The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Modify OEM exhaust to sound like PE exhaust
      09-03-2012, 09:18 AM   #1
elim11
Drives: e90m3
I got some inspiration from the M3 guys who are modifying the stock exhausts to become more aggressive sounding. http://www.m3post.com/forums/showthread.php?t=720030
Anyone know what the differences are between the stock 335i exhaust and the BMW performance exhaust? Both seem like the use the same muffler housing dimensionally. I'm guessing the internal baffling and insulation is different, but by how much.
It would be awesome if we could just modify our stock exhausts for a couple bones and achieve a PE-type tone and sound. I'm sure it would be VERY popular. It might be wishful thinking, but I figure I throw it out there.
(Not interested in the catless DP + stock, or the golf tee mod sounds.)
EDIT(thanks to Secretsquirrel):
Background
Elim11 started this thread to inquire about emulating the mod that many M3 owners use to modify their stock exhausts in order to achieve a PE-type sound. After the contributions of many members, we’ve finally got a similar sound with savings of about $1000!
This write-up was created to keep people from having to sift through the mountain of information contained within this thread. Elim11 has moved on to another vehicle and doesn’t frequent this this forum often. So, please feel free to direct your questions towards SecretSquirrel or others who’ve shown willingness to answer questions. But please, read this overview thoroughly before doing so. I’d like to not duplicate the effort if it’s already here.
Special credit: apjr09, Ripley, Glowin, WhiteFury, SecretSquirrel and many others who’ve contributed to this. I apologize if I missed someone. This was a group effort and we appreciate everyone who devoted their time for the community.
Process
Those with N54's can reproduce the sound I have by:
1. Replacing resonator with X pipe (if you have an e90. e92's don't have a resonator). A 2.5” stainless Xpipe will work. Check question 2 in the FAQ for a link if you’re lazy. 
2. Replacing both outside perforated pipes with solid pipes. The driver side muffler will have an internal muffler resonator. Chop that crap off and replace with solid pipe. See the first image for a pic of the internal muffler resonator
3. Don't remove any packing. As WhiteFury mentioned, no sound should be coming out of the areas with solid piping anyway, but it will likely absorb "ambient" (unwanted) noise from the muffler.
4. DownPipes
Pictures for illustrating the process to your exhaust shop.
What the exhaust looks like when the mufflers are cut open.
Credit, Unsure. Please let me know who you are so I can credit you appropriately
What the exhaust looks like once the perforated section and internal muffler resonator is cut and ready to be replaced with solid 2.5” pipe. *Please note that the internal muffler resonator is different than the resonator on the e90 that sits about 18” before the mufflers.
Credit. Javy, post 852 http://www.e90post.com/forums/showpo...&postcount=852
What the exhaust will look like once it has been modified and is ready to have the packing replaced and welded shut.
Videos
1. WOT video
Ripley, http://www.e90post.com/forums/showth...0#post15086160
2. Start up, rev and slow driving
SecretSquirrel, Post 968 http://www.e90post.com/forums/showpo...&postcount=968
FAQs
1. Q. How much labor does the mod cost?
A. You can count on the mod costing anywhere from $250 to $400. A quick estimate of labor time: muffler mod (2 hours), Xpipe install (45min), new tip installation (30 minutes).
Note: The Xpipe requires 8-12 inches of 2.5”piping in order to gradually flow into the exhaust. Just suggest that they use scrap metal for this as any exhaust shop will have tons of 2.5” piping laying around.
2. Q. How much for parts?
A. The Xpipe should cost you around $40. Make sure it is 2.5” and stainless.
Note: Don’t show up to an exhaust shop without your parts. They will attempt to sell you a Magnaflow xpipe for 100-125. Get this one for about 40 shipped. http://cgi.ebay.com/ws/eBayISAPI.dll...m=151258323391
Tips should cost you $70-150. Check out Cyba or Dimisa, but any 2.5” inlet tip will work. I used the 2.5” inlet, 4” tip at http://www.autoanything.com/exhausts...ed-exhaust-tip. Just make sure the shop welds them with the name pointed down.
