Let's have a coilovers - springs - shocks discussion!
06-01-2018, 02:20 PM | #266 |
10
Rep 68
NEED ADVICE
I'm looking to buy a 2007 328i which has been lowered on blisten sport struts and H&R Race Springs 1. Before buying I would like to know if anyone else in canada is running a similar setup and how is the winter driving? I'm from montreal so our winters are pretty bad and I'm worried of getting stuck way too often. 2. Also would H&R Sport springs be a better option for daily driving including winter? (I will always be running winter tires in winter so that's not a factor) 3. Finally, I would like to know how bad is the camber with the race springs and what camber kit would you recommend to fix it? |
11-04-2018, 10:18 PM | #267 |
Rep 2
what about rear shock mounts? how much difference does it make? I saw someonline that say they never wear out and are high performance. I don't take my car on the track and it's a stock model 328xi but I want to start doing th ebest I can with what I have. thanks!
11-20-2018, 07:58 PM | #268 | |
374
Rep 317
No increase in NVH. I want to try the rear suspension mounts next |
12-07-2018, 11:52 AM | #269 | |
Rep 3,856
squaredphoto373.50 |
12-07-2018, 11:53 AM | #270 | |
Rep 3,856
12-07-2018, 12:17 PM | #271 | |
Nomore
149
Rep 793
Hows the ride been, since you've put some more time on the setup since you last posted, maybe even better now after breaking the setup in..? How are the roads in your area? Is that a concern for you personally |
12-27-2018, 06:53 PM | #272 | |
Rep 5
?? any luck
just curious how did that setup work out for you im running the same thing?? |
03-21-2019, 10:15 AM | #273 |
Rep 5
Hi there! New here
Thinking about buying these KW Coilover Variant 1 inox. The v2 might be nice to, might be a bit expensive. What kind of difference is there in mounting for all e9x chassi? Some manufactures have e90 suspension but don't fit all chassi and engine types. Is there just springs? Since i might switch to another e91 in the future. If i could use them on the next car i might go with the v3 even. (Looking for e91 manual 335i LCI but 2009 model) |
03-27-2019, 11:34 PM | #274 | |
374
Rep 317
E9X RWD and E9X XI have near similar rear suspension so you can probably mix and match components E9X RWD and E9X XI have very different front suspension and you cannot mix and match I can't comment on E9X ( non M ) and E9X M3 suspension but there is a thread that talks about compatibility of parts |
04-09-2019, 07:19 PM | #275 |
Rep 14
Coilovers Needed
Looking to swap/sell my 3p airlift kit off 2013 335is coupe Installed almost a year ago but less than 5k miles put on them...Price paid was over $3200 still very much like new. Some help ASAP
09-10-2019, 09:06 PM | #276 |
Rep 1
ISC N1 Coilovers
Is anybody here running these coil overs? What is the lowest you can actually get in the front? Pics of possibly with wheels set up. I can’t seem to get my front end to go lower than stock
09-13-2019, 01:00 PM | #277 |
Rep 3,731
Just curious.....with the factory 18" wheels on my 07' 335i.......if I drop the car an inch or so (springs or coil overs)....what's the widest tire I and fit in the rear without having to roll the fenders?
01-30-2020, 02:26 PM | #278 |
16
Rep 108
I'm looking to change my Shocks, Struts & Springs, Strut Mounts, etc.... I'm not into racing just a daily / Weekend driver... plus I'm in E93 335i Convertible ... I wouldn't gear it up to race but to go fast and handle well if that make sense.
What is the best bang for Buck in regards to improving Ride.... 2008 335i Approximately 50K miles and OEM Shock Struts springs etc... I'm looking to stay under $1000.00 Thanks in advance DSteele41 |
01-30-2020, 03:33 PM | #279 | |
eBay Special
3108
Rep 3,038
Drives: E90 330xi
Bilstein B8s if you want handling < comfort Koni FSDs are also a great choice
Common sense is a flower that does not bloom in everyone's garden
01-30-2020, 10:22 PM | #280 |
16
Rep 108
Struts Shocks vs More Tire for Bette Ride
colorado.e9x
" Bilstein B6s if you want comfort > handling Bilstein B8s if you want handling < comfort Koni FSDs are also a great choice " Did You Mean Bilstein Bs if you want Handing > comfort ? If so I see and Thank You Also Is there a Good Test to know if I need to replace the Springs along with front struts and also what other hardware should I replace like Strut Mounts etc... I'm just getting a really rough ride... some from the Struts and Shocks but also from the Low Profile Tires what is the Max Ride Height Ratio You Can go as far as getting more tire without scraping wheel wells ... Hope that make sense .. btw way I have 18" stock wheels Thanks Again Sir |
01-30-2020, 10:45 PM | #281 | |
eBay Special
3108
Rep 3,038
Drives: E90 330xi
When I was riding on my original struts/shocks that were blown I often hit the bump stops on good sized potholes, had horrible body roll, and each time I hit a bump (tar filling, pothole, etc) theyd make a hydraulic hissing sound. When I finally replaced them, much like Justin Buice's video, the originals did not come back up when compressed where as the new shocks came back up almost instantly. Your current springs should be fine unless you want to go lower, I don't believe they wear out like the shocks or struts do. I would replace all shock mounts, front and rear (bottom) with OE and upgrade the rear (top) mounts with Dinan or Monroe. The upgrade helps it be less bouncy or floaty from what I've noticed. Spring pads, and top hats were fine on my car so I returned the new ones I ordered, though Id reccommend you get them just in case. You can always return anything you dont need if they look good already There's plenty of threads on different tire/wheel setups you can run on the wheels subforum, I'd search there first. Good luck!
01-31-2020, 12:55 PM | #282 |
16
Rep 108
colorado.e9x
Great Great Info....I will replace the Shocks and Struts as far as the Mounts, etc.. you suggested ; Can I get everything from one place (Best Price of Course) ? Thanks for the list of additional parts too Because If Your going to do all that work might as well replace all the parts you can within reasonable price. Thanks Again DSteele41 |
colorado.e9x3107.50 |
01-31-2020, 01:49 PM | #283 | |
eBay Special
3108
Rep 3,038
Drives: E90 330xi
01-31-2020, 06:54 PM | #284 |
Rep 6,968
Drives: 2007 Black/Black 335i e90
If you value comfort vs handling buy a Buick or Cadillac LOL 😂
In all seriousness, I think stock shocks & struts & or Koni FSD's |
03-20-2020, 04:29 PM | #285 |
Rep 5
Bilstein B12 Pro Kit
Does anyone have experience with this Bilstein/Eibach kit? Just picked up a 2011 335i coupe, RWD, 19" wheels. I've got a track car so while handling is important, I want some comfort as well. Any help on preloading suspension during installation? Thanks.
12-12-2020, 06:04 PM | #286 |
Rep 1
BMW 328i e93
Hello, i'm posting this for some help.
I hit a pothole on both of my passenger tires and front tire is bent but the passenger side is lower than the drivers side. Not sure if it's a suspension issue or something but if anybody can help me out on this i would appreciate it thanks so much. |
