BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY Paddle Shift F30
GetBMWParts
      10-11-2016, 11:46 AM   #45
thatg20guy
thatg20guy's Avatar
Drives: 2021 M340i
Originally Posted by Blacktan View Post
If your car production date is up to mid 13's i am afraid that you aren'tprewired ...
My car is a March 2015 production date - am I pre-wired? I coded the paddles portion in FEM to aktiv but nothing works still
      10-11-2016, 01:20 PM   #46
Blacktan
Blacktan's Avatar
Greece
49
Drives: BMW f32 428i mpack
Very strange if your car is 15's producted ..
I bet on it that is prewired !
Maybe this is a dumb question but are you sure that you connected properly the fuse of steering wheel's paddles to the pin connector of the car ?
      10-16-2016, 07:37 PM   #47
gyrotuner
Drives: 320i
My car is also a 15- and no pre-wire.
Also still having the issues with the stock wheel back on, any ideas?
      10-29-2016, 12:04 PM   #48
BMWtight2me
87
Drives: 320ayayay...
Originally Posted by mokorx View Post
Link below is my documented of DIY paddle shifter that I installed on my BMW F30 316i. Other folk has done the installation before, but I have not been able to find a complete detail step and information related to paddle shift.
Hope that this DIY will save time to the folk that want to install since all the information is in one place.
Thanks to all the DIYer that do this before me.
View
http://www.mediafire.com/view/m33a3n...30_Rev._3L.pdf
Download
http://www.mediafire.com/download/m3...30+Rev.+3L.pdf
Amazing -- thanks! Does it matter that it is a different style steering wheel in the guide (I have the m Sport wheel)? Is it the same parts and wiring? Looks like I may need an additional wiring harness? I only have the wheel, bag, and a small 4 inch cord.
Thanks again -- appreciate the help.
      10-29-2016, 08:53 PM   #49
BMWMPR
BMWMPR's Avatar
Puerto Rico
77
Drives: 2016 LCI F80
You will need the paddle shifters, the steering wheel back cover, and a new wiring harness to connect the paddles.
      10-29-2016, 09:07 PM   #50
BMWtight2me
87
Fantastic. Thank you BMWMPR. Do you happen to know the part number on the wiring harness? Is it the same across 320i/28i/35i? I think I have the back cover already... but if you have that number as well, that would help. I'm going to look on real oem right now to try to figure it out. Appreciate the help.
      10-29-2016, 09:21 PM   #51
BMWtight2me
87
I just went on realoem.com and found the 320i parts breakdown. I believe this is the correct version for me: http://www.realoem.com/bmw/enUS/show...diagId=32_2169
Looks like I need part 5, the wiring harness for the wheel.
Is there an official guide for installation?
      10-29-2016, 09:28 PM   #52
BMWMPR
BMWMPR's Avatar
Puerto Rico
77
Back cover PN - 32307848268
Wiring harness PNs -
32307848337 - if your car has steering wheel heater, and/or lane departure/lane change warning
32307848335 - if your car doesn't have any of the above
I have for sale the paddles, the back cover, and the harness. If you are interested, let me know.
      11-01-2016, 03:46 PM   #53
zcspec
zcspec's Avatar
214
Drives: 911/Boxster/Model Y
First off, thanks OP for putting together a DIY. I have a 2014 M Sport with the M Performance Steering Wheel type II. The issue is, the left paddle shifter is loose/has play unlike the right shifter. My F30 is still under warranty so I had the dealership inspect it. They told me that the previous owner, most likely installed the wheel/paddle shifters so they would not cover the repair/adjustment. Do any of you know if the removable process of the Type II wheel would be the same? I'd like to inspect the wheel and see if I could simply tighten the left paddle shifter as my it's driving my OCD crazy.
      01-11-2017, 11:02 PM   #54
cmbj3000
Drives: F30
Paddle shifters
Can anyone record it while they are doing it if possible
i have a 2013 328 sport line NO Paddles and that's one of the thins i miss about my E92 " Paddles and Heated Steering"
      02-14-2017, 11:54 AM   #55
madmortar
Drives: 2013 BMW 328i M-Sport
Anyone on here that installed the paddles and had to re-wire and run to the FEM care to comment/help?
