07-21-2023, 09:33 AM | #1 |
25
Rep 170
Convertible Tops
Is it just me, or is it a truism that all convertibles tops will fail at some point in a car's lifetime? My case in point is that I owned a Mercedes and now a BMW and both of these car's convertible tops have failed. I don't know if this happens more to soft tops versus hard-top convertibles. If I purchase another convertible, I'll make damn sure it's an old-school convertible where I can manually operate it.
What say you? |
07-21-2023, 10:52 AM | #2 |
Rep 4,410
Drives: 2022 Z4 M40i, 2021 228i GC
The issues with a top not working often times is caused by leaking rod seals in the convertible top hydraulic cylinders. This happens because of age and/ or constant exposure to a high heat outdoor environment. After 14 years I had to replace the hydraulic cylinders on a 2004 CLK500 and they only failed after I moved from NYC where it was garaged to hot and sunny Florida where I had to park it outdoors and it was exposed to the elements 24/7.
Malfunctions can be expected to happen with convertible tops the same way other parts on a car need to be repaired/ replaced. In some ways this is similar to our body parts that start to fail us when we get older. I just had cataract surgery performed and my vision is better than ever! Last edited by Westside Guy; 07-21-2023 at 05:25 PM.. |
07-21-2023, 12:57 PM | #3 |
Rep 485
I'm going more generic. Every car part will fail at some point; convertible roof, window regulator, taillights, parking brake, etc. If not this one, another will.
In 18 years of owning convertible tops, they never gave a single problem. But pretty much everything else did.
2016 35is, monoballs, camber plates, KWV3, PS4S, xHP, MHD, LFB pedal, flat bottom wheel, red indicators, black headlamps
Westside Guy5740.00 |
07-21-2023, 04:52 PM | #4 |
sportscars only
3250
Rep 3,199
I was silly because I didn't account for that when buying my car. Knock wood the roof has been great but I fear one day who knows? Supposedly there's not much preventative measures one can take but I found it ironic that ppl who rarely used them (thinking that it may extend the life) seem to get more trouble since the lines weren't regularly flushed and they went on to crack.
The richest one percent of this country owns half our country's wealth, five trillion dollars. One third of that comes from hard work, two thirds comes from inheritance, interest on interest accumulating to widows and idiot sons and what I do, stock and real estate speculation...It's bullsh*t. I create nothing. I own. We make the rules, pal...Now you're not naive enough to think we're living in a democracy, are you buddy?
07-21-2023, 05:35 PM | #5 | |
Rep 4,410
tranquility3249.50 |
07-21-2023, 07:47 PM | #6 | |
sportscars only
3250
Rep 3,199
So, yup, it's kinda ironic for some ppl thinking they are 'saving' their rooftops by using them less and they end up running into trouble.
07-22-2023, 07:38 AM | #7 |
Rep 4,410
Initially my reaction was exactly the same as yours and I agree with you that this approach does make sense.
