The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > High Beams Aren't Working Properly!
      01-02-2013, 08:55 PM   #1
hunginator
hunginator's Avatar
154
Drives: 2012 BMW 135i E82 DCT
Hello All,
I am a new owner of a 2006 E90 325i and I love it! However, it seems like I have a little problem and was wondering if anyone could help.
My xenon high-beams (push light stalk away) doesn't seem to stay on. After I toggle the high-beams on, it'll stay on for 5-10 sec and then it'll turn off and stop working for a bit. It'll come back randomly and then shut off again.
It's getting really annoying so I was wondering if anyone have had the same issue before I resort to the dealership.
Any help is appreciated!
Thanks!
      01-05-2013, 07:37 PM   #2
hunginator
hunginator's Avatar
154
Bump!
      01-05-2013, 07:41 PM   #3
cuiter23
cuiter23's Avatar
81
Drives: 2023 G87 M2 6Spd
2007 BMW 328i  [6.00]
It is most likely connectors in your HIDs. Dosen't seem like your HIDs need replacement since your low beams work fine. I am no expert on this at all but it seems to me that your wires have water damage, faulty, fried, or not connected properly.
Let us know, I am curious as well!
[SOLD] 2007 E90 328i - Titanium Metallic l 19" VMR V710 l H&R Trak+ Spacers l M-Sport Rear Bumper l Mtech Rear Lip Spoiler l Hamann Front Lip l Eibach Sportline l AA N52 Signature Exhaust l OEM Blacklines l MTEC V3 AE l 6000K HID l Nokya 7000K Fogs l MTEC License Plate LED l Interior LED l 15% Tint l BlackVue DR380G-HD + PMP
2023 G87 M2 6Spd - HEA Package | OEM M Performance Carbon Wing
      01-05-2013, 07:43 PM   #4
RedSled
RedSled's Avatar
14
Drives: 335 M Sport
do you have automatic high beams?
//BMW Performance Exhaust//BMW Performance Spoiler//BMW Performance Grills//Cobb//Afe Stage 2 intake//AA Charge Pipe//S2 Interior LED kit//HPB 3000K HID fog lights//KW V3//Llumar CTX 40//
BEU
      01-05-2013, 08:04 PM   #5
username604
username604's Avatar
Drives: bmw
2008 BMW 335i  [10.00]
That's very strange considering it's just an actuator that moves the beam from the high and low position. RedSled asked a good question!
      01-05-2013, 08:58 PM   #6
RedSled
RedSled's Avatar
14
Drives: 335 M Sport
if you have automatic high beams then they are controlled by the light collecting probe on the back of your rear vie mirror. I thinking double tapping the stalk allows you to override it. You will see the icon change on the dash. I use mine all the time.
BEU
      01-06-2013, 12:18 AM   #7
hunginator
hunginator's Avatar
154
I don't believe I have automatic high beams. Did they have it back in the 2006 BMW 325i?
The low beam xenon's work perfectly. The high beams will turn on for a couple seconds and then off by itself. And then I'll try toggling it on/off and nothing will happen. If I leave it toggled on, it'll turn on sometimes and then off and same thing repeatedly.
      01-06-2013, 02:01 PM   #8
Arben72
Albania
50
Drives: E92 M3
If u have automatic high beams a little icon shows right above your odometer.
      01-06-2013, 09:46 PM   #9
hunginator
hunginator's Avatar
154
Hmm, definitely don't remember seeing any icon above my odometer. I probably don't have automatic high beams.
      01-14-2013, 10:24 PM   #10
hunginator
hunginator's Avatar
154
The weather has gotten a bit warmer temporarily in where I live and the high-beam issue has seem to disappeared! This leads me to believe that the cold is the culprit. I guess that something has to be lubed up so that the "shutter" doesn't get stuck when it's cold.
Does that make sense?
      01-14-2013, 10:46 PM   #11
JustinGTP
JustinGTP's Avatar
58
Drives: '13 MINI Paceman JCW
Odd, they should work fine in cold temperature. Is there excessive condensation or moisture in the headlights?
'09 LCI 335i E90 in BSM over Oyster Dakota Leather, Manual, Sport, Navigation, Individual Audiophile, Executive, Active Steering, JB4 + MHD BEF, 335is Exhaust w/AWE Tuning Tips, AFE DCI, Euro Tails/Fog Light Switch, various painted and other OEM + mods, 19" M5 reps summer
'13 MINI Cooper S Paceman JCW R61in Light White & Black Roof/Mirror Caps/Sport Stripes, Loaded + Rare
      01-15-2013, 05:56 AM   #12
Efthreeoh
General
Drives: The E90 + Z4 Coupe & Z3 R'ster
Alright, there seems to be some confusion here. The OP said he has Xenon headlights not HID headlights, so he has the standard headlight setup, which doesn't have a deflector to change between high beam and low beam. If the OP does have standard headlights, then I believe he simply has a bad relay. It has moisture in it. When it gets cold the relay will not hold position.
OP look in the fuse panel and see if there is a high beam relay. Or it might be under the hood somewhere. I can't answer this for you as I have HIDs, so my car is different than yours. If it does have a relay, then replace it and see if that cures the problem.
      01-15-2013, 07:23 AM   #13
hunginator
hunginator's Avatar
154
Correct. I have xenon headlights (the projector things). There doesn't seem to be moisture that I can see by looking into the headlamp casing.
I'll have to do what Efthreeoh recommended. I guess I have to find out where my fuse panel is first - haha!
      01-15-2013, 03:18 PM   #14
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
xenon = HID
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      10-08-2013, 08:51 PM   #15
Nd4Spdgirl
Drives: 06 325xi Wagon
I am having the exact same issue in my 06 wagon. I was wondering if you ever figured out a solution?
      10-09-2013, 08:16 PM   #16
hunginator
hunginator's Avatar
154
Nope, never figured out a solution but I also found out that it only happens during the winters here. When it's warmer out it doesn't seem to have that problem!
      10-16-2013, 08:53 PM   #17
Nd4Spdgirl
Well that is strange. I live in a warm climate place but I guess I will have to just take it to the stealership to have them look at it. =(. Have you had any other issues with your car other then this???
      04-19-2014, 07:09 PM   #18
Boogster
Boogster's Avatar
Drives: 2008 335is with Dinan Stage 2
Thanks for your post about the headlight high beam issue for HID.
Did the root cause for this headlight ever get determined and is there a solution aside from the Stealership?
      04-20-2014, 10:07 AM   #19
hunginator
hunginator's Avatar
154
Not really. I believe it had to do with colder temperatures!
      08-12-2015, 10:30 AM   #20
BobLeeSwagger
Drives: 2008 328i SA
Same Problem
I'm experiencing the same problem.
The research I'm finding is when the lights are turned on there is no HI/LO beam, per se. The headlight assembly has a flap (or eye lid if you will....) that drops down and covers the high beam in normal mode. When you call for high beams, the flap moves up and out of the way to expose the full Xenon beam.
From what I understand, the only way to fix the flaps is to replace the entire headlight assembly,which isn't bad cost wise, until you add in the Adaptive Headlight option, then it goes through the roof!
Not sure if there's a work around to repair it or not. If you have a solution to the flap issue, any help would be appreciated.
      08-12-2015, 05:33 PM   #21
simonsingh
Drives: 2013 640d
When your high beams flick off do they both go off at the exact same time, or are the left/right sides delayed?
      08-18-2015, 05:36 PM   #22
BobLeeSwagger
Both flaps go out at the same time
Both of the flaps fall into the low beam position at the same time.
325i, bmw, e90, headlights, xenon
