TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wash, Wax, Detailing and Cosmetic protection/repairs > Noob Paint Correction Attempt on Jet Black 2007 335I
      08-03-2012, 09:06 PM   #1
LaynEE92
Drives: 335I
I decided to take the plunge and bought all the detail equipment I thought I needed to correct the paint on my 2007 335. Detailed in the following in order:
Wash and Dry
Clay Bar
Poorboys World SR2.5 on orange pad
Poorboys World SR1 on white pad
Poorboys Black Hole Glaze on black finishing pad
Jet Seal 109 1 Coat Applied by hand and machined buffed with micro fiber pad.
I went over parts of the car that I thought needed more attention with the 2.5.
I unfortunately did not have the right lighting equipment so I was not able to see the fruits of my labor as i was polishing. I did take it outside a few times to give it a look down.
I knowingly proceeded on the SR1 knowing I still had a degree of fine scratches. I reasoned this out of my inexperience thinking the glaze and sealant would help fill in the remaining scratches.
I don’t have a good close up pic of the paint but i would have to say my car looks great from 2 feet away but if you get real close you can still see a few scratches here and there.
The other flaw in my work that is bothering me was machine buffing of the jet seal 109. I believe this has given the car a hologram look. If anybody else has had these issues or think im off base please chime in!
Anyways here are some pictures of the finished product.
      08-03-2012, 10:07 PM   #2
bretster
bretster's Avatar
84
Drives: E92 M3
Looks good! Show us some pictures to show the correction!
      08-05-2012, 12:22 AM   #3
psnt1ol
psnt1ol's Avatar
31
Drives: e90
Wash and Dry
Clay Bar
I use jetseal almost exclusively. I never experienced what you had described. I apply jetseal mostly with a DA but I never buff the car with it. The only thing I would do differently would be to apply the glaze by hand and use a finishing pad to apply the sealant. I like to do my corrections with MF pads and finish down with foam. I have better results going this route. By the way, what speed did you use with the Jetseal and MF pad combination??? I assume you are using MF polishing pads and not the cutting pads.
What is absolute control???? Having the means and the abilities to exercise it at will but....chooses not to.
      08-10-2012, 12:25 PM   #4
Otruba_843
Otruba_843's Avatar
Drives: 2009 E90
I did not know we were supposed to buff sealants. I thought you just apply then wipe off in time alloted
2009 E90 328i Monaco Blue
premium/idrive/convience/logic-7/cold weather/ xenons/ saddle brown interior
      08-11-2012, 02:49 AM   #5
oilngas
DAHU
oilngas's Avatar
Drives: 09' 335i
2009 E90 LCI  [0.00]
You're defeating your purpose using glaze. Glaze is a cosmetic compound that is used to hide scratches and swirls. It won't do much for holograms either. The effect is gone after a few washes.
So if you polished and glazed, you pretty much hid what you missed. I use Meg. 105 and Menzerna SIP. Seal with Menzerna Powerlock. Pads: Yellow with Meg, Orange with SIP and Blue or Black with Powerlock. For optimum seal, I wax 24 hrs after applying sealant. Use a DA like Porter Cable or a Flex.
And No, you don't buff sealants.
I specialize on black exteriors. It's a hobby....
Link below is for a Black MB E55 I worked on a while back.
http://dph-online.com/work%20porfolio9.htm
"Success is a direct result of effort."
