04-05-2022, 11:42 AM | #1 |
Instagram: @bmwdriven_
51
Rep 119
Stage 2 93 OTS Map & Datalogs
Hey Tuner Bros,
I am experimenting with different maps and trying to better my understanding of reading datalogs. In this video I try out the Stage 2 93 OTS map. Check it out! |
04-20-2022, 02:51 PM | #2 | |
Rep 7,624
- There no reason at all really to get a custom tune with pump gas or with any fuel (including Emix) with stock HPFP anyways. You're either going to be octane limited or fuel supply limited and the OTS maps already get you there. - You don't need those colder NGK plugs or a smaller gap with your setup unless for some reason you had issues with stock plugs stock gap - You aren't supposed to use a feeler gauge to gap this type of plug, you need to wire tool or you can damage the tip. - Max boost is way before 3500 rpm with stock turbo and you shouldnt get knock from a "traction issue" as you said... |
harkes1090.00 |
05-09-2022, 02:17 PM | #3 |
51
Rep 119
Hey Jeremy,
-I don't recall saying you can't run 93 on the 91 map. I remember saying something down the lines that it doesn't seem that "fun". But yes, you can and should run the 91 map using 93 octane if the gas is subpar. -Agree, if I had to do it again I wouldn't custom tune on a stock hpfp. -I went with the one step colder plugs because I was planning on running the E30 map. -I used a wire tool to gap these. Don't you worry. I appreciate the insight. What tune are you running on your car? Plugs? |
05-09-2022, 02:35 PM | #4 | |
Rep 7,624
You don't need the colder plugs with E30. Very few cars actually need colder plugs / smaller gap, and it can easily be detrimental to make the switch, especially if you frequently take shorter trips with the car and dont have any issues with stock plugs. You want the largest gap possible without issues. Plenty of people are running stock plugs with 20+ psi of boost, higher ethanol mixes, WMI, etc. |
BMW DRIVEN51.00 |
bm3, tuning |
