BMW X3 Forum
BMW X3 Forum
      10-28-2017, 04:10 PM   #89
najnad
General of the Space Forces
najnad's Avatar
Drives: 11 X3 35i M-sport
Another satisfied repair....2 boards replaced for about $9 instead of $750 to replace both inner and outer lights on passenger side!
      10-28-2017, 05:03 PM   #90
smovva
Drives: G05 2019 X5
Forum member MindBraker on the X3 bimmerfest forum found a direct replacement board for $20 shipping included that may be a good alternative for those of you who don't want to solder wires etc. He also suggested using a 250mA Mean Well driver; I have been using the 500mA driver for months without any ill effects.
The replacement PCB is $20 shipped worldwide:
https://www.ebay.com/itm/202094518700
http://www.bimmerfest.com/forums/sho...=822229&page=5
      11-02-2017, 03:49 PM   #91
Commerce
278
Drives: 2019 X3 M40i
I have this board on order, I'll post an update once I install it.
      11-30-2017, 06:43 PM   #92
Commerce
278
Update... The replacement board is a super easy fix for those who don't want to solder. I used it for both the inner and outer lights. The replacement is not as thick as the original Valeo board requiring you to tack it down in order to hold it securely in place (I used hot glue). Highly recommend it!
      02-28-2018, 06:58 PM   #93
beats
beats's Avatar
225
Drives: 2015 911 GTS
Here is a little guide I put together to use a different mean Well LDD-500L module that requires no wire cutting or soldering. The module is also a little cheaper than the first one (LDD-500HW) I recommended. Enjoy!
You are a champ! This is why the car forums are awesome!
Thanks for the write-up, piece of cake fix. Ordered 3 spares just in case.
      03-04-2018, 08:40 PM   #94
smovva
Drives: G05 2019 X5
Smile
You are welcome! As a fellow owner of a "Break My Wallet" brand car, its good to be able to do somethings for ourselves without having to resort to dealer and BMW prices.
Also member Ogee from Norway on the Bimmerfest forums has created a PCB that can have the equivalent connector and the meanwell part on it so you dont have to cut any wires. Those of you handy with a soldering iron can get his eagle CAD files, order a PCB and solder the connector and MeanWell driver for a factory look. He is using a MeanWell 300ma driver to be closer to the Valeo specs, though the 500ma on my car after 16 months has caused no problems...
http://www.bimmerfest.com/forums/sho...&postcount=165
beats225.00
      04-15-2018, 07:24 PM   #95
najnad
najnad's Avatar
Just fixed another one...that makes 3 of 4 on my 2011 X3.
      08-02-2018, 06:58 PM   #96
nonot
Drives: 2016 X5 M Sport
Just a word of lookout for those replacing the LED driver board with ones from eBay: I had mine replaced and I got interference from the board and it affected my comfort access and keyless entry. I got the intermittent message that my key can not be recognized.
Still looking for another brand and see if it will be less of an interference.
Any recommendations?
2016 X5 35i F15 (Prod.date 2015-10-01)
2014 X3 2.8i F25 (Prod.date 2013-10-25)
2006 X5 3.0i E53 (Prod.date 2006-04-05)
2008 X3 3.0si E83 (Prod.date 2007-10-23)
      08-03-2018, 01:45 PM   #97
x3sm
x3sm's Avatar
284
Drives: M3 E93 Porsche
Which one did you buy from eBay? I got mines from eBay and my comfort access works.
      08-03-2018, 03:05 PM   #98
nonot
This is the 1st board I got:
      08-03-2018, 08:44 PM   #99
x3sm
x3sm's Avatar
284
I got mines from guy from Russia.. I can take a pic of my board. But how would the board mess with comfort access ?
M3 E93
PORSCHE MACAN S: SOLD
BMW X3 F25: SOLD
AUDI S4: SOLD
BMW E92 335: SOLD
      08-03-2018, 08:59 PM   #100
Commerce
278
I bought mine from hiperlights_ru on ebay and have had no issues with comfort access.
      08-03-2018, 11:08 PM   #101
nonot
They guys where I bought the first board was kind enough to replace it with boards which I believe is from Russia. Will test it when it arrives.
Here is the picture, sent to me, of the replacement boards from Russia:
      08-05-2018, 09:30 PM   #102
x3sm
x3sm's Avatar
284
thats the one I have!
