2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Creaking/squeezing front suspension BMW F10
      07-08-2019, 01:56 PM   #1
Calle799
Denmark
Drives: M5 F10
Hello,
I have a pretty iritaring sound coming from mine front end on my M5 F10.
Sound appear only when driving with low speed.
For example i hear the noise on uneven roads when going slow, and i also hear it when i start roling from the trafficlight for example.
Please see the vido i have uploaded. What could the problem be? I have read all about wheelbearing, dry bushes, sway bar and so on. What do you think guys?
Hope somebody can help me out with this, it is so irritaring..
      07-08-2019, 05:08 PM   #2
cdmulders
cdmulders's Avatar
327
Drives: 2013 535xi
I've had this, and it happened to me after driving through heavy rain. I think it was some water getting into bushings, etc. My squeaks went away after a week or so, when stuff dried out. All you might need is to get some lubricant into the bushings or otherwise remove the moisture.
PS: We need pics of your M5!!
2013 535xi, Carbon Black, beige interior, M Sport package, HUD, DDC & ARS, ACS springs, Kelleners wheels
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension
2000 528i, Cosmo Black, beige interior, Sport package (retired)
zrile91.00
      03-15-2020, 05:49 PM   #3
Thewrench86
36
Drives: E92 \M sport. F06 640d M Sport
Any update on this having a similar issue atm after washing my car. But squeaking creaking has stayed for past month.
      03-15-2020, 09:45 PM   #4
BimmerHausPerformance
BimmerHausPerformance's Avatar
513
Drives: 2011 535i 6MT
2011 BMW 535i  [0.00]
Did you wash the lube off?
2011 F10 S55 6MT
Website Insta @bimmerhausperformance YouTube
      03-16-2020, 07:25 AM   #5
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
I believe there isn't really any type of lubes maintenance on our f10's?
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~
Follow me on Instagram: lsturbointeg
      03-16-2020, 07:49 AM   #6
513
Sorry getting threads confused cause there was just another one about this... I was meaning any lube you might have added to any after market sways that DO tend to squeak.
2011 F10 S55 6MT
      10-03-2020, 02:48 AM   #7
BIGXPX
Drives: BMW F10 M5
Bringing this back up again. I've started to experience this over the last 2 week.
There are no issues with how the car drives and yesterday I had Eibach springs fitted. They checked all suspension arms, bushings etc and all ok.
Any idea what this noise is? Anything that needs to be lubricated or greesed?
The noise is so annoying
      10-03-2020, 08:35 AM   #8
Hoa
513
Drives: BMW
I suspect the bolt hole for your control arm have wear on it and is causing this noise. To attempt to fix this, pull the bolt from your control arm, spray WD40 to help remove the black stuff from the bolt hole on your control arm. Put anti seize around the bolt shaft and reassemble.
      10-04-2020, 06:58 PM   #9
Grizzlymc
The Hibernator
Grizzlymc's Avatar
Drives: 2018 X3 M40i
Front thrust arms was the issue for me with similar symptoms. Also caused a vibration when braking
      10-06-2020, 11:23 AM   #10
VAB5
21
Drives: '15 535; '15 328; '05 ZHP conv
Same here. I had the creaking when driving daily through my work parking garage. Thrust arms fixed it.
remmib1568.50
      10-22-2020, 01:37 PM   #11
JoeC
Drives: 2007 Z4M, E39 M5, F10 M5 CP
I took my car into a specialist, they looked over the suspension and said the only possible issue they can see is that the front sway bar bushings were a bit cracked. I had them install a new sway bar (because obviously the bushings aren't sold separately) and the issue is still there. They said the thrust arms look good. I wish the original poster would come out and say what fixed this on his M5. I do not want to start replacing parts for the hell of it.
      10-27-2020, 06:29 AM   #12
Zenith5229
Drives: Bmw F10 528i
I also have the exact sounds when going slow from a standstill be it in D or reverse , or anytime that i drive off the car while it has been parked for a while .
Mine is a 528i N52 .
      12-04-2020, 02:37 AM   #13
nick5524
Drives: '15 535i MSport, '08 335i
I get the same thing... In the mornings when I reverse from my parking spot. Ideas???
      12-04-2020, 04:21 PM   #14
Thewrench86
36
I've still not solved this issue. But what I have found is sometimes if I mount a kerb and drop down of it on the side I think I have the issue, the sound goes away for a time. Maybe until I mount a kerb or drive over a large speed bump. I tried lithium grease on all the ball joints I could reach but nothing really solved it permanently
      12-04-2020, 06:09 PM   #15
Unspec
Unspec's Avatar
1301
Drives: 2015 BMW 535xi
Might be your upper control arm (aka thrust arm) bushings. I've read that those bushings go the fastest.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets
ISTA VM Setup/Tutorial
      01-09-2021, 09:36 PM   #16
Grizzlymc
The Hibernator
Grizzlymc's Avatar
With my thrust arms, it was the bushings. Apparently the oil ballast on the bushings was leaking dry causing the noise
      09-12-2021, 10:06 PM   #17
Byambadagva
Drives: E90, F10, F30, E84
I've had this problem, replaced both front control arms, it went away.
https://www.aliexpress.com/item/32811917228.html
      02-05-2022, 03:50 AM   #18
Eisbaer Lars
Eisbaer Lars's Avatar
Drives: E65 750i; F10 550ix sedan
Same here - changed front control arms and squeaking noise is gone
      02-19-2022, 04:04 PM   #19
SomeMods27
SomeMods27's Avatar
Drives: 535iXdrive
Yeah Front Control Arms Are Making That Sound, I Had To Change Out My Bottom Control Arms, It Was Making That Same Sound, When I Turn The Car From Left Or Right. It was The Passenger Side, I Replaced Both Left And Right
      02-19-2022, 04:29 PM   #20
Eisbaer Lars
Here are the vids taking for the sqeaking noises - I could force them by getting in low speed on and off the brake - but the limitation was LOW TEMPS! The squeaking got only more with low temps - so as I call it a seasonal issue.
Right sied squeaking
Left side squeaking
As I mentioned before - changed front control arms and squeaking noise is gone
Happy sound search!
Lars
      07-19-2022, 04:37 PM   #21
Vega2k
Drives: BMW F10 523i
Hey, is it necessary for wheel alignment after replacing this control arm?
      01-18-2024, 02:56 PM   #22
jpophammer
Drives: 2013 F10 M5
sorry for reviving an old thread but I just found the solution to my creaking noise in my front end and wanted to share!
After digging into what the most annoying sound my M5 has ever made, I was convinced it was the lower front control arm... well, I jacked the front of the car up and the wheel had NO play at all...
reached into the spring/ strut area and pulled the little rubber bushing and plastic tube down, sprayed it with silicone lube. SQUEAK IS GONE!
Thank god I didnt go out and just buy parts for it...
Best of luck to everyone and hopefully you'll be able to fix the noise with a few bucks!
5post
