11-18-2009, 05:41 AM | #23 |
Change for a Nickle?
14
Rep 875
Just like pimpin, disassembly is easy. Besides, we've got to take advantage of the weather while it's still warm.
"I tasted death many times on the river today. Do you want to know what it tasted like? Do you REALLY want to know? Well I'll tell you then: it tasted like BEEF JERKY." - unknown paddler 8/1/09
11-18-2009, 07:58 AM | #24 |
104
Rep 2,474
you call this warm?
AW 135i w/ blackette, performance short shift kit, BMW alarm, Performance rotors, APEX ARC-8 wheels, Direzza Star Spec 235/275, Dinan stage 3 suspension, M3 wishbones/tension rods/front sway/rear subframe bushings and thats all folks! |
11-18-2009, 08:12 AM | #25 |
winter mode
62
Rep 2,057
Drives: 08 135i, 88 M3
i thought pimpin wasn't easy, but necessary
88 M3: BMWCCA J Sport
08 135: because streetcar |
11-18-2009, 08:20 AM | #26 |
104
Rep 2,474
Pc Load Letter!?!? Wtf Does That Mean!?!?!?!
11-18-2009, 12:01 PM | #27 |
14
Rep 875
I guess it depends on your perspective. When asked the question "is pimpin easy?" my response is "hell yeah!"
11-20-2009, 08:09 AM | #28 |
14
Rep 875
The motor was disassembled last night. Here's what we found:
- All connecting rod bearings were excessively worn - All main bearings were excessively worn - Except for #4, the connecting rod journals measured 0.005" under the minimum tolerance - #4 measured 0.015" under minimum tolerance (this was the mis-torqued connecting rod) - Abnormal wear on the # 4 cylinder wall at the bottom of the travel - Rust and abnormal wear on the #3 cylinder wall - A crack in #3 cylinder sleeve 2/3 the length of the bore - 3 pistons with compression ring gaps lined up - stuck (immobile) oil control rings on all pistons Some pics may be posted later.
11-20-2009, 08:18 AM | #29 | |
winter mode
62
Rep 2,057
11-20-2009, 09:00 AM | #30 |
104
Rep 2,474
ALL BAD
11-20-2009, 09:33 AM | #31 |
14
Rep 875
Pics: Worn bearings, cylinder wall crack, ring alignment.
11-22-2009, 10:33 PM | #32 |
14
Rep 875
Weekend activities on the car included cleaning up and repainting the front and rear cross members, stripping the interior out (except for the dash) and vacuuming a year's worth of rodent droppings. I need to get the car moved inside tomorrow before it rains.
11-23-2009, 05:20 AM | #33 |
104
Rep 2,474
well it cant weight too much without all that crap, so just pick the sucker up. or is cleaning up the garage gonna be the hard part?
11-23-2009, 07:15 AM | #34 |
Most interesting Roadster
70
Rep 2,224
Drives: '01 Z3.0 Roady;'10 C300 Sport
how many miles were on that motor (the one in the above pics)
I can't complain, but sometimes I still do........Life's been good to me so far.
- Joe Walsh |
11-23-2009, 07:40 AM | #35 | |
14
Rep 875
Supposedly 65000. It is possible. The guy I bought it from admitted to running low on oil and the spun bearing. The crank and bearing damage was not unexpected. The crack in the cylinder sleeve was unexpected and pretty much turns the block into a paperweight.
11-23-2009, 08:27 AM | #36 |
104
Rep 2,474
The new roomie is a nice guy. he brought some eye candy with him one day too so that was a bonus.
let me know when you need some more help.
11-27-2009, 09:33 PM | #37 |
14
Rep 875
The car got moved inside this afternoon, the dash was removed and two more (uninhabited) rodent nests were found. It's stripped to the point where it's ready have the frame straightened and and go to the cage builder just as soon as I can get some suspension back under the car. At this point, I'm held up on parts, but expect most of what's needed to show up during the next week. I'm also expecting a new short block by Monday, so the motor should be assembled by the end of next week. I should get some pics posted tomorrow.
11-28-2009, 01:34 PM | #38 |
Rep 10,176
How the hell did I miss this thread, Mike? Great project, although the meathead who previously owned both the car and the spare motor are of questionable background.
Looks like you're gonna have fun this off season. Pretty envious! |
11-28-2009, 07:40 PM | #39 |
14
Rep 875
Pics from yesterday:
11-28-2009, 07:41 PM | #40 |
14
Rep 875
Today's project... Cut a hole in the roof. The vent will get mounted tomorrow.
11-28-2009, 07:46 PM | #41 |
Rep 1,262
Lookin' good, so far! Keep up the good work!
11-28-2009, 07:49 PM | #42 | |
14
Rep 875
As for the guy that the spare motor came from, he was upfront about running it low on oil before I bought it. The bearing wear was not a surprise. The crack in the cylinder wall was, however. I'm pretty confident that he had no idea about that. The other surprises were the stuck oil control rings and the alignment of the compressions rings. The motor had to be burning quite a bit of oil and the compression had to have been low in it since day one.
11-28-2009, 09:20 PM | #43 |
14
Rep 875
So I got motivated and installed the vent. Some help would have made it quite a bit easier.
11-29-2009, 03:56 PM | #44 |
Rep 10,176
Looks good! Like a cyclops Batman, with the red outline.
What did you use to weather seal the vent? Rubber gasket or caulk? Are you going to feather the joint in? |
