My 2006 E91 CCC to CIC retrofit journal
07-16-2014, 08:44 PM | #23 | |
Rep 1,068
Little confusing.. I may just install as is and do it some other time
2006 BMW 325xi E91 Wagon SGM
18" Fast Nemesis / Azentis Staggered Bilstein B12 w/E93 Eibach Pro Kit 2009 CIC Retrofit + Combox 6NR, 6NF, snap-in retrofit |
07-17-2014, 07:58 PM | #24 |
295
Rep 2,203
Subbed!!! Some amounts of info in this thread man. Good luck.
I'm attempting this task myself but I'm held back with the source of a dash at the moment.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
07-17-2014, 08:05 PM | #25 |
Rep 1,068
thanks, i will add photos and installation items next week. looking forward to sharing it as many others did too. But I see that it evolves year after year.. and I'll be doing the snap in retrofit, armrest usb retrofit, bluetooth, combox, etc.. good luck finding a dash! now that's a challenge to do!!
07-18-2014, 10:00 AM | #26 |
32
Rep 160
I'm thinking about parting together a CIC retrofit like you did, but I'm starting to wonder if the hassle vs cost savings isn't worth it? How much money do you have wrapped up in this? Also I'm thinking of maybe going NBT as I believe the combox is built in?
07-18-2014, 10:17 AM | #27 |
Rep 1,068
So far almost at 3000$ and not installed yet or coded yet. It depends how important all this is to you. I'm a geek so being connected and having the gizmos is important to me
07-18-2014, 09:02 PM | #28 |
Rep 1,068
Bumpers, I've begun with my Sirius tuner retrofit. See Page 1 Post #4
07-19-2014, 05:06 AM | #29 |
17
Rep 320
nice work so far jezzy with the pics....
I cant help you with the Sirius retrofit but I will say the 3 attenna cables in your hand in one of the pics went into my tcu unit. I don't think they are for Sirius radio (but I could be wrong). The white one will go to the combox but you will have to cut a small piece from the connector on the combox. you will see when you come to connect it. I also found the pinout for the aux audio out from the baseplate. pin 3 - aux out left pin 4 - aux ground pin 12 -aux out right I will update my pic... Last edited by terminator2k2; 07-19-2014 at 06:45 AM.. |
07-19-2014, 07:51 PM | #30 |
Rep 1,068
awesome! I still haven't been able to spend that kind of money on the wiring for that aux mod. =( Perhaps I'll just get the pins necessary and find extra wiring somewhere.
07-20-2014, 08:12 AM | #31 |
295
Rep 2,203
Jezzy I'm curious as to why the troubles of retrofitting a Sat-Tuner when the CIC unit has this feature. Correct me if I am wrong on this. Is it that the head unit you have the Euro version?
07-20-2014, 08:14 AM | #32 |
Rep 1,068
Hi only 2011 cic radios might have Sirius built in but has to be written on the unit. I have a us 2009 cic radio this no Sirius tuner built in. Only hd radio. ;(
07-20-2014, 10:30 AM | #33 |
295
Rep 2,203
Ahh! bummer!
07-21-2014, 11:06 AM | #34 |
Rep 1,068
So, i got my retrofit done this morning.. well, done's the wrong word. Its installed and running, but for the life of me, i can't get NCS working.. I was able to previously see my VIN with my CCC unit, etc.. so was able to do some custom coding.
Now.. it won't see my VO or VIN, and well. Now stuck! I can't code my CIC for my car.. navi, voice control, radio and mp3 all work at least.. Any ideas guys?
07-21-2014, 01:18 PM | #35 |
17
Rep 320
ref the ncs problem, have you tried driving your car 10 minutes or so then letting it sleep for half hour or so and try again?
reboot computer? re-plug coding cable? plug your cable into a different usb port? |
07-21-2014, 01:51 PM | #36 |
Rep 1,068
I think I got it. Pfew! Managed to change my vo to $0909 but now lost phone and Bluetooth on the cic. Hmm. I will update thread with photos and coding once it's solved!
