light, and a Brake light. Along with a DSC Malfunction code. So, my problem was that the Crankshaft Sensor plug, was not plugged in!
It plugs into the crankshaft sensor, on the crankshaft.