      03-07-2019, 07:12 PM   #103
NYRangers79
Drives: 2019 Bmw X3 m40i Stage 2+
This should be a sticky. I had this same board. Complete junk. Comfort access broke. Bought those other one from Russia. Perfect. No issues. Too bad cause bmw basically replaced my keys and diversity attenna. Guess it was my fault.
      03-11-2019, 12:00 PM   #104
doru
doru's Avatar
126
Drives: e92, f25, e46, e83
During the last year, I replaced already 3 boards, waiting for the 4th OEM to go South, from Hyperlights - Russia.
Absolutely no issues with comfort access or any other functions on the car.
On another note:
I change the garage door opener with a new generation Lift Master. I didn't like the light output, so I changed the bulbs with LED bulbs. Nice bright light, but: both BMW's failed to open/close the garage door. Did some research, and Lift Master has only a few LED light bulbs that are compatible with the garage door opener because they say it WILL interfere with the signal. Weird, but it happened to mine. So maybe if one switches the regular tail lights with some LED lights from Chinaland, those could interfere with the signal of the comfort access. After all these are diodes.
Stable:
e92is
f25 N52
e83 N52
e46ci M54B25 (e53 N62 - sold, R.I.P. e39 M54B30)
      01-09-2020, 12:10 AM   #105
AleksandrBykov
Drives: BMW X3
Hey guys, I have had the same issue on my X3, and I bought new led tail light replacement driver board from a UK website. The quality of the product was super fine, and the price was quite low. I would recommend you guys to give it a try. Here is the product I’ve been using for 6 months and it’s working perfectly.
https://xenons4u.co.uk/bmw-x3-f25-le...b003809-2.html
      02-06-2020, 06:00 AM   #106
ColdCanada
Drives: 2005 BMW X3 AND 2011 BMW X3
HELP
Originally Posted by smoothmoka View Post
Hi all,
Just wondering if anybody else had to replace the LED tail lights. I know it's very easy to replace but can they be fixed instead of the replacing the full assembly? My warranty expired as of May 2015 and my odometer is at 98000...not sure if dealership has any grace period on out of warranty replacement on them (wishful thinking).
Both outer left and inner right seem burnt out. I tried wiggling the wire on one of them and for a moment it lit up then dimmed out after 2 seconds.
Any advice would be very much appreciated!
Thanks.
hello guys.. I have the 2012 X3 AND ONLY the outer sides light up...
is this right???? or are both my inner side lights out? no warnings or anything.
      02-06-2020, 06:40 PM   #107
rcsup1
154
Drives: x3 35i
I replaced my first board with the Russia one no issues the second one I got from another source (I'll have verify which) on eBay and it is currently interfering with my comfort access and my Tpms which is now giving me error msgs stating there is interference!
2011 F25 X3 35i |M-Sport Front Bumper Conversion|Largus Full Adjustable Coilovers|FTP Charge Pipes|Gutted Catalytic Downpipe|RB Oil Cooler Thermostat Delete|25 Row Oil Cooler|Custom Built Cold Air Intake|9"AEM Cone Filter Behind Kidney Grills With Outerwear|Precision Raceworks Coils|BM3 Stage 2 E30 Tune| BM3 Upgraded 8-speed TCU Flash|395mm X5M Front Brakes
      02-06-2020, 06:45 PM   #108
Commerce
278
You should have 4 lights total, the two outer ones and the two inner ones on the tailgate. If I were you, I would just replace all 4 so you don't have to pay twice for shipping in the future.
      02-10-2020, 04:32 PM   #109
BMW JA
29
Drives: 13 X3, 73 454 Vette,
1 down, 3 to go
Just repaired my drivers side tail light. Ordered 4 MW 500mA drivers. Too cold out to do the rest. Come on spring!
      06-12-2020, 12:50 PM   #110
SpyrosX
Drives: BMW X3
Just to summarize. There are 3 fixes for the problem:
  1. Re-solder the board
  2. Buy a new after market board
  3. Replace with LDD-300L driver (also can be soldered on driver board with 4 resistors and a BM04B-XASS-TF)
Do you have an opinion which one is more durable without causing problems to the led lights or the car?
xbimmers
