BMW
X7 and XM
forum
BMW X7 (G07) Forums General BMW X7 Forum Chipmunks chewed through Coolant Sensor Cable
      04-25-2024, 02:04 PM   #1
mangowarlock
Drives: BMW X7, Tesla Model X P100D
Can someone help me find the right plug that connects to the coolant expansion tank? Chipmunks chewed through a few inches of the two wires that connect the sensor to the main harness. Staealership wants $700 in labor. TIA!!
      04-25-2024, 06:26 PM   #2
streborx
Drives: 2022 BMW X7 M50i
Share a photo?
      04-28-2024, 10:17 AM   #3
mangowarlock
See attachment. It is impossible to picture the actual connector without completely tearing it apart, hence the ask for help. Thanks!
      04-28-2024, 11:31 AM   #4
M_Bimmer
M_Bimmer's Avatar
588
Drives: G12 B7, G07 XB7, F02 B7, 991.1
Originally Posted by mangowarlock View Post
Can someone help me find the right plug that connects to the coolant expansion tank? Chipmunks chewed through a few inches of the two wires that connect the sensor to the main harness. Stealership wants $700 in labor. TIA!!
While BMW does sell certain connector bodies, there are several other solutions that you should consider first depending on the location of the broken wire relative to the connector assembly.
  1. If the broken wire is close to the connector, and you have enough wire length, then you can remove the contact from the connector body, and crimp on a new contact, then reinsert the contact into the original connector body (you will need the correct terminal crimping tool)
  2. Use a short "bridge" wire, of the same gauge, soldering and protected by heat-shrink
  3. Purchase the whole harness from BMW, and install it yourself
Honestly, item 2 above is the recommended method.
If you are still set on buying the connector itself, you will need to take a picture of the actual connector, as the connectors are based on type, not location, in the BMW Parts catalog. You will need to know your vehicle's MFG date too. You can peruse the catalog here.
https://www.bmw-etk.info
xbimmers