I have a buddy who is in the process of the install (I will be installing paddles myself in a few weeks) and we are running into a snag.
Paddles are installed and car is coded but the paddles wont work.
Looks like 2 wires are required for the install but per the DIY PDF, it looks like just one wire is run from the A83*2B PIN#3 (in SW) to the A173*7B Pin#5 (In FEM) correct? So what is the second wire used for? The wire isn’t long enough to go from SW on drivers side to FEM on passenger side so do I assume 2 wires are needed to be joined to make the distance?
Any advice or better step by step instructions would be greatly appreciated!
      02-21-2017, 03:03 PM   #56
madmortar
Did the paddle retrofit over the weekend, details on my thread! Page 3
http://f30.bimmerpost.com/forums/sho....php?t=1304793
      08-15-2017, 07:09 PM   #57
Icon5585
Drives: 2022 m340i
So, if I'm reading this thread correctly, most 2014+ sport lines are pre-wired for paddle shifters???
      08-16-2017, 05:06 AM   #58
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
Drives: BMW 316d, BMW F40 116d
Yes
I can confirm on my F30 316d 2014.
2013+ have them already prewired.
      08-19-2017, 03:32 PM   #59
zole2112
Modder of everything I own
zole2112's Avatar
147
Drives: 2013 335i Xdrive
Shit, mine is pre-wired as well apparently, 2013 335xi F30 build date 12/12. I was kind of shocked thinking what the hell?? Both pin #3 on plug A83*2B at the steering wheel and pin #5 on plug A172*7B at the FEM are occupied with a green/yellow wire. My car came with the luxury and sport pkg (not the M). Glad to see others are prewired but have no paddles, I was kind of freaked out for a bit thinking I was looking at it wrong. On to coding now!
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
      08-19-2017, 05:20 PM   #60
omglol
Drives: F31
Could somebody that has a multimeter measure the resistance of + and - paddles when they are engaged? This would really help me a lot to solve my problem. Thanks!
      08-20-2017, 07:12 AM   #61
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
I changed my steering wheel to, but did not disconnect the battery.
After 2 months no problem at all.
Just don't push on start/stop and see if everything is off.
      09-19-2017, 06:12 AM   #62
madmortar
Great video to help those out still thinking about this mod
      10-27-2017, 08:25 PM   #63
TK335iMSPT
TK335iMSPT's Avatar
Drives: F30 335ixdrive M Sport
Sorry if I'm not understanding correctly but what is the easiest way to check If my car is pre wired for the paddles. I have a MY 2014 built in February of 2014. It's an M Sport. Thank you!
      12-10-2017, 08:41 AM   #64
Kailec
Kailec's Avatar
595
Drives: 2013 328i xDrive
Hey all, I finally installed my new M Sport steering wheel today! Only thing is, after enabling the paddle shifters through coding, both paddles only shift up. I did the following coding after installing the wheel:
PADDLE_VERBAUT from nicht aktiv to aktiv
Does anyone know what the issue is? I'm going to assume it's a wiring issue but if anyone can confirm and how to fix it I'd appreciate it.
      12-11-2017, 04:43 PM   #65
omglol
Drives: F31
I have EXACTLY the same problem.
      05-14-2018, 08:05 PM   #66
TMac335i
335i F30
TMac335i's Avatar
Drives: 2013 F30
I am figuring out which wire goes to which paddle shifter. I also heard that the shorter one goes to the side furthest away which makes zero sense to me. You would think BMW would label them. I'll let you know once I code the paddles and figure out if they work or not. Right now I have them as the longer side hooked up to the furthest paddle.
The real question I have is the lane assist. I am now getting a lane assist malfunction and that feature no longer works. Could I have the incorrect wire harness or will this go away once I code the shifters. It's strange because everything is hooked up but I have two connections just tucked away because the paddle shifter harness replaced them. Harness part number 32-30-6-854-769 and I couldn't find another harness for lane assist just a heated feature which I don't have.
Can anyone weigh in on this?
I have the non M sport wheel
13' F30 335i Mineral White Metallic
Sport Package | 19" Rotiform SPF | BC Coilovers
Coral Red Interior | H/K Package
Active Autowerke Flash Tune, FMIC, Exhaust | BMS Intake | VRSF DP | VRSF CP
