04-10-2024, 03:21 PM | #1 |
89
Rep 138
Bimmerworld X-pipe impressions
Just installed a custom catless BW x-pipe with 2 extra sets of resonators. With my corsa rear section, this is a perfect setup imo. Zero drone, no rasp, and an exotic tone.
A proper tune is needed to optimize this setup, so I have an Epic Motorsports tune on the way. I’ve been running this system without a tune, and I’ve found drivability to be fine. No CEL, but some stuttering at high rpm. Also, a slight buzzing/whirring on acceleration. I’ll see if it changes after tuning. |
04-11-2024, 08:13 PM | #2 |
68
Rep 119
curious how this works out, I have a similar setup but with high flow cats in the rear section. Epic, BPM or RK Tunes are the 3 I'm looking into, why did you go with Epic over the others?
04-11-2024, 08:37 PM | #3 | |
89
Rep 138
I will be tracking my m3 and I think the tune will be a good match. |
04-12-2024, 10:04 AM | #4 |
///M
95
Rep 252
Yes and yes exactly, Randy is great. What kind of secondary resonators did you get?
04-12-2024, 10:37 AM | #5 |
89
Rep 138
The previous owner had the fab work done, and he said it was just what the exhaust shop had around so idk. The x-pipe has the magnaflow resonators in the standard position, with 1 set of resonators in the primary cat location and the other set as pictured after the x.
zcp31294.50 |
04-16-2024, 11:58 AM | #7 |
Rep 1,107
Drives: 2009 E92 M3 Dakar Yellow II
04-16-2024, 12:55 PM | #8 |
89
Rep 138
Nope, to eliminate any smell you’d mimic this modified BW x-pipe with HFC. Also, since my x-pipe is welded that eliminates potential leaks that could introduce more stink than usual.
