02-04-2022, 12:14 PM | #23 |
26
Rep 85
glad you got it figured out man
Slowdr1v3r5.00 |
02-04-2022, 02:25 PM | #24 | |
Rep 552
Drives: 2018 M4 ZCP 6MT
Transmission mount wise, I have you covered. I upgraded to the Rogue mounts last year as I was having a lot of what I'd call transmission sway on quick bursts of acceleration, as well as well as during "spirited" turns; made it hard to catch second as it would shift around under load. If you look at the stock mounts, they're absolutely pathetic for a vehicle of this caliber. The Rogue mounts made short work of the problem though, and as a bonus they didn't introduce any additional NVH.
2018 F82 ZCP 6MT: FBO, Kratos KRAS55Bi, EU5 Injectors, Dorch HPFP Lift Kit, Stage 3 LPFP, Bend Calibration Zeitronix ECA-2, BM3 Flex-Fuel Tune by ABP
For Sale |
Slowdr1v3r5.00 |
02-04-2022, 05:05 PM | #25 | |
Rep 5,179
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
Slowdr1v3r5.00 |
02-05-2022, 07:55 AM | #26 | |
Rep 45
02-05-2022, 11:18 AM | #27 |
Rep 45
I think the delay valve was the main culprit. I did try bleeding the slave when I first got the car back from the shop and it did not help. Although this time I also did try to reverse bleed it then regular bleed as well. So that may have helped. But I honestly think it was the CDV that was just too restricting for such an aggressive clutch.
TopJimmy5494.00 |
01-18-2023, 08:40 PM | #28 | |
Rep 6
Hey, so after you replaced the diff, driveshaft and axle. Did all your wheel hop issue go away? Are you able to spin the tires freely w the twin disc? |
10-15-2023, 07:06 PM | #29 | |
34
Rep 75
Curious on what throwout bearing you received with the CM kit, was it an OEM or some other? I havent physically seen the “HD” one they apparently send with the kits. Their customer service has been dismal to say the least.. |
11-07-2023, 07:30 PM | #30 | |
40
Rep 120
Spec P-trim. I used the "low" setting on a brand new OEM TOB. Any advice? Is it worth dropping the trans and switching to the "high" position on the "HD" TOB? Already did a new slave and CDV delete. Improved pedal feel but it feels like there's a lot of pedal travel missing, so to speak. Spec told me to install at whatever position the TOB came out. I suspect this might be incorrect. |
