03-22-2018, 12:46 AM | #23 |
Rep 1,827
Anyone else with having issues with launch control post-flash? I wanted to do a couple launches the other day, and launch control wouldn't activate (I put the car in Sport+, stood on the brake, and mashed the gas beyond the kickdown point). I've done it once or twice before I flashed it, but now it won't engage.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
03-22-2018, 07:42 AM | #24 | |
Rep 1,206
03-22-2018, 08:27 AM | #25 | ||
Rep 1,827
03-22-2018, 02:38 PM | #26 | |
Rep 832
Drives: 2019 G01 X3
03-22-2018, 02:54 PM | #27 |
Rep 1,827
Yes, drove home after work (36 miles) and tried it around there. I'm 85% sure it has to do with the tune. Either the coding for LC was altered, or (idk if this makes sense or not, just hypothesizing) the added torque triggers it to disable? I've emailed Nic from AA to see if he can look into the coding.
03-23-2018, 11:58 AM | #28 | |
Rep 1,348
How does the car feel power wise and what stage?
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 |
03-23-2018, 12:13 PM | #29 | ||
Rep 1,827
Car feels great! Power and torque are definitely STRONG. I broke traction getting on an on ramp at 45mph in 4th gear last night and the stock iDrive Sport Displays for hp & torque maxed out (max range is 320 for each). Way faster all around, and super smooth delivery. AA didn't really designate a "stage" number for my map, but I'm guessing it's basically a stage 2. Cat delete for c/l downpipe, cold start delete, burble, 91oct (Cali living ...no fmic...yet. Haha. Waiting on an E30 map.
ceedawg467.50 |
03-23-2018, 12:21 PM | #30 | |
Rep 3,034
Drives: 2019 M2 Competition
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
TMac335i68.00 |
03-23-2018, 02:25 PM | #31 |
Rep 1,827
Already did! Just waiting on the new files from Nic.
BMW DIY Guy3090.00 |
03-23-2018, 10:31 PM | #32 | |
335i F30
68
Rep 252
13' F30 335i Mineral White Metallic
Sport Package | 19" Rotiform SPF | BC Coilovers Coral Red Interior | H/K Package Active Autowerke Flash Tune, FMIC, Exhaust | BMS Intake | VRSF DP | VRSF CP |
03-23-2018, 11:19 PM | #33 |
Rep 5,776
Can you run e85 with that tune and does it make a difference? With JB4 and flex fuel wires it is a definite HP increase.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
03-24-2018, 07:33 AM | #34 | |
335i F30
68
Rep 252
03-24-2018, 02:16 PM | #35 |
24350
Rep 191,156
Yes you can run E85, just let them know so they can send you an E85 map.
TMac335i68.00 |
03-29-2018, 08:56 AM | #36 |
Rep 603
Successfully flashed the car with the AA Stage 1 file last night after experiencing some problems at the first try last weekend.
What happend was, that I got an error trying to flash the car with the "large" Stage 1 file that I received from AA. It dropped an error on the iFlash program after selecting the file and didn't start to upload. However I could flash the ECU with the large new Stock file I also received. Nic from AA then sent me a new "small" Stage 1 file, which I could then successfully flash over the new Stock tune. Flashing the large file took about 10 minutes (charger hooked up) Flashing the small file took about 1 minute. The car then shows a limp mode warning, which I was told was normal, but as I didn't know before, this kind of put me into "shit, what happens?" mode for a moment! After the ECU flash you need to restore the coding database which takes another minute or so. After that, limp mode warning went off. And I my heartbeat and adrenaline level went back to normal. Basically, I just followed 1:1 the easy and clear PDF instructions I got from AA! Took the car for a short test drive and are pleased with the results. As the engine was cold I didn't push, but can for sure feel how much more torque there is. I did some pulls on the road before the AA flash and will repeat that at asap and then share with you the M Performance Driver App graphs later. So far it feels powerful, but let the numbers talk! :-)
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
TMac335i68.00 |
03-29-2018, 08:58 AM | #37 | |
335i F30
68
Rep 252
03-29-2018, 10:51 AM | #38 |
Rep 1,348
Please dyno and post ,the masses are waiting to see the numbers,you cannot imagine!
03-31-2018, 11:19 PM | #39 |
Rep 3,034
Here you go guys.. my summary analysis is up from my 3/31 dyno run:
http://f30.bimmerpost.com/forums/sho...0&postcount=70
TMac335i68.00 |
04-02-2018, 07:38 PM | #40 | |
335i F30
68
Rep 252
04-02-2018, 11:19 PM | #41 |
Rep 3,034
Bolt ons: CTS Turbo CAI, AA FMIC, AA CP, AA exhaust, Ignition Projects ignition coils (with new stock Bosch plugs), 3.5bar TMAP plus matching tune changes for that, GFB DV+ and of course the AA ECU tune, running 92 octane fuel.
TMac335i68.00 |
04-13-2018, 09:05 PM | #42 |
Rep 3,034
Nic of AA sent me my latest tweaked build for my car, and I got it flashed this afternoon.
I was able to get 4 logged runs this evening, including a long 4th run before I ran out of time and road. Incredibly responsive, DSC light in 2nd and 3rd, and even tail end wiggle in 4th gear. Just amazing.. new turbo PSI record of 18.7lbs peak! My cat temp peak was 1601, so not climbing any higher which is good.
04-13-2018, 09:37 PM | #43 | |
Rep 1,206
That’s a lot of boost for a stage 1 car. Is it a boost spike on tip in or is that what u getting as your Rpms rise. Car should be very fast at that psi if it’s not simply a spike. |
04-13-2018, 09:38 PM | #44 |
Rep 3,034
50f and rainy slimy roads. 8)
