04-05-2015, 06:13 PM | #1 |
Rep 10
Maybe the answer is " nothing"
From the silly questions department: Just passed 100k on my '10 E90. My first BMW (all too late in life) and best daily driver, ever. I did all the scheduled maintenance through 50 K, had my rotors worked on, then just kept changing oil and filters until now. It runs like a champ.
In fact, I finally figured out what makes me want to just keep driving this car, when I'd typically have new car fever by now: It drives like the day I bought it. Should I be focused on any further service items, or just watch to see if / when any sensors tell me otherwise? I do have one issue. A light bulb error message. I have a hairline crack in one lens cover, but all,of my lights work properly What say ye? |
04-05-2015, 06:44 PM | #2 | |
1Addict
3234
Rep 7,895
04-05-2015, 07:19 PM | #4 |
1Addict
3234
Rep 7,895
At the very least change the fluids and replace with fresh OEM fluid. They are absolutely not lifetime fluids.
04-06-2015, 02:05 AM | #5 | |
Rep 4,087
An Congrats.. on the milestone... But something tells me your going to get another BMW |
04-06-2015, 05:13 AM | #6 | |
Rep 3,203
Check ZF literature for recommended service intervals. at 100K, you are way overdue. There is NO such thing as 'lifetime' fluid on these cars. |
04-06-2015, 05:37 AM | #7 |
General
17317
Rep 18,741
What E90 is it and what transmission type?
04-06-2015, 11:01 AM | #8 |
Rep 875
You may even start considering looking at your suspension components and checking to see if they are still in good condition, like bushings, ball joints, axles/boots, dampers, etc. Also check alignment.
04-07-2015, 10:37 PM | #9 |
Rep 10
Thanks for the help. I starting with spark plugs and differential fluid. I did oil, air and cabin filter. Will also have them check suspension components and other fluids
04-07-2015, 10:43 PM | #10 |
Rep 10
Thanks for he help, gentlemen ! I'm starting with differential fluid and spark plugs. Oil, oil filter, air filter and cabin filter replaced. I'll have them check other fluids and suspension components as well
Cheers (And yes, I'll probably buy another one some point I have a '54 Bentley and '89 560Sl with 26k miles to keep me distracted ... |