3. Q. Is it loud?
A. No, the mod is not loud (with or without DPs). The normal driving volume is about as loud as the exhaust on an Infiniti FX. It also has a very similar “rhythm”. The great thing about the exhaust is its ability to be louder when wanted, but quiet enough that you can conduct a teleconference while driving on the highway. But you can also make it loud enough so that everyone every one notices you by giving it light throttle presses.
4. Q. Any drone?
A. No, there is absolutely no drone with or without catless DPs.
5. Q. Is the Xpipe necessary for the e92?
A. The e92 already has an Xpipe, whereas the e90 has a resonator. Therefore, e92 owners don’t need to install an Xpipe.
6. Q. Is it necessary to replace all the packing?
A. I don’t know if it’s necessary, but IMO it’s a good idea to do as it should absorb some of the sound that circulates within the exhaust. Some have experimented with removing different amounts of packing, or removing packing from one side of the exhaust with varying results. Removing packing seems to have a limited upside at this point.
      09-03-2012, 09:21 AM   #2
benzy89
Drives: '08 E90 335i
2008 BMW 335i  [7.50]
PM/Call/Email AutoCouture Motoring (Fair Lawn, NJ) -- They basically started the OEM M3 exhaust mod & would be the most informed about if this could be done for an N54
      09-03-2012, 11:40 AM   #3
tmo24
tmo24's Avatar
Drives: 2007 BMW 335i e92
It sounds to me like the m3 mod is just cutting out the internal silencer and replacing it with a straight pipe. I wonder how different this would sound on a 335i doing a straight pipe internally vs doing a muffler delete. The difference would be that there would still be a connecting pipe between the two mufflers and there would still be a flap. I can't load the pic from my phone but search "335i exhaust cut open" in google images, there is an image that will make this make sense. It would be awesome if someone would try it to see how close it sounds to the PE.
2007 335i Jet Black e92 6AT - VRSF Full street exhaust DP, Chargepipe 7.5 FMIC, MHD, XHP, Koni orange/Eibachs, some other stuff
2007 335i Jet Black e90 6MT - Eibachs, magnaflow exhaust, carbon hood, short shift kit, some other random stuff - being sold somewhere sometime soon probably
2010 335i AW e90 6 AT Msport - The GF took this one over... JB4, PE exhaust, Koni yellows/Eibachs, pink badges, fuzzy steering wheel cover ?
      09-03-2012, 11:44 AM   #4
Hisam135i
Hisam135i's Avatar
Drives: 335i
I'd be supper interested in this!
2008 Monaco Blue 335i | Terracotta | Premium | Auto | Comfort Access | Matte-black Grills | Carbon Fiber Splitters | 20% Tint | 1- point E9x Picture Game | Staggered 19' VMR V701 | Legal Disclaimer: My posts on this website cannot be held against me in any issues, such as warranty claims. |
      09-03-2012, 12:17 PM   #5
sickem
Freude am fahren
sickem's Avatar
71
Drives: E90 N54
+1. They have a method of modifying the mufflers and bypassing the silencing in the setup while keeping the stock look. I was just discussing this with them the other day. About 1/3 the price of BMW PE.
Cobb E40 PROtune by Jake@PTF/RR catless DPs/aFe DCI/ETS 5" FMIC/ER CP/Forge DVs/Alpina B3 TCU flash/BMW Perf. Exhaust./BMW Performance Style 313s/M-Tech Rear
      09-03-2012, 02:38 PM   #6
Beemw335
62
Drives: 335i
Pe, 335( is) and oem all have the same muffler box, so the sound difference comes from packing inside and how much of the perforated pipe is covered up.
Whoever has a pe and doesnt mind cutting it open will do all of us a favor since we could then see what to do to ours in order to make it sound alike.
      09-03-2012, 06:16 PM   #7
Zebra99
Zebra99's Avatar
112
Drives: 2011 335is E93
I highly doubt anyone who just bought a PE would want to cut theirs open lol....
I'm sure there is a better way to figure out the internals of the PE. Anyone have access to specs/design graphs or internal maps for this purpose?
      09-03-2012, 06:33 PM   #8
Beemw335
62
Drives: 335i
Ohh cmon someone has to take one for the team
      09-03-2012, 07:37 PM   #9
zeenon53
zeenon53's Avatar
39
Drives: BMW
Maybe we should set up a community kitty for someone to open up their PE so it's worth their while.
