Coding performance brakes
04-26-2017, 03:58 AM | #67 |
Rep 1,600
ISTA/D has the guide on what to do. Service Functions > Chassis > Traction Control. Open up the FUB and it will tell you what you need to do, in what order.
I've already left work for the day sorry |
10-03-2018, 07:34 AM | #68 |
Rep 420
hi,
i've put caliper m4 serie F on my e92 335i , with brembo disc 370mm. all is plug & play for front... my question it is necessary to code it ? with SPBR etc....? else brake master cylinder for e92 335i is reference --> 34336785664 maybe it will be better to put brake master cylinder e92 m3 with reference --> 34312283533 one picture
335i Pack M Stage 2 BR Performance 403,5 hp 582n.m/Bilstein B14 pss/R&B PVC2 valve/K&N air filter/Spearco FMIC/pre cata empty/EBC Redstuff,aviation hose, BMW Performance exhaust, Charge pipe Evolution Racewerks, Forge DVs
10-03-2018, 03:15 PM | #69 | |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
feuer4275.50 |
10-03-2018, 03:19 PM | #70 |
Rep 1,815
some people do need coding but no one knows why. Some need it and some don't.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
10-03-2018, 03:19 PM | #71 |
Rep 420
10-03-2018, 03:20 PM | #72 |
Rep 420
10-03-2018, 03:57 PM | #73 |
Sua Sponte
1299
Rep 2,850
Sport brakes were never a 335i option so while you may be able to change the VO I dont think it will change the bias, etc. like it does on a 328i where a difference was made. I've never compared the 328 and 335 DSC software. I'd have to see a 328 and 335 DSC TRC file pre and post SPBR VO addition and compare them to be convinced that it makes a difference in the 335. I ran the 370mm up front for a few months before I added the rears and the M3 MC and it was fine.
feuer4275.50 |
10-03-2018, 04:02 PM | #74 |
Sua Sponte
1299
Rep 2,850
+SPBR was never a VO option for 335i's. So while you may be able to add the option to your VO, your DSC software may not recognize it or it may not make any changes. One way to know for sure it to save the TRC file of your car. change the VO, default code the appropriate modules, save the new TRC file and compare them.
feuer4275.50 |
10-05-2018, 08:21 AM | #75 |
Rep 420
Peope in UK where i bought m4 caliper said.
I would recommend having the system bleed properly via abs pump. I had the same issue on my e91 last year when I fitted these, I was going crazy and was also looking for m3 master cyl, because after I bled it 3 times the pedal was still sinking. I then did some research and decided to give it another go and bleed it again via abs pump and problem solved.
feuer4275.50 |
10-05-2018, 12:42 PM | #76 |
Rep 1,815
Sorry, I didn't catch the 335i part. On a 335i I don't think coding is needed or would do anything. On a 328i you would feel a loss of stability when braking. My wife's car shifted side to side almost like jerking the steering wheel back and fort on a straight road when braking hard.
07-25-2019, 03:01 AM | #77 | |
87
Rep 236
Drives: e92 335iA
I had run into this very same issue when going from e36 328i rear brakes to e36 M3 brakes... it has worked perfectly.
"If everything seems under control, you're not going fast enough.” Mario Andretti
09-03-2020, 03:55 AM | #78 |
Rep 29
Let me revive this thread; on German aftersales sites Leebmann24 and AfterSales, they do not offer the performance brakes for 330i and 335i.
Is this because the coding is non-existent? Maybe because the brakes are already calculated for this bias, and DSC as well? So to speak, the existing cylinder surface is big enough to cover for "upgraded" 6-piston front and 4-piston rear calipers?
E92 330i N52K 200kW (EU)
09-03-2020, 01:51 PM | #79 | |
Rep 1,815
09-03-2020, 01:53 PM | #80 | |
626
Rep 2,099
Rears are a little different story, but because of the bias, the difference may not be significant unless you are doing the M3/M4 upgrade or the 380/370 upgrade. On the other hand, the brakes (esp on a pre-lci) for the 328i have a significant jump in pistons on both ends and disc size. So you could see where it could potentially benefit from coding. |
09-04-2020, 05:01 AM | #81 | |
Rep 29
09-04-2020, 02:50 PM | #82 |
Rep 1,815
that is what I believe. 335i brakes on a 328i is a winning combo.
02-21-2021, 12:37 PM | #83 |
Rep 720
Sorry to revive a thread, I'm after opinions from anyone who has put 335i brakes on 320
I have done the rears already and have the fronts to fit next week, so far the brake pedal feels less responsive, although its brand new discs and pads with no more than 10 miles so far. To be honest its nearly two months since I last drove the car and I've driven others in between so I really can't say I'm doing a fair comparison. I've gone to 336 on the back from 300 and the front will be 348 from 312 (I think). That is to say, opinions on whether to code SPBR. I already read the trace from DSC and there is not a nice obvious option for sport brakes/not sport brakes. I plan to decode a 335i vin to be certain SPBR is enabled from factory for the standard brakes. |
02-21-2021, 03:20 PM | #84 | |
Rep 1,815
02-21-2021, 03:57 PM | #85 | |
Rep 720
I had to test the rears before the fronts really as I had to make and install spacer rings for my smaller handbrake shoes. I was concerned the heat from brazing may have warped the discs. I didn't want to over complicate the results by having 2 new sets of brakes at once (the larger front discs are used and as such an unknown quantity in terms of quality). Question, how does the pedal feel alter by coding in normal driving situations. Does my MK60 DSC incorporate a precharge circuit? |
02-22-2021, 02:40 PM | #86 | |
Rep 1,815
That I do not know.
02-22-2021, 02:56 PM | #87 |
Rep 720
Sorry you missunderstood me, I meant to ask how can coding change pedal feel when as I understand it the feel is a function of master cylinder and servo assistance, at least until the ABS is required to function as in a lock up situation.
Though your second statement essentially negates my question. Thanks |
