08-22-2023, 11:25 AM | #133 |
Rep 13
hello
can someone tell me where to connect the wires behind the chofagem, which pin connects the wires on the IHKA3? THANKS Fresh air grille rear room : 64229265350 https://prnt.sc/jXb4eTyzC_Xx |
08-30-2023, 10:58 AM | #134 | |
Rep 4
mounted straight ac unit 9363546 on my 03/2015 f30 pre lci when first booted the screen was white and it was dimmable to red via dimming lights wheel instead of this i've coded the clima "auto switch to color" from bimmercode (shoud be the Farbumschlang) and after I was not able to turn it red and my dimming wheel is not working anymore as my ambient lighting (everything apperars shut off). I just need to try if it light/sensor related, but seems strange I cannot revert it back with coding. Any advices? |
03-06-2024, 05:50 PM | #135 | |
Rep 2
No matter what I tried, there was only cold air coming to the interior. When reading sensor values with INPA, footwell and passenger ventilation temp were always at 70C. Removed the glovebox to look at his wiring and found out that he installed an IHKA3 basic module instead of IHKA3 high. IHKA3 basic module is only for cars without dual-zone air conditioning, which he has... that's why it was unable to read the sensors on the passenger side, they are only present on cars with dual-zone AC. He installed the correct IHKA3 high module and everything is working fine now. So make sure you have the right module if you encounter this issue. |
