BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      03-28-2024, 01:56 AM   #1
VicS5
VicS5's Avatar
Drives: 2009 E92 M3
Heater core HVAC delete
Looking for guidance on coolant line re-routing for deleting the heater core from an S65 car. Other platforms employ block off plates and plugs, but the S65 has coolant routed from the head to the transmission to bring the DCT up to temp more rapidly.
I’ve seen many recommendations to avoid looping the heater core supply and return lines, but I can’t find much info on the S65. All kits and most information seem to be related to other platforms. I obviously don’t want to ruin my engine while chasing 20 lbs.
Hoping there are other similarly afflicted fools here trying to “add lightness” who have already been down this path.
Thanks.
roastbeef11586.00
      03-28-2024, 03:14 PM   #2
roastbeef
roastbeef's Avatar
Drives: E92 M3
i'm interested in the same.
is there a safe DIY way of taking out he freon? hold my breath and turn on a fan?
Instagram; @roastbeefmike
      03-28-2024, 04:47 PM   #3
VicS5
VicS5's Avatar
Drives: 2009 E92 M3
I had the AC refrigerant removed by a local shop in a safe, environmentally conscious way.
One small step to balance out getting 7 mpg and destroying 4 tires in as many days.
Or you could huff it.
Appreciate 3
roastbeef11586.00
amg6975500.00
kolosy1488.00
      03-29-2024, 07:54 AM   #4
VicS5
VicS5's Avatar
Drives: 2009 E92 M3
Looks like the coolant exits the engine at the back of each cylinder bank into metal tubes that join and feed a single hose running to the DCT heat exchanger. Return line from DCT runs to auxiliary water pump, which then feeds supply to heater core through the bulkhead.
Return line from heater core runs straight to the return pipe to primary water pump.
I don’t see anyplace in the loop where there is opportunity for mixing of return from the DCT and return from the heater core. Rather it is a single continuous loop, and all coolant flows through the heater core before returning to main pump. I think the main role of the auxiliary pump is to augment flow to the heater core when at low RPM so the cabin still gets heated when in slow traffic. Heat delivered into the cabin is determined mostly by what the fan extracts, not by volume of coolant delivered.
Bottom line: I believe the coolant flow is a single continuous loop once it exits the back of the engine. Looping in a U-shaped bypass of the heater core (aux pump straight to main pump return line) will have no effect on cooling, except for the heat that would have been shed to the heater core. I suspect the auxiliary pump can be removed because it will never be activated by a call for heat at low RPM from an HVAC head unit that doesn’t exist, but I’m not comfortable with that assumption.
I’d welcome any input based on concrete knowledge rather than my suppositions. Am I naive to think there is no other hidden parallel flow path within the engine that I might be shunting coolant away from by creating a bypass of the heater core?
      03-29-2024, 08:09 AM   #5
amg6975
amg6975's Avatar
500
Drives: '12 M1.5, '05 ZHP, '98 M3/4/5
Another thought is do you really need the wateril warmer for the DCT in a track car?
I would guess not but I have no scientific data to back that up. I think there are aftermarket solutions for deleting it.
      04-16-2024, 12:10 AM   #6
TheStevo1000
TheStevo1000's Avatar
17
Drives: E92 M3
I'm also trying to figure this out, as I've removed the heater & AC from my track car. I contacted Bimmerworld, Turner Motorsport, and Condor, and the people there also weren't entirely sure...I would agree with the assumption that the aux. coolant pump could be removed and the lines looped together. If the entire HVAC system is gone, would the aux. pump ever turn on? I don't think it's always on, right? One annoying problem is the hoses going in and out of the heater core seem to be different diameter, so I can't just connect them with a standard tube/pipe.
      04-16-2024, 06:11 AM   #7
VicS5
VicS5's Avatar
Drives: 2009 E92 M3
I ended up installing a loop between the aux water pump and the hard return line. It’s 19mm on both ends, so a 19mm 180 degree bend hose works. The ends of the 2 hoses that attach to the heater core at the firewall are different sizes, but the other ends of those 2 hoses at the aux pump and the return line are the same size.
I didn’t remove the aux pump or bypass the loop to the DCT. Looks like temp sensors in the transmission control the aux pump, so even removing the full HVAC system wouldn’t stop the aux pump from running. See DCT info details here.
https://www.m3post.com/forums/attach...4&d=1317583307
I brought it up to temp in my driveway and all a seems stable and flowing well. Will be on track at WGI Monday and Tuesday to give it the full test.
All in, shed over 80lbs this winter.
AC pump, condenser, and lines.
EVAP system delete
SAP delete
Rear parcel shelf delete
Heater core delete
Washer reservoir and fluid
BW CF headlight blanks
Rear O2 sensors and extension wires, brake wear sensors, and various other metal bits and and further wire thinning
Appreciate 3
DRLane3988.50
amg6975500.00
roastbeef11586.00
      04-16-2024, 12:10 PM   #8
TheStevo1000
17
Drives: E92 M3
OK, thanks for sharing the great info. That's good to know. And that makes it pretty easy to just install a loop hose.
Ya, I've been weighing all the parts - then entire HVAC system and all related parts is around 39 lbs!
roastbeef11586.00
m3post