2016 340i xdrive
2009 335i
      09-10-2012, 06:41 AM   #10
wahooooman
wahooooman's Avatar
Drives: 2010 Atlantis M3
just came across this, inside of Stock muffler
at the bottom of the post !
http://www.e90post.com/forums/showth...muffler+delete
07 e90 335xi- Sold, 09 X5- Sold, 12 e92 335 xdrive - Sold 11 e92 M3- Sold, 15 M235-Sold,07 e90 335xi (current daily), 10 Atlantis e92 M3 (current) Way to many mods to list
      09-10-2012, 10:45 PM   #11
DEVN335
DEVN335's Avatar
Drives: 2015 F30 335
How is this coming along? I want to know how this is gonna turn out
      09-11-2012, 07:34 PM   #12
Zebra99
Zebra99's Avatar
112
I just replied in the above topic to see if that member can provide some further insight. It looks like there is a Y-pipe connection at the end of the resonator. If that resonator could be cut and made into a straight pipe, I can almost guarantee that would amplify sound. Or, you can cut the mid pipe that connects the mufflers, but it seems that might cause chocking if you have the flap still and aren't running golf-t mod or canflap open on a JB4.
We need some more experts to chime in on this, but it looks like we're going to crack this soon and PE sales will be Nil in the near future lol
      09-11-2012, 07:40 PM   #13
Brey335i
Drives: e46 ///M3
I have an extra e92 335i muffler (muffler only) that I'd be happy to donate to the cause if anyone wants to cut theirs and experiment without modifying their only muffler if something goes wrong.
      09-12-2012, 12:25 PM   #14
elim11
Drives: e90m3
My guess, and its only a guess, is that the PE has reduced amount of insulated packing material and probably a straight or a straight + perforated pipe in place of the large resonator.
Only one way to find out...anyone with PE willing to be guinea pig?
      09-12-2012, 01:34 PM   #15
Beemw335
62
Drives: 335i
Ive seen pics of the stock muffler cut open, but thats useless, what we really need is a pi of the performance exhaust.
If anyone with a pe ever gets rear ended and has a damaged muffler than it would be perfect to cut open.
      09-12-2012, 02:28 PM   #16
Randomaccess335
Randomaccess335's Avatar
69
Drives: 07' 335I
Looks to me if you cut the baffle out of oem muffler and replace it with a straight pipe it would be the same as muffler delete
JB4 G5 ISO , AR DP's, DO Meth kit Trunk Mount, ETS 5" Intercooler, M6 Rims, ER Charge Pipe, Fordged DV's, MMp relocated inlets,
Ebay 4" chrome Tips, Lux Angel Eyes
**********11.910 @ 117.09***1.851 60'**********
      09-12-2012, 03:50 PM   #17
e92oholic
Drives: 2013 MINI JCW GP
Someone xray it! lol
      09-12-2012, 04:02 PM   #18
Randomaccess335
69
Drives: 07' 335I
http://www.google.com/search?tbm=isch&source=mog&hl=en&gl=us&client=safa ri&tab=wi&q=335i%20muffler%20cut%20open&sa=N&biw=3 20&bih=356#i=0
      09-12-2012, 04:03 PM   #19
Randomaccess335
69
Drives: 07' 335I
This is supposed to be a link to oem muffler cut open
http://www.google.com/search?tbm=isch&source=mog&hl=en&gl=us&client=safa ri&tab=wi&q=335i%20muffler%20cut%20open&sa=N&biw=3 20&bih=356#p=0
      09-12-2012, 04:53 PM   #20
Yvette
761
Drives: M
Just get PE, it's worth it
Sounds so exotic at high rpms
      09-12-2012, 04:58 PM   #21
dicostal
dicostal's Avatar
Italy
55
Drives: 2007 335i
do you have a down pipe with no cats? would it be too loud with the after market DP?
GIAC stage II|AA DP|AA Charge pipe and BOV|AFE S2 Intake|HELIX FMIC
      09-12-2012, 07:43 PM   #22
e92oholic
No its not to loud with catless dp's. My friend has the PE with them and it sounds like a damn ferrari coming down my street. It sounds soo nice.
But anyways the mufflers look just like the stock ones someone has to figure this out. They cant be that different inside.
