01-24-2011, 06:45 PM | #1 |
Rep 443
✚WHEELSTO | WORK Wheel S1 R & M1 R Meister - Semi-Forged, Lightweight & Aggressive!
Bimmerpost,
We here at WheelSTO are proud to announce the release of the new WORK Wheels Meister S1-R & M1-R for BMW 5x120 PCD. You might be familiar with the original, cult classic Work Meister S1. The original S1's were spun cast barrel with a cast face available in riveted 3 piece or the 2 piece construction. WORK Wheels have decided to cut the weight down and make the Meister into a competitive 2 piece track wheel. The new WORK Meister S1 R/M1 R was born. WORK Meister R series uses a two piece construction wheel. They have modernized the center disk to a more updated look while saving as much weight as possible without sacrificing the wheel strength while utilizing their patented low pressure cast center disk with a spun forged step rim barrel. Sizing: 18" Sizing only at the moment Sizing ranging from 18 x 8.5 ~ 11.5 wide. Offset increments in (1mm) for a precise specification Construction: Low pressure cast center disk with a spun Forged step rim barrel. Disk Type: (A) Disk for standard, larger factory calipers. (R) Disk for Big brake clearance. (O) Disk for Maximum lip, less brake clearance or smaller brakes. Weights: 18 x 9 ~ approximately 22 lbs 18 x 10 ~ approximately 23 lbs Colors/Finish available: Matte Bronze Anodized Barrel - S1R Feinheit Silver II - S1R Matte Black (MBL) - S1R Bright Buff Finish (BBF) - S1R Matte Bronze Anodized Barrel - M1R Feinheit Silver II - M1R Matte Black (MBL) - M1R Platinum Gold (PG) - M1R How to Order or Get More Information: Call: 312.880.7767 Email: info@wheelsto.com PM the WheelSTO Crew: Julius ● Julius@WSTO Dave ● Dave@WSTO WheelSTO Wheel & Tire Package Program WSTO also offers wheel and tire packages. Please Let us know what your favorite tire is, when asking for price quotes . If you are not sure, just let us know and we can make some suggestions for your intended use! WheelSTO uses a Hunter Road Force balancer to ensure your setup is perfectly balanced. Each order includes a printout showing the accuracy. Ask Your WheelSTO Rep about our FREE Mount and Balance Program Today! - Wide selection of Tires: Yokohama / Michelin / Nitto / Toyo / Pirelli / Vredestein & more - Mounted and balance with TPMS - "Ready to Go" |
01-26-2011, 02:23 PM | #2 |
1771
Rep 7,653
Hello,
The 18 x 9 (O) Disk +69 ~ -11 The 18 x 9.5 (O) Disk +75 ~ -17 The 18 x 10 (O) Disk +84 ~ -24
01-27-2011, 06:58 PM | #5 | ||
Rep 443
If you plan on running a "HUGE" BBK, let me know and I can check the clearances for you. Quote:
19's are planned, but no official news yet. |