07-21-2014, 03:56 PM | #38 |
Rep 1,068
Update to come tonight
Edit: Okay. Once I turned it all on. Navigation works. Bluetooth showed up and phone did too. Once I did a #0909 on the cas the options disappeared. So I'll need to re-add them again. I added the code for e91 so the car info screen works fine. I'll update once kids are in bed and write down the listed vo. Once that's up. Review the most connections. Combox is plugged in with a modified USB cable. What a pain to ass to run a cable from Center console to the trunk. I passed it over the carpet just for testing purposes. Combox is plugged in with the adaptor plug. I tried both USB plugs but as far as I got with time today. I also added my Bluetooth antenna today. Black wire with a Pink plug. Same as the one in the arm rest that the snap in uses. The blue snap in USB runs to the combox with that modified cable. Voice control is much improved over the ccc one. Maps are lovely too. Mine date from 2009 so need updating too. I pulled out the 7 digit code with tools32 for the fsc code if required. I'm currently using my ccc controller. Works fine! Last edited by jezzy; 07-21-2014 at 05:10 PM.. |
07-21-2014, 06:19 PM | #39 |
Rep 1,068
Updated 2nd post with pics. More coming in a few mins.
This is my FA : E91_#0911&KAB4%0475$1CA$203$205$249$255$2CZ$354$38 6$402$431$441$464$481$494$4AB$502$520$521$522$524$ 534$544$548$563$5GA$609$620$640$645$655$676$6FL$6N F$6NR$818$823$838$845$850$853$876$896$925*VT13-B090 I've got the Daten files v52 for the E89 platform. I've changed my VO year to 09/11, and TRIED adding 614, 614, 644, -IPOD, -KMP3 but without success. the same error appears : coapi error -1181 =( I'm only trying to code my CAS at the moment.. I haven't done any "code entire car" yet. Last edited by jezzy; 07-21-2014 at 09:48 PM.. |
07-21-2014, 10:00 PM | #40 |
Rep 1,068
^ holy sh*t.. perhaps I've been trying to use #614 instead of $614 can that be possible?
07-21-2014, 10:25 PM | #41 | |
295
Rep 2,203
07-22-2014, 02:28 AM | #42 |
17
Rep 320
Just a pointer , no need to code entire car, might be problematic.
You only need to code cic, combox and then kombi if the vehicle info isn't correct I think you will also need $6va $6vc and $6nl I don't see them in your vo this could be why you cant put in $614 $615 as $6va is for cic and $6vc is for combox Last edited by terminator2k2; 07-22-2014 at 11:39 AM.. |
07-22-2014, 01:46 PM | #43 |
Rep 1,068
Thanks. I'll try it again right now. Anyone do remote coding? pm me! I'd love to get some help. ($) =)
Anyhoo, I've tried and tried again. Each time I code the car and return, the values have disappeared. Now tell me if I'm doing it wrong. I add the item to the VO $6VA for example.. i click back, I then select the ECU I want to write the VO too, i select CIC, select SG_CODIEREN, it says job done, my CIC reboots, and nothing ever changes (no additions). I did notice when I click "process ECU", it shows CIC.C08 then changes to CIC.C13 once it starts to write. Perhaps my CIC firmware is too cold to take some of these options? So i called bimmerretrofit who is 10mins from my house, they can only do remote coding for an Eseries car.. but if I need firmware updates, an OPS cable is required.. so remote coding is out of the question? Anyway, guru's ! fun adventure.. but looking forward to getting the remaining snap-in to combox / combox to usb/aux cables in and perhaps FBAS cables too. I had a brain fart, think my emulator is blocking me from updating my VO? Should i remove it ? It's a hot 35'c in the car today, parked in the sun trying to code.. not too enjoyable!
18" Fast Nemesis / Azentis Staggered Bilstein B12 w/E93 Eibach Pro Kit 2009 CIC Retrofit + Combox 6NR, 6NF, snap-in retrofit Last edited by jezzy; 07-22-2014 at 02:28 PM.. |
07-22-2014, 02:31 PM | #44 |
17
Rep 320
ok here goes on how to change / modify VO
file - load profile - choose expert mode - press ok press f2 choose chassis - then choose chassis of your car - click ok click f6 back click f1 vin/zcs/fa press f2 enter fa choose chassis for your car click ok pop up box with your vin in there - click ok enter what you want to change in the box and click add when finished click ok press f6 back press f4 process ecu choose cas - press ok press f2 change job - select FA Write - click ok then lastly f3 execute job you only change the vehicle order in the cas and frm module. you possibly will not be able to change the vehicle in the frm as it will not accept the date as your frm is too old......I have the same problem but it will not affect the cic or combox. the emulator will not cause any problems regarding coding.... do you have a programme called team viewer? I can try and help you remotely Last edited by terminator2k2; 07-22-2014 at 02:36 PM.. |
