02-01-2023, 08:46 AM | #1 |
HotBimmer
40
Rep 116
Drives: 2016 335GT & 2000 Z3M Roadster
N55 Rod Bearing replacements
Hi guys,
my MHD Stage 2+ tuned n55 is approaching 190K km (118K miles)... engine runs great and pulls strong. been reading that rod bearings can be an issue on these engines particularly tunes ones. I know the effort involved (mine is F34 335GT). question is?? how do i know if I need to replace them? is this a maintenance item or more of a address when XXX symptom(s) appear... I've heard people talk about rod bearing knock; but to tell if I have it? Thanks! If replacing; preferred brands? |
02-01-2023, 03:43 PM | #2 |
41
Rep 187
Drives: BMW F36 435i FBO
It’s all about oil, keep it topped up at all times to not risk oil starvation and keep up with maintenance. 5k oil changes
There is not much problems with the N55s in F series cars. You shouldn’t worry, more problems on the earlier E series cars with N55 |
02-02-2023, 10:47 AM | #3 | |
Rep 10,301
Small percentage of N55 engines in US-spec 2013 F30 vehicles exhibited premature rod bearing wear. BMWUSA replaced these engines. |
02-03-2023, 02:46 PM | #4 |
Rep 7,622
extensive discussion on rod bearing replacement: https://f30.bimmerpost.com/forums/sh....php?t=1893538
SpencerC_6MT198.50 |
02-04-2023, 02:53 PM | #5 | |
Rep 5,399
If I ever need to drop my oil pan I’ll probably replace my bearings with coated VAC bearings. They can withstand short periods without lubrication. https://store.vacmotorsports.com/mob...s55-p4845.aspx |
06-11-2023, 02:50 AM | #6 |
Rep 18
Hi
You wouldn’t know up until the engine started knocking.If it’s started knocking you may stop ASAP and don’t ever start or drive the car until it get fixed. Do regular oil changes like the others said every 5000k.if there is any oil leak fix ASAP. The only way you can tell is inspect the engine oil.you can either remove the oil sump and have a look, when you change the oil have a look or inspect the oil filter.mainly you are looking for metal particles.they are like silver metal powder in the engine oil.if you remove the oil filter and if you do a thorough check you will see them.if there is anything Like that please get the engine check than waiting and causing more damage.it will cost you more like happened to me |
06-17-2023, 12:20 PM | #7 | |
Rep 18
06-18-2023, 08:48 AM | #8 | |
Rep 10,373
An oil analysis can give a false negative. When you perform an oil change look for a lot of glitter in your oil filter and in the residual oil in the oil filter housing. Google will help.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
n55, rod bearing, rod knock, tuned |
