04-16-2014, 12:03 PM | #1 |
Rep 1,247
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
10 speaker system sub's?
So what I have been reading is that the subs in my system are behind the seat my 2004 3.0 sport package with the 10 speaker system. Correct?
Yet when I use the fader, and fade to the back, I have no bass at all. I fade tot he front and I have all the base I usually have. Does that mean I have an issue with the sub's, or is that just how the system is set up where the fader does not put the subs in when faded to the back? The system seems to have decent base (for a factory system anyway) but it all seems to be coming from the kick panel area - not behind the seats. Normal? Problem? Thanks, Matt |
04-16-2014, 01:00 PM | #2 |
#buildnotbought
11015
Rep 4,913
It is normal that the subs fade in with the fronts.
If they produce bass (enough bass)... I don't know. They work ok? take a listen if there's any sound at all (seats moved forewards and listen at the sub speaker mesh)
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
04-16-2014, 01:18 PM | #3 |
Rep 1,247
That is what I was wondering. Maybe they were not considered "rear speakers" and maybe would fade out with the front when the fader was moved to the rear. Bass is always hard to tell where it is coming from, but I can certainly feel the bass pounding on my foot when bass heavy songs are on. I will try your suggestion of moving the seats up and maybe taking the grilles off and see if I can determine that they are in deed working.
The systems sounds decent and I have no reason to think they are not, but like all us car people, I do my best to test everything and keep it working. That is 1/2 the reason I buy cars like this - to piddle with them. Thanks! Matt |
04-16-2014, 01:38 PM | #4 |
#buildnotbought
11015
Rep 4,913
Don't take the grilles off unless you need to.
When the cars get older& the plastic ages, the intergrated clips in the grille tend to break (first hand info......) Just play loud music with a lot of bass (or adjust tone/eq), get the seats foreward and hear (or feel with your hand) if theres bass coming from the speaker grille and that it doesn't sound distorted
04-16-2014, 02:19 PM | #5 |
Rep 1,247
I have already had them both off. One had some "gunk" on it and the other came off to put my smart top in. But you are right, I wont take them off unless I can't hear anything with them on and need to feel with my hand.
12-20-2014, 06:17 PM | #7 |
Rep 3,004
Removed the drivers side sub woofer speaker (lower, large cover) and the clips were fine on my 07 Z4M roadster; removed cover to expose Bluetooth PassKey identification sticker to retrieve the 4 digit number....to program my smartphone for hands-free phone use.
Racerbruce
12-21-2014, 02:51 PM | #8 |
79
Rep 335
I had the same issue (no base). So i pulled the grills off and there was no movement from the speakers. If I pushed on the cone, then the speaker would start working. This is caused by an internal wire that is broken or loose. OEM replacement is very expensive like $400 a speaker. And the non-OEM replacement is hard to find because it is a 10-ohm system. I ended up taking them out and saving weight. I like the music of the engine better.
12-22-2014, 03:09 PM | #9 |
125
Rep 178
Drives: 2007 Z4 3.0i Roadster
2007 BMW Z4 3.0i Roadster / Silver Grey BMW CCA 492691 |
