BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Corroded Plugs & Coils
Extreme Powerhouse
      03-01-2022, 10:19 AM   #1
bendeyo
Drives: 2013 BMW F30 N55 335XI
Over the past month I've noticed some strange acceleration and what seemed to be a misfire but no codes. The car also seemed to be running rich under heavy load with the occasional plume of black smoke when I step on it. I decided to swap the plugs and coils last night and this was the result(attached image). Cylinders 5 and 6(farthest back) were heavily corroded both on the coil and on the plug. I just replaced both the plugs and coils about 20k miles ago and didn't notice anything like this at the time.
Would this just be caused by moisture getting into these or should I be more concerned of something more serious? The plug cylinder(tube the coil is inserted into) did seem a little damp in cylinder 6 but not in 5. Is there anywhere I should check to avoid additional moisture getting in there?
It seems to be running much better today but I'm nervous that I should check them sooner to make sure this doesn't happen again. I did try to wipe up any extra moisture in the plug cylinder.
2013 F30 N55 335xdrive
125,000 miles
Stage 2 Bootmod3 tune 93 octane
Catless DP
Upgraded charge pipe
      03-01-2022, 11:47 AM   #2
thejeremyman9
thejeremyman9's Avatar
4371
Drives: 2015 BMW 335i
Are you running with your engine cover and the OEM foam?
      03-01-2022, 11:47 AM   #3
LA1Z24
Drives: 2014 435i M Sport
Water is most likely dripping onto the top of the valve cover near those coils, from the hood/cowl area. Although there is a lip around the plug hole to keep water out. And the seal on top of the coil wraps over the lip. Is it possible the coils were not fully seated in the head?
      03-01-2022, 01:44 PM   #4
bendeyo
I'm using the engine cover but not the foam anymore
      03-01-2022, 01:46 PM   #5
bendeyo
I'm pretty sure they were seated correctly as I've done plugs and coils multiple times on the car. I'm wondering if the rubber seal that goes on the strut bars was not on correctly the last time I did them.
      03-01-2022, 04:40 PM   #6
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
The coil seal was absolutely not sealing.. 100% that
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      03-01-2022, 05:57 PM   #7
thejeremyman9
4371
Its probably a combination of all 3: water gets into engine bay as cowl is not sealed --> engine cover/foam doesnt stop water --> coil is not sealed
2013 3 series, 335xi, f30, n55
