06-03-2010, 07:05 PM | #1 | |
Administrator
6731
Rep 4,201
New Details on BMW's upcoming 3-Cylinder Powerplants
BMW Insider Scott26 has posted up some very very interesting and tantalizing news on BMW's future engine productions, which are of course very much in the vein of EfficientDynamics. The new engine in question is a 3-Cylinder engine that BMW has developed for use primarily within the next generation 1-Series (possibly 0-Series?), 3-Series and MINI cars and then would obviously filter its way into other cars in the BMW range in the typical fashion. Whats most important here is the title. The new engine design will be based on a new 500cc per cylinder philosophy that could be used in a modular fashion in a fashion similar to how manufacturers can build many different sized cars based on a shared platform. So that means engines going anywhere from 3 cylinders to 8 cylinders could use the same design scaled up and down as BMW sees fit. Because of the additional use of both turbo charging and direct injection, we should see some phenomenal engine output while retaining fuel economy relative to the given engine size. Here is the original post in his words: Quote:
06-03-2010, 07:34 PM | #4 |
Rep 475
3er is getting to be quite a big car to be powered by such a small engine. Hopefully it will be a sufficient enough powerplant. If it is, great, but I won't be buying one
06-03-2010, 09:10 PM | #8 |
Rep 1,938
The race to make engines with as few cylinders as possible evokes the two-cylinder two-stroke engine used to power a German marvel called Trabant. Happily, the two-strokes of yore are currently as politically incorrect as diesels used to be.
06-03-2010, 09:20 PM | #9 |
Rep 5,561
I think it will have about 120hp and will be the base engine fit into 316i model, available in Europe.. For sure we'll not see it for other markets..
I'm curious for the final specs |
06-03-2010, 11:14 PM | #10 |
Rep 1,569
I would love to have this in a 1er hatch here in the U.S. Something very small with a little engine to get back and forth to work would be great.
06-04-2010, 03:12 AM | #11 |
M Slut
18
Rep 564
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
+1 Watching all the einser's run around here with the diesel badges makes me feel the same way. These cars easily turn in close to 60 mpg.
You have to be 100% behind someone before you can stab them in the back.
David Brent |
06-04-2010, 04:25 AM | #12 |
Rep 3,888
Scott said: "500cc from 3 to 8"
This means: 500cc x 3 = 1.500cc I3 500cc x 4 = 2.000cc I4 500cc x 6 = 3.000cc I6 Actually the V8 is: 550cc x 8 = 4.400cc V8 As Scott said "to 8", it means it will change: 500cc x 8 = 4.000cc V8 But as the V12 is also a 500cc: 500cc x 12 = 6.000cc V12 Why does not Scott say "500cc from 3 to 12" ? I would then assume that the V12 is going to change and become this: 450cc x 12 = 5.400cc V12 or even this: 400cc x 12 = 4.800cc V12 But as the new V8 is going to be a 4.0l (500cc x 8), I wounder if we shall see a new V10 500cc x 10 = 5.000cc V10 derived from this new V8, which could take place in the new BMW Z Spyder Stradale ? |
06-04-2010, 07:53 AM | #13 |
winter mode
62
Rep 2,057
Drives: 08 135i, 88 M3
Sweet idea....I was about to say "I can't believe no one thought of this sooner," but actually, bmw already has. Look at the e90 6 cyl engines. 3.0L / 6 cylindedrs = .5L per cyl. Or what about the old 540 v8? Wasn't that a 4.0L? 8/4=.5
Btw if none of this makes any sense, I was at an open bar party with my coworkers starting at 230pm yesterday.........
88 M3: BMWCCA J Sport
08 135: because streetcar |
06-04-2010, 08:02 AM | #14 |
21
Rep 313
I thought BMW was about "Freude am Fahren"? How does a 3cyl engine fit into that?
*putting on flamesuit*
06-04-2010, 08:34 AM | #16 |
21
Rep 313
Thing is, all cars around here with a 3cyl engine are really small and ugly(that of course is a personal thing ) Daihatsu's, Smarts, Toyota's to name a few. Why would they put a 3cyl engine in a 1 or 3 Series? Fuel economy? I doubt that as I think it would be too small for such heavy cars? Besides that, look at the 320d Efficient Dynamics, that car is awesome when it comes to fuel efficiency but you can also drive it sporty as it has quite some power Why then putting a 3cyl in it?
06-04-2010, 10:02 AM | #17 |
Rep 6,110
Wow. 3 cyl.
When you say impact instead of affect/effect, you are communicating that you don't understand the difference between the two words, and are too lazy to learn.
06-04-2010, 10:02 AM | #18 |
Rep 1,898
the 3cyl. will of course be charged and going up to around 170bhp/260Nm. Will drive better then all the current 4cylinders, I am sure.
Sound is something I'm wondering about... |
06-04-2010, 10:03 AM | #19 | |
Rep 1,898
06-04-2010, 10:28 AM | #20 |
129
Rep 2,218
^ I agree with what he says...
- 2014 CPO i01 BEV Electronaut Edition Capparis White Tera World, '17- - 2015 CPO i01 BEV Laurel Grey Tera World, '17- - 2015 i01 REx Laurel Grey Tera World, '15-'17 - 2003 CPO 330i ZHP Imola Red Build 03/03/03, '06-'15 |
06-04-2010, 11:25 AM | #21 |
Rep 417
QFT... No one has been able to design a smooth 3 banger yet. It's an inherently "rough" running design.
G30 540i Msport
G05 X5 xDrive40i Msport Retired '03 330i, '10 335d |
06-04-2010, 12:16 PM | #22 |
Rep 9,160
