BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > Bad fuel rail pressure sensor?
ARMA SPEED
      04-10-2024, 08:09 AM   #1
armend195
Drives: '12 F20 120d M Performance Pkg
Hello
Looked around the net and could not find a definitive answer.
When reading fuel rail pressure live data on idle the values go up and down sporadically between 27000-30000 kPa (270-300 bar).
Is this normal or should the value be at a stable number?
MAF sensor seems to follow the pattern as it also jumps from 10-25 g/sec.
Car feels as if low boost or lower power on low rpms.
Stage 2 with DPF removed.
I assume that it is not remap related as the car has been working fine after remap, but these issues started recently.
MAP, MAF, IAT sensor cleaned no difference.
No boost leaks, smoke test done.
Thanks
2010 118d Stage 2 220hp & 340 nm
2018 320d Stage 1 235 hp & 460 nm
      04-20-2024, 03:51 PM   #2
barf
Drives: F30 330D
Should be stable and shouldn't bounce. Probably bad sensor or quantity control valve on fuel pump, more rarely caused by pressure control valve on the rail.
      04-26-2024, 09:09 AM   #3
armend195
The n47 has a quantity control valve and a pressure sensor on the rail. Do you know how to troubleshoot this and single out the failing part. The quantity control valve is an expensive item.
edit:
Sorry i was misinformed. There indeed is a pressure regulator and pressure sensor on the rail.
The quantity control valve is on the pump.
      04-30-2024, 07:48 AM   #4
armend195
I unplugged the pressure sensor, car did not start. While cranking, the rpm slowly started to rise from 200 rpm but it did not feel good to keep cranking it so i stopped and pluggef the fuel rail pressure sensor back in. The first minute the car felt completely different like full power from 1000 rpm then it slowly went back to its old behaviour.
What could cause that? Maybe when cranking it with sensor unplugged there was a raise in pressure that made the car feel more powerful the first minute?
Or maybe the car ran good until the fuel rail pressure sensor values started to differentiate?
Thankful for any input.
      04-30-2024, 07:50 AM   #5
armend195
Is there any sensor i can unplug to see if the pressure normalizes? For example unplugging the pressure regulator and see if the pressure is stable or if there is a difference?
fuel, fuel rail, pressure, rail pressure, sensor
