      04-23-2010, 05:25 PM   #1
EAS
EAS's Avatar
549
Drives: VF620 M3
▀▄ eas | DIY: Macht Schnell - Competition Stud Conversion Kit Installation
Step 1
Jack up the vehicle and secure it on jackstands.Unbolt the lug bolts.
Step 2
Remove wheel from hub.
Step 3
Remove wheel and clean hub of all dirt and/or surface rush with a wire wheel to ensure a clean and flush surface. [optional]
Step 4
Apply loctite onto the end of the studs and hand tighten the studs onto the hub.
Step 5
Use an allen wrench to completely tighten the studs onto the hub.
Step 6
Put your wheel back on and torque down the wheel locks. Repeat for the other three wheels.
This is how it will look finished without the wheel on it yet(also has a spacer on it)
Enjoy!
      04-23-2010, 11:22 PM   #2
SlickShift
SlickShift's Avatar
325
Drives: '11 BMW E90 M3 ZCP, '21 X5 ZMP
Very nice! Surely makes changing wheels a lot easier!
-Nick
2018 BMW 440i - M Sport, Exec
Glacier Silver Metallic/Coral Red Dakota
Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i
      04-26-2010, 12:20 PM   #3
EAS
EAS's Avatar
549
Drives: VF620 M3
It sure does! In regards to torque specification, it is the same as the lugs torque spec. You can do this ahead of time or as you torque down your lugs onto the studs
      05-03-2010, 11:03 AM   #4
Castr_85M
Castr_85M's Avatar
55
Drives: AW/Fox 6MT E90 M3
How big of a spacer can be ran with this setup? I'm looking into the Macht Shnell Kit 18/12mm spacers Will this be safe for DD usage?
      05-03-2010, 12:46 PM   #5
EAS
EAS's Avatar
549
Drives: VF620 M3
You can run up to a 12mm spacer on the studs. 18mm won't work with these.
